Question about Sewing Machines
Belt broke on machine needle not going up and down
  • 28 Answers
I would suggest changing the belt, if you are handy, if you aren't, check with a shop on how much it would cost to replace. Good luck.
Posted on Apr 29, 2017
My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Aug 31, 2008 | Brother XR-65t Mechanical Sewing Machine
Needle broke, replaced it now bobbin thread not picking up nor is belt moving underneath
The needle may not be inserted all the way up the shaft, or you haven't purchased the right needle. Could also be that the needle has been placed in the machine backwards. The long groove Dow the needle shaft must be facing you.
Oct 11, 2014 | Sewing Machines
Belt slipping sewing machine simplicity
Here's a You Tube video that should help. https://youtu.be/8Voq7f5vT6E
Oct 24, 2017 | Simplicity Creative Spirti PLus SA2200...
Platinum 950e sewing machine, the needle broke and now won't go up and down at all, and the main spool will not turn. The motor is running when i press the pedal and the bobbin winder spins, but to needle...
More than likely the motor belt jumped off. Remove 2 bottom torx screws from the base of the machine at the back. Then you have about 7 #10 torx screws to remove from the back cover. Then lift up the pressure foot. The trick to getting the back cover off is to get behind the machine, and slap the back cover and pull off at the same time. Sounds rediculous but thats the way it comes off.
Apr 25, 2011 | Platinum 950E Sewing Machine
Hand wheel wont turn on my Kenmore sewing machine
it sounds like the belt to turn the wheel broke
Dec 12, 2009 | Kenmore Sewing Machines
I have a Euro-Pro 473 model sewing machine, I?m converting into a Needle Felting Machine (adapter is Around metal with seven needles around it and is suppose to be attached into needle bar). I?ve removed...
If you're having the same problem we did, the attachment is installed too high on the bar. Move it down as far as possible and see if that solves the problem. If it doesn't, check to see whether the machine is belt-driven; did the belt break or slip off?
Apr 27, 2009 | Euro-Pro 473
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
