Question about Refrigerators
My water cooler has been making a loud humming noise for several weeks. How can l fix it?
  • 28 Answers
Have you checked your filter? Most likely that needs to be replaced, if you haven't done so recently.
Posted on Apr 29, 2017
I have a KitchenAid Refrigerator Model Number: KBFC42FTS. Bottom drawer freezer over cools -10 degrees.
Does that unit have a low temperature monitor built in? Maybe that is what is making the noise when your temps dip to -10 degrees. Actually, that is great because the lower the temps the longer you can keep food in the freezer so I would not be overly concerned about that aspect. BTW, have you tried to isolate the source of the humming noise?
Sep 19, 2017 | KitchenAid Refrigerators
Just plugged in my new 12 bottle Danby wine cooler and it hums, LOUDLY. Any idea why?
it might , it has a compressor and that would make more noise under a strain . refrigeration units strain when the box is warm. let it run and bring down the temp of the box and then see how much noise it is making . 12 hours should do it.
Jan 30, 2016 | Danby DWC1233BL-SC 12 Bottle Wine Cooler
Ive got power, hot and cold to my existing pump and shower, but the pump doesn't start, just makes a whirring noise.
Above Ground Pool Pump Won't Start or is Humming & How ...
? 6:16
Apr 15, 2014 - Uploaded by Above Ground Pros
Above Ground Pool Pump Won't Start or is Humming & How to Fix It ... Pool Motor - Humming-Loud Noise ...
How to fix your pool pump from humming - YouTube
? 2:43
Mar 25, 2013 - Uploaded by James Hayward
Do you have a pool pump not priming (pumping water) andmaking a humming noise ... not only give a ...
pool pump makes humming noise and does not pump - Trouble F
Dec 08, 2015 | Home
My Igloo ice 102C is making a loud noise when it pumps in water to make Ice. How do I fix this
It shouldn't make any loud noises at all. Most likely it's a water pump related problem. Most pumps make loud noises when they are lose from their base due to a broken clip or untighten screw. It could also be caused by a faulty pump. Either way, if you just bought it and have the receipt, return it and have them give you another one.
Dec 02, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
Loud humming while driving 2005 toy. camary. had tune up and transmission filter and fluid changed 2 months ago, was fine for a while but started humming loud again this week?
Please check your tyres.
if it is due to the tyres put the front tyres to the rear part.check if the noise moves to the rear.did you just replace the tyres?
there are brands offering cheap tyres which make noise .
Jul 09, 2009 | 2002 Toyota Camry
Loud noise
The compressor fan is making the noise and causing overheating as well. Easy fix. Call Danby with model # and they can figure out correct fan. Part will cost around $10 and is easy to replace. Plug and play with screws. Good luck
Apr 21, 2009 | Danby Silhouette DWC512BL Wine Cooler
Periodically cycles through a loud humming noise.
Hi, these are the early signs of compressor failure. i would put in a service call before it completely fails.
Mar 09, 2009 | Refrigerators
Wine cooler noise
Had same problem. cooling fan was going out.Replaced fan about a year ago and now it is going out again. Am ordering another fan now
Mar 25, 2008 | Danby DWC513BLS Wine Cooler
Kenmore side byside refrigerator
Maybe you have some sort of a blockage in the pipes or the water cooler has an electronic fault and mabye needs replacing. Ask an expert such as a plumber. I'm glad i could help. Good luck!
Sep 11, 2007 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
70 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
