Question about Coffee Makers & Espresso Machines
Cleaned coffee maker like I always do, worked fine ,today water won't come out and only third light will come on
    Problem Solver:
  • 18 Answers
Email the Manufacturer, since we don't know what brand model this is, it's impossible for us to GUESS. They will be more than qualified to answer this.
Posted on Apr 29, 2017
Cleaned coffee maker according to directions just like always it worked fine for 4 days now today water stop coming out and the third blue light is the only one on
Would help to know what Model, But in reality, write to the manufacturer they are really good at answering these simple questions. :)
Apr 29, 2017 | Coffee Makers & Espresso Machines
Blue light keeps blinking and its full of water-- just got it today and it won't brew
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101-=-
[p
Aug 10, 2011 | Keurig B30 Mini Coffee Maker
I have had this coffeemaker for about two months and use it daily. Yesterday the machine refused to make coffee, it would perk and perk but very little water came through into the coffee pot. The self...
We had the same problem and it seemed to be caused by the little charcoal filter. We took it out and the machine worked fine. replacements are available, but expensive. (2 for $9.95)
Dec 03, 2010 | Cuisinart DCC-1200 Coffee Maker
What is the best way to remove lime scale and other mineral build up from a Bunn VPR coffee maker? Water flow has been reduced to a trickle even though we used filtered water.
I always use CLR to clean my coffee maker. You don't need much more than 1/4 cup and mix with 8 cups of water and brew it like you would make a pot of coffee, then dump it out and run 2-3 more pots of just water, that should work fine. Also, run vinegar thru the machine once in awhile to help keep it clean
Apr 13, 2010 | Bunn VPR Coffee Maker
How to clean the kitchenaid java express coffee maker
The Coffee Maker can be descaled using
a packaged descaling agent or vinegar.
Always mix the descaling solution using
cool water.
• When using a descaling agent, follow
the directions on the package for the
recommended amounts of descaling
agent and water to use.
• When using vinegar, fill the carafe with
a solution consisting of 1⁄2 vinegar and
1⁄2 water.
Descaling Steps:
1. Before descaling, always remove the
water filter (see “Installing the Ion-
Exchange Water Filter” on page 7) and
make sure the brew basket contains
no coffee or coffee filters.
2. Run the Coffee Maker through a
complete brewing cycle using a full
carafe of the descaling solution.
3. If the cleaning needed indicator lights
after the brewing cycle is complete,
repeat Step 2 using fresh descaling
solution. Keep repeating Step 2 until
the cleaning needed indicator no
longer lights after brewing.
4. Rinse the Coffee Maker by running
it through two brewing cycles using a
full carafe of fresh, cool water
each time.
5. Wash the brew basket in hot, soapy
water and rinse with hot water. This
part can also be washed in the upper
rack of the dishwasher.
6. Reinstall or replace the water filter.
Replace the filter every three months
under normal usage, or more often
with heavy use.
Mar 30, 2009 | KitchenAid JAVASTUDIO KCM534 14-Cup Coffee...
Water accidently poured into coffee dispenser
If the machine is still working, then you are fine. If you can hear the grinder spin, but nothing is happening, then the water caked-up the grinder. It needs to be taken apart and cleaned. It is best to have this cleaning done by a professional. See the authorized service provider list and bring it in for service.
Jan 27, 2009 | Gaggia Syncrony Compact Coffee...
Cuisinart Coffe Maker has no power
Cuisinart replaced the coffee maker. It was still under the 3 year warranty so Cuisinart told me to take it back to one of the stores that sells Cuisinart coffee makers because the store I bought it at was going out of business.
Nov 21, 2008 | Coffee Makers & Espresso Machines
I just need intruction on how to clean my Kitchenaid coffee maker i cannot find my booklet
I Always Clean these Cases, Assesories with Orange Cleaner and Baking Soda ( Works Wonders ). Use a Tablespoon of Baking soda and run with water ( NO Coffee ) Though System. Cleans System Fine and is Safe. Once every month.
Aug 16, 2008 | KitchenAid Pro Line Coffeemaker Coffee...
vinegar is not the best thing descaler vinegar remove calciumin little piece that might block thr rest of machine descaler produit melt calcium 1 part solution 1 part water fill the water tank start machine leave it running for few second turn off for 15 minute and repeat untill empty dont forget to rince the machine very good that stuff is very corosif but does the jobs thanks for using fixya pierre
Feb 09, 2008 | Cuisinart DCC-1200 Coffee Maker
Coffee Makers & Espresso Machines Logo
27 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
