Question about Top Irons
I ha e a DG5030 ih releses top much water and no steam what can i do to fix it? Thank you
    Top Expert:
  • Top Master
  • 49,215 Answers
Buy a new one
Posted on Sep 10, 2017
3 Suggested Answers
  • 43501 Answers
SOURCE: Rowenta Steam Iron DG5030; Iron drips water
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
Posted on Jul 14, 2010
  • 684 Answers
SOURCE: do you know where I
Hi there.
You can buy parts for your steam iron at
Posted on Jul 15, 2011
The iron is still working but the water not hot
There is most likely a build-up of minerals around the steam holes. Minerals are in ordinary tap water. The coat the heating surfaces, act like an insulator and prevent iron from getting hot. Clean the hot plate with a fine needle or other fine object and then put in a mixture of vinegar and water and let it steam out. To prevent future mineral build-up, use half distilled water and half tap water. If you can't get distilled water, use ordinary drinking water you can buy from your supermarket (it also cheaper). Don't use 'all' distilled water as it boils (steams) at higher temperature and could ruin your iron. Good luck.
Jan 20, 2015 | Rowenta DG5030 Iron
Dg5030 steam is not working
Sounds like you may have a buildup of calcium in the water line. Try putting in some LimeAway and letting it sit overnight to clear it out. The drain the LimeAway out refilll and steam a few times on scrap cloth to get all of the cleaner out, see id that solves the problem.
Aug 13, 2014 | Rowenta DG5030 Iron
Steam comes out the filler cap on the water base on my Rowenta DG5030
WIre brush the caps screw threads and replace the O Ring ASAP.
DOn't use the iron until you get a new O ring and they need to be the orange/red rubber ones they are able to withstand the hot steam black o rings at home depot won't last.
Jul 24, 2014 | Rowenta Pressure Iron and Steamer DG5030
Fix rowenta dg5030
Send it in for repair.
Google Rowenta Repair Center
Jul 22, 2014 | Rowenta DG5030 Iron
Ssteams constantly without pressing steam trigger
Sounds like your trigger valve in the iron portion (not the tank) is jammed open. It could be from mineral deposits so maybe try running it with a solution of distilled water and a couple of tablespoons of vinegar in the tank. Wiggle the steam trigger to try to release any scaling that maybe present inside the valve. If your steaming from the iron stops, you've fixed the problem so let the iron cool and rinse the tank using ONLY DISTILLED WATER which anyone knows is the only type of water to be used in ALL appliances. Minerals in regular tap water kill appliances quickly. Never use tap or bottled drinking water even if the directions say it's okay. Iron some old rags or towels with a tank of distilled water to make sure no mineral deposits or staining steam comes out after cleaning.
If this fix doesn't work, you can buy a replacement iron portion online..try It's cheaper than buying a whole new iron but you may need a repairman...I've never tried to fix this portion of my DG5030 iron.
Aug 28, 2013 | Rowenta DG5030 Iron
Steam is coming out of water fill area
Where did you purchase a new cap, mine was accidentally broken and can't find a replacement.
Apr 22, 2013 | Rowenta Pressure Iron and Steamer DG5030
Steam comes out of the place where you put the water in
check the holes in the hot plate are not blocked with lime scale...sounds like you have a back pressure problem
Dec 29, 2012 | Rowenta DG5030 Iron
Water keeps coming out after pressing steam button
hi i have just looked this information up and apparently that using 100% distilled water can cause your iron to spit and leak, to solve this problem you should press the steam button and keep pressing it until there is no water left in the iron, then try it again, if it still does this, repeat a few times and then the iron should be fine
hope this helps
Feb 28, 2011 | Rowenta DG5030 Iron
Irons Logo
119 people viewed this question
Top Top Irons Experts
ray gallant
Tom Chichester
Michael McClure
Michael McClure
Are you a Top Iron Expert? Answer questions, earn points and help others
