Question about Bosch Dryers
Are the sensors on the Bosch Classixx 8 Tumble Dryer at base of drum area on outer casing?
SOURCE: tumble dryer Creda Smplicity T320VW
I am an authorized servicer for Creda and I can explain how to remove the front panel to change the belt. Email me at starztruck4u@aol.com if you still need help.
Posted on May 19, 2008
sonicboomele
  • 1557 Answers
SOURCE: bosch classixx condenser dryer won't turn on
try replacing the thermistate fuse link
Posted on Jul 04, 2010
SOURCE: Bosch Maxx WTL 6100 tumble dryer - door switch
i have wtl 6100 bosch and the mashine is not running. There is power on the machine, it can run but it can not run and heat. I can get light in al the panel, but it is like it needs to be rebouted. I can get it to show 111,222,333 etc in the window but i cant get it to work
Posted on Sep 05, 2010
SOURCE: Bosch classixx tumble dryer container full light
This is happening me too. Have you had any suggestions how to solve this problem???
Posted on Oct 11, 2010
  • 32 Answers
SOURCE: how do you change the drive belt on a Bosch
Its a fairly simple process depending on your machine. Most Bosch machine belts are simple to replace. Here is a good resource: http://www.videojug.com/film/how-to-replace-the-belt-on-a-tumble-dryer-bosch
Posted on Dec 30, 2010
My Bosch Classixx 8 Tumble dryer stops about a minute after start. It shows F09 on screen. Occurs on all programs.
F09 seems to be a problem with the Heater sensor. when you cleaned the sensor di you manage to see if the wiring is ok? From what I read on the fact sheet, it could be a short circuit.
Apr 29, 2017 | Cars & Trucks
Bosch wff 2000 inner drum wobbles and knocks??
when you changed the bearings did you check the spider for any broken legs on it
or have you firmly fixed the belt pully
Nov 11, 2013 | Bosch Classixx WFL 2066 Front Load Washer
How do you change the drive belt on a Bosch Classixx tumble dryer WTA3003GB/17?
Dec 03, 2010 | Bosch Axxis WTA 3003 Electric Dryer
I have a Bosch Maxx condenser tumble dryer that wont work.
Have you taken the condenser itself out from the bottom of the machine? Remove the condenser from the bottom door and rotate the clamp tags which secure it in. Slide condenser out (aluminium mutli-finned box assembly) and carefully take it outside. Use a garden hose with lots of water pressure to spray each vent passage carefully to clear lint and dust away. Passages must be cleared in both directions, long ways and cross ways. Cross ways is the problem area and once you finish clearing the air ways you should see daylight through the condenser easily. Reassemble and always clear lint filter in the door /drum area.
Good luck.
Sam
Sep 02, 2009 | Bosch Dryers
The tumble dryer does not dry The heater element warms up The fan motor is turning but no heat gets into the drum. Bosch Classixx wash and dry
does the element heat up then turn right back off after a few seconds? if so, there is 2 sensors that control the heat element, one is in the duct right after the fan. when this sensor senses too hot, it will shut down the heat element. either your sensor is bad, or the lint is not getting out, causing the heat to build up in the duct.
Oct 27, 2008 | Bosch Washing Machines
Bosch Classixx 1200 Express - metal got under the drum
This video will show you how to get into the drum through the heating element and remove the bra wire on this Bosch front loader washing machine
we have all bosch repairs in our channel
Apr 01, 2008 | Washing Machines
Dryers Logo
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
