Question about Swift Computers & Internet
Error code e25h on truma hot air heater in swift challenger 584 caravan, no heating
  • 7 Answers
SOURCE: i have a 2000 dodge caravan, no heat
Sounds like the air "blend" door might be inoperable. This door opens and closes a specified amount to regulate the amount of either cooled or heated air, as requested by the climate control unit. If the door is continually in the position which is bypassing the heater core (cold setting), the air will not get warm regardless of the condition/operation of the heater core. I'd suggest having this component checked.
Posted on Nov 28, 2008
mnabi01
  • 94 Answers
SOURCE: i have a 1995 dodge
240cpa is right.dodge caravan does not have a heater control
valve and coolant constantly crculate in heater core . use the temperature contorol on instrument panel if you notice no change in heat your blend door in heater box is not moving . and as 240cpa mentioned make sure the t stat is not stuck open.
Posted on Jan 27, 2009
SOURCE: heater blowing clod air
Check your rad, could be a leak and low on fluid - check level in overflow. Low fluid with leak, no heat. replace radiator
Posted on Feb 28, 2009
morse008
  • 1111 Answers
SOURCE: My heater in my dodge caravan does not blow hot
First of all make sure your anti-freeze is at specification level's as well as make sure With the engine cold start the vehicle remove the radiator cap and make sure you see the flow of anti-freeze while keeping your hands as well as your clothing away from moving parts feel both hoses going into your heater core if the one on top of hot one on the bottom is cold then you have a Clogged heater core in which case you will need to flush the system . a simple garden hose will do the trick simply remove Both hoses to the heater core with the hose at the bottom line apply the garden hose until liquid comes out at the top of the other hose will probably see a lot of gunk. Also ensure that the vacuum line to the round ball under the hood is connected and not dry rotted.this will cause a vacuum leak to not allow the switch to fully engage from cold to hot. I hope this helps you.
Posted on Nov 07, 2009
  • 1779 Answers
SOURCE: 2001 Dodge Caravan heater blows cold air when stopped
Have you checked the coolant level? What you describe is exactly what happens if the coolant level is low. When stopped at idle, hot coolant is not circulating through the heater core, so no heat. As the engine increases in rpm's when you pull away from the light, the water pump is spinning quicker, and some coolant is making it to the heater core. So check the level, and if it is low, keep an eye on it to see if it drops again. That of course indicates a leak somewhere. Get it fixed, as overheating the engine leads to costly repairs and worse case a new engine. Let me know how you make out with this.
Posted on Dec 05, 2009
Testimonial: "Thanks Curt! You were right ON!"
Can I use a Truma hot water heater on gas in my shed kitchen for washing up?
I just looked on the website which contains a remark there is only approval for installations for campervans and caravans.
Nowhere in the description or specifications does it mention a flue or ventilation requirement which is very surprising because burning gas needs a good supply of fresh air and produces poisonous gases that must be got rid of/vented to the exterior.
I guess you could use your heater as long as the requirements of an adequate fresh air supply and the venting of combustion gases is taken care of...
Sep 10, 2017 | Water Water Heaters
2000 dodge caravan heater blowing cold air only car does not overheat
Feel the heater hoses where they go through the firewall. If they're both hot but you're not getting any heat, your blend door is not moving to mix heated air with unheated air. It could be the blend door actuator not working or the HVAC control unit not working.
Mar 31, 2017 | 2000 Dodge Caravan
2006 dodge grand caravan replaced thermostat and radiator, still no heat?? And the van is running hot
How hot is the engine in degrees F? With a fully warmed engine are the heater hoses, hot? Check coolant flow through the heater core. If no coolant flow through the heater or engine, I'd have to check water pump.
Sometimes when the cooling system is opened, it may get air in the system, your temp gage may be reacting to air in the system?
Nov 22, 2014 | 2006 Dodge Grand Caravan
Dec 05, 2009 | 2001 Dodge Grand Caravan
Why the Goodman air heat unit that will not come on?
we are trying to loacte teh starter for the pilot. Seems to kick on but no hot air, so not heat throughout the house. Sorry, total mentally challenged in basic home appliance repair...
Jan 27, 2009 | Goodman GMS90703BXA Heater
I have a 2000 dodge caravan, no heat
Nov 27, 2008 | 2000 Dodge Caravan
Electric water heater will not stay on
sounds like the electrical thermostat is defective and is being over ridden by the overheat safety stat.
Nov 17, 2008 | Water Heaters
Computers & Internet Logo
54 people viewed this question
Top Swift Computers & Internet Experts
ray gallant
Steve P
Steve P
JonSnell Electronic
JonSnell Electronic
Are you a Swift Computer and Internet Expert? Answer questions, earn points and help others
