Why would 3 touch pads be out. There is something wrong with xfi nity in our area. Am I not right.
3 Suggested Answers
KingDWS
  • 1606 Answers
SOURCE: DELL 1501 TOUCH PAD BUTTONS DO NOT WORK AT ALL. HELP.
This could be a hardware or software (windows) problem.
If it is hardware it could be as simple as the connector ribbon inside is loose or that the touch-pad unit is failing. A replacement is $30-$80 plus labour.
I've seen a few of these where the problem is windows acting up. Since you have tried the drivers and they didn't fix it what you can try is go to control panel - system - hardware - device manager - mice and other pointing devices
Open that and select and then delete the pointing device or mouse shown. Then reboot. Windows is now forced to detect the touchpad hardware and reinstall the drivers. That usually does the trick unless it is hardware caused.
Now the tricky bit. Once you delete the mouse you will have to close and reboot using only your keyboard. You need windows to reboot normally, you can't just pull the power cord. To do this use ALT-F4. Hold down the ALT key and press the F4 that will close the windows until you get back to the windows desktop where it will close down windows. When you start the computer again your mouse will be detected and will work again. What we won't know is if that is enough to reset things and get your buttons working until you try this. You can try this a few times but generally if the drivers are right and you have done this then its time to replace the touch-pad.
Posted on Aug 17, 2009
mulmol
  • 184 Answers
SOURCE: My right button on my Dell touch pad isn't working....
The right mouse button might worn out due to normal wear and tear in everyday use. These buttons are usually replaceable bring it to your local Computer Tech. and have it serviced.
Posted on Dec 15, 2009
I filled a bobbin and the touch pad quit working, will still sew, but only straight stitch, no adjustments
if the bobbin winding has been switched back to normal sewing then there could be something wrong with the computer
May 11, 2016 | Sewing Machines
Can someone help instead for my computer to output slash out it do something else. that where to find @ i find " and vise visa
http://www.ebay.com/itm/NEW-IBM-LENOVO-Ideapad-G575-G575A-G575AC-G570-series-KEYBOARD-US-black-frame-/110931720756?pt=PCA_Mice_Trackballs&hash=item19d40bba34
A) Forward Slash: -> /
Combined with ? key. To the LEFT of the Shift key
(Above CTRL key on Right side)
Also in number pad area at Top.
To the Right of the Num lock key.
(Number pad area is right side of keyboard)
B) Back Slash: -> \
Combined with Colon key ( : )
To the LEFT of number 7/Home key, in number pad area on Right.
C) 1, 2, 3, 4, 5, 6, 7, 8, 9, 0; then Hash ( - ) key.
Combined with Underscore ( _ )
.....and slash out it's batten are not there...........
Believe Forward Slash is your slash out.
Explained where it is above.
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 01, 2013 | Lenovo G570
I recently deleted some old files and temp files to free up disc space and when i rebooted, the scroll on the right side of the mouse pad is not working the buttons are and the double click function is too...
The files in temp folder can be safely deleted and have nothing to do with touch pad atleast. Something else might have gone wrong. Just check from the Device Manager or Control Pannel that the drivers for touch pad are installed. If so, check for the scroll option (synaptics touch pad utility) and set it accordingly.
If it doesn't work, you may download and reinstall the touch pad drivers again from the manufacturers support site.
Hope it helps! Good Luck!
CreativeTECH
Apr 20, 2011 | Computers & Internet
I can't use for scrolling up and down from the right side of mouse pad, how to setting it? thx
Sometimes there is a setting, under mouse, in the control panel. But also there is a time based issue, you need to stop while pressing in the scroll area, and the mouse shifts from mousing to scrolling. Duration of time, and first touch to the pad in the scroll area are keys.
Oct 27, 2010 | Compaq (153515-001) Touch Pad
I dont want to be able to select something just by touching the little pad, i want to hafta left click, I'm constantly accidentally selecting something, just by touching it.
You can adjust your keyboard and the touch pad , controls with the adjustments in the menu for mouse and keypad options.
Also you can use the personal settings to get this right for your touch , adjusting the sensitivity accordingly
Sep 24, 2010 | Computers & Internet
The touchpad above my keyboard is no longer responding as I think i may have deleted something from the hard drive. how do i fix this? When I first recieved the computer the majority of the touch...
sure you deleted something, how else can a driver just go byebye.
NO OS stated is this XP
we cant guess what OS is there ever.
so does mouse work, usb plugged in , that be first.
after checking device manager, for touch pad , driver errors
then know a pad this old can be bad.
it can also be set wrong in control panel, click mouse
and set it as you like.
Feb 18, 2018 | HP Pavilion DV9720US Notebook
All functions halt unless I press very hard on touch pad area....
Doubt it. Seems like a bad fault, maybe it's worthwhile contacting whoever you bought it off - it sounds like a faulty good.
Jan 25, 2010 | IBM ThinkPad T43 Notebook
Mouse is not responding at all
you need to go to device manager...
right click "my Computer"
select "manage"
select "device manager"
click the + sign for "mice and other pointing devices"
select your touch pad...
try to enable it or find what is wrong from there
You'll need a USB mouse or something of that ilk to do it.
good luck
Apr 10, 2009 | Lenovo 3000 N500 Notebook
Dell XPS 1330 touchpad scroll areas quit working
Hi Patrick,
The most likely problem is that the ribbon cable from the touch pad is not making proper connection with the motherboard.
I would recommend you get this repaired under warranty, there is a bit of work involved in pulling the laptop apart to get to this cable & connector and if you do something wrong it could void your warranty.
I can give you instructions if you wish to try and fix it yourself.
Let me know.
Nov 26, 2008 | Dell XPS M1330 Laptop
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
