Question about Singer Sewing Machines
Bobbin latch on Singer Touch and Sew model 626 won't seat properly. Therefore plate covering bobbin case will not slide back into place.
    Genius:
  • 1,067 Answers
Have you had the bobbin case out? If so, remove it again and replace carefully.Or contact manufacturer .
Posted on May 02, 2017
Why the bobbin casing won't snap into place
Usually you need to hold the little latch open until the bobbin case is seated in the machine. Perhaps this video will help;
Singer Promise 1408 Get started
Mar 29, 2016 | Singer Promise 1408 Sewing/Quilting...
Bobbin case wont stay in place when I sew
Most bobbin cases have a latch that must be released to remove or install in the machine. Be sure to hold the latch open while you insert the bobbin case into the machine. Rotate the bobbin case slightly until it feels seated. Then release the latch. If the bobbin case is not latched in place, it will continue to fall out whenever you begin to sew.
Apr 01, 2015 | Sewing Machines
I have a Singer Touch and Sew #758. The bobbin case keeps popping out of possition when I try to sew. I have cleaned and oiled the machine, checked all the threading, tried different bobbins, etc. The...
it does sound as if the sprung bracket is not holding the case in position. Move the latch to the right, remove and install the case and then move the retainer back into its proper position
Feb 17, 2014 | Singer Drop-In Bobbin 758B-28BH Mechanical...
I cannot get the thread from my bobin to come up out of the face plate for my Singer Zig Zag 753. The bobbin does not rotate, though the bobbin winder part works. The bobbin is in seew position. The bobbin...
When you slide the throat plate cover back into place, there may be a little lever the plate is suppose to move back into place. Try to reset the cover to see if it will catch.
Recheck the manual to see if there is another function that should be reset.
Make sure the bobbin is not over wound.
Feb 28, 2010 | Singer Sewing Machines
Loose Bobbin Case on Singer 4830
Your first step is to go to the Singer site and download your user manual -- it's available free. You need to check to make sure that you are inserting it properly in the first place. Please keep in mind that the bobbin does NOT turn--the thread unwinds from the stationery bobbin.
Next, I would manually sew using the hand wheel and no fabric with the needle plate off and observe what it's doing. You CAN replace the bobbin case if necessary.
Jun 30, 2017 | Singer 4830
Bobbin
IMPORTANT: Always use a metal bobbin, or the magnetized bobbin case will not be able to function properly, resulting in a lack of tension on the bobbin thread.
9a8cb19.jpg Step 1:
Turn the handwheel counter-clockwise until the needle is in its highest position. Raise the presser foot lifter. Pull the slide plate forward and remove the empty bobbin.
Step 2:
Place the filled bobbin into the bobbin case, and pull about 4" of thread from the new bobbin. Make sure that the bobbin turns clockwise when the thread is pulled, or you will not have correct tension when you begin to sew.
Step 3:
Hold the needle thread loosely with your left hand. Turn the handwheel toward you, first lowering the needle, and continuing to turn the handwheel until the needle comes to its highest position.
Step 4:
Lightly pull up the needle thread and pick up the bobbin thread which will appear through the needle plate slot. Then pull both threads to the back of the machine leaving a 4" thread tail. Push slide plate back in.
Hope this helps. -samson39
Jul 22, 2009 | Singer Sewing Machines
Singer touch and sew 648
Thread the machine as if you were going to sew. When you thread the needle, pull the thread off to the left and wrap it around the thumb screw on the left and just above the needle. Wrap it only 2 or 3 times and hold the end of the thread. With bobbin in place and the face plate slid open, push the thumb lever on the left under the face plate to the left. Begin to 'sew'. As you do, the bobbin will wind and the thread you are holding will detach. Once the bobbin is full to the outside line, slide the face plate the closed position. As it closes, it will release the thumb lever. Put the needle in the slightly lowered position and slide something blunt under the pressure foot pulling thread from both the bobbin and the needle; cut the thread when you've pulled it out sufficiently.
Jan 19, 2009 | Sewing Machines
Bobbin filling on Singer 626
The Singer 626 has a self-winding bobbin. You place the empty bobbin in the bobbin thingie (sorry for being so untechnical). On the left of the bobbin you will see a "lever" with a circular top on it (I think it is red-ish) Again, sorry for being so untechnical. Press the "lever" down. Thread your machine, thread the needle, wrap the excess thread from the needle around the knob that tightens the needle and holds it in place and press your foot down on the foot pedal. The bobbin will automatically wind as you hold the foot pedal down. Do not wind the thread onto the bobbin past the outer white line.
Aug 17, 2008 | Sewing Machines
Sewing Machines Logo
75 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
