Question about Coffee Makers & Espresso Machines
Cleaned coffee maker according to directions just like always it worked fine for 4 days now today water stop coming out and the third blue light is the only one on
    Problem Solver:
  • 18 Answers
Would help to know what Model, But in reality, write to the manufacturer they are really good at answering these simple questions. :)
Posted on Apr 29, 2017
Cleaned coffee maker like I always do, worked fine ,today water won't come out and only third light will come on
Email the Manufacturer, since we don't know what brand model this is, it's impossible for us to GUESS. They will be more than qualified to answer this.
Apr 29, 2017 | Coffee Makers & Espresso Machines
Cuisinart coffee center, ss-15, lights are flashing on cup sizes, and won't make single cup coffee.what to do?
We have the Cuisinart combination 12 cup coffee maker with a 6,8,10 K-cup maker. Today 8/06/2017 the K-cup started making a strange sound stopped working and all 3 blue lights 6,8,10 where flashing and wouldn't make a cup of coffee. After some looking around it seemed that the top stainless steel water injector was clogged, I took a long toothpick and slowly pushed it in as I spun the toothpick around slowly as to not break the toothpick off inside, the water injector is sharp so the toothpick will fray as you spin it around inside this is why you must go very slowly. I also did the same to the K-cup holder stainless steel spike tube to make sure everything was clear and clean, I then ran 4 full water containers through the K-cup system starting with the 6, than 8 and 10 oz. size. I was finding little black objects in my 20oz drinking cup as I was doing this, not sure what that was but after running the 4 full containers through it they were gone. Now it works fine. I hope this helps anyone with the same machine having the same problem
Feb 13, 2017 | Cuisinart Coffee Makers & Espresso...
My ec702 stopped pumping water through. the wand still works. we descaled and cleaned out all filters. nothing. how do we fix it?
I suggest you try cleaning/descaling again. Possibly the scale that was loosened did clog the coffee maker up.
May 12, 2014 | DeLonghi Pump Espresso Machine Stainless...
I was cleaning the coffee maker. The next day the lights wouldn't turn on, so I think water got inside it. But now it's working. Is it ok to plug it in unattended or could it short?
Dry it well. Then it *should* be fine.
You might put the cm with a desiccant, like microwaved rice or those little moisture boxes that come in pill bottles. Leave it for a day or so to soak up any remaining moisture.
The lights/controls of the cm actually run at a low wattage; a malfunction there should not be dangerous unless something causes the heating elements to come on. They are built to be okay if they're on with no water/dry pot, so as long as the cm is away from anything flammable--standard procedure for a cm anyway--it shod be fine even if it turns itself on.
Another option, and the one I recommend, is to go buy a new cm. You should not have to worry about the antics of your small appliances. A new cm will be cheap--and safe--and would set your mind at ease.
Mar 20, 2014 | Mr. Coffee Coffee Makers & Espresso...
Water coming thru coffee maker very slow
If the spray head is clean and clear and you have run the spring the the brew tube till you can push it almost all the way in (leaving only 1/4") then it should not have issues.
Dec 29, 2012 | Bunn NHB Coffee Maker
I have had this coffeemaker for about two months and use it daily. Yesterday the machine refused to make coffee, it would perk and perk but very little water came through into the coffee pot. The self...
We had the same problem and it seemed to be caused by the little charcoal filter. We took it out and the machine worked fine. replacements are available, but expensive. (2 for $9.95)
Dec 03, 2010 | Cuisinart DCC-1200 Coffee Maker
Grinds coming out in cup
When that has happened to me it was because the grounds were too fine...or the coffee maker needed to be cleaned with white vinigar, run through it like you were making coffee, then follow up with water, atleast 2 pots of water after that. The third thing that I tried was using a filter that stores in the maker, not the paper ones, sometimes they fold over and the whole thing gets clogged...Hope this might help...from one coffee drinker to another.....
Apr 04, 2009 | Keurig B100 Coffee Maker
Coffee Makers & Espresso Machines Logo
23 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
