Question about The Audio Players & Recorders
I just received my siriusxm radio. I'm going to have to listen using an fm site.do I need to disable the aux detect?it says disable if using an older dock.is it an older style dock?
    Problem Solver:
  • 18 Answers
I'm not a SiriusXM Expert, but it might help if you give more details on the model equipment you are using.
Posted on Apr 29, 2017
Connecting mp3 car radio
If you radio has an Aux input then you can connect a audio cable from your MP3 player to the Aux input on your radio.
If your radio does not have an Aux input the you can use a FM transmitter device. Connect the MP3 player to the FM transmitter and tune your FM radio to the radio frequency on this FM adapter to listen to your audio book on your MP3 player.
Check out these WEB sites fro FM transmitters.
http://dx.com/c/car-accessories-799/car-audio-systems-707/fm-transmitters-players-710
http://www.amazon.com/Coby-CA-745-Wireless-Transmitter-Cigarette/dp/B000OTF6G0
http://www.popularmechanics.com/technology/how-to/gadgets/4307160
Feb 05, 2013 | Audio Players & Recorders
The radio keeps going from fm to aux on its on
Auto detect circuit in the radio is going bad and reacting to vibration
contact Iron Cross Audio for repair options
www.ironcrossaudio.com
Aug 30, 2012 | Harley Davidson 426290 AM/FM Radio
HOW DO I GET RID OF STATIC IN MY STILETTO 2 CAR DOCK
First, you have to find out if the intereference is coming from your power supply or your FM radio. Are you listening to the Stiletto2 on your car FM radio? Is you car FM antenna visible? First try using a different FM frequency - that is the most simple fix. Second, if you car radio has an "AUX" input jack, use that to eliminate static. If the interference is from the car ignition, that is most difficult to eliminate, but you can try a clip-on ferrite ring on your power cord.
In summary, try a different FM frequency, 2nd, try using an AUX input cable, and if you've done either of those, then the noise may be in the power. Make sure to turn the AUDIO OUPUT level of the Stiletto2 all the way up so that your car radio won't have to be up so loud. Go luck, and let me know if this works for you. Happy New Year too!
JohnnyElectron
Nov 26, 2010 | Audio Players & Recorders
My roady xt does not have a fm select option on the menu
You need to have it in the AUTO base/cradle - AND - you cannot have anything plugged into the LINE OUT or AUX OUT jack, as it will disable the FM transmitter. Try unplugging the audio output, then you'll be able to select the FM transmitter again. I believe that they removed the option from the HOME cradle/dock all together because of regular AM/FM radio stations complaining to the FCC that the transmitters were too strong (in other words, they wanted to hurt satellite radio competition or slow it down as much as possible by forcing Sirius and XM go back and redesign their radios for a much weaker or NO FM transmitter).
Nov 07, 2010 | Delphi Roady XT XM Radio Receiver
While playing a cd it skips to aux I have to scroll down to cd to keep it playing
Either the "mode" switch on the handlebar is vibrating or there is an issue with the auto detect circuit in the aux section of the radio. Check the bar switch first. If that is good, radio will need to be repaired.
06 and newer...contact Iron Cross Audio
05 and older...contact Radio Sound.
Oct 01, 2010 | Harley Davidson 426290 AM/FM Radio
How and where to connect an AUX source (e.g. MP3 player)?
Cassete players do not have Aux Inputs.
You will need to use an FM Modulator type Aux device that will broadcast to a radio station preset on your radio.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 11, 2009 | Pioneer KEH-P6600 Cassette Player
What is a digital pll fm modulator
Hello towturtle,
An FM modulator is a little box that plugs into your receiver antenna connection. It sends a low-level signal directly to the radio which you then tune in on the FM band just like a radio station. They're handy for older receivers that do not have AUX, USB, or iPod inputs. You plug your device into the modulator and it plays through the receiver. The "PLL" just means that the tuning uses a technology called "phased lock loop" which keeps the frequency from drifting.
Hope this helps.
Oct 14, 2009 | Car Audio & Video
Which wire on the back of the radio is aux in? I would like to connect my sirus radio. Thank you
Your receiver does not have an AUX input, so you will need an adapter. Should be easy enough to find, there are many to choose from. Just go to any electronics store. What wires you'll need to connect will depend on what type of AUX accessory you buy. It could plug into the lighter, it may need to be wired.
You could also use an FM modulator. They work well enough in my experience(I'd stay away from Belkin though). This would probably be the cheapest solution and you would still use the AUX inputs and would not have to install/uninstall anything, just plug and play and run your antenna. You may want to wire the power to the 12v power wire on the back of your stereo if the FM modulator needs to be plugged into the lighter, if not then don't bother and just use the lighter to power the satellite radio receiver. :-)
Jul 26, 2009 | Clarion DB-235 CD Player
I have a 6 CD Changer but dont know how to use it?
This is an older way that makers of CD changers used to get CDs into cars that didn't have them.  This is what they tried to get people to by them.  I was never a fan of this system as the sound quality was never better than listening to FM radio.  There is a unit in the car, usually under the dash behind the glove box, that the CD changer is plugged into.  This unit has the FM antenna from the car plugged into it, and then a cable that is the same as that coming from the antenna going from the unit under the dash plugged into the FM antenna jack of the radio in the dash.  All this unit does is take the digital, high quality sound from the CDs, transmit it on an FM frequency (usually low on the FM band 80s, 90s or low 100s) and then you tune the radio into that FM frequency to get the sound form the CDs.  Problem is, the sound quality was only as good as FM radio.  A pretty poor way of getting CDs into cars.  But they sold millions of these things.  If it isn't working, the wiring may have come loose, the fuse to the unit under the dash might be blown, or something is disconnected.  if you go all through the FM dial, 0.1 at a time and don't hear it, it is time to get under the dash near the glove box and poke around.  Good luck.  If it were me, I would take all this gear out and put a new CD/MP3 player where the factory radio currently sits.
Jan 02, 2009 | Marantz ZS5300 6-Channel Amplifier
Top The Audio Players & Recorders Experts
Jose Ma DM.
Jose Ma DM.
kbrowndo4u
Level 1 Expert
metsamehike
Level 1 Expert
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
