Question about GE Microwave Ovens
Tvs have not worked in 3 days. Cannt ge in touch with anyone.
How do I unlock the control panel of a ge microwave oven?
See the link
Many microwave control panels can be locked to prevent accidental use or access by children.
There are two different ways to lock the control panel:
  1. Press and hold the CLEAR/OFF pad for 3 seconds. The display will show "LOCK" and then revert to the time of day. A small "L" will appear in the corner of the display as a reminder that the control panel is locked. If anyone tries to use the microwave, the display will show "LOCK".
  2. On some models, press and hold the 5 and 7 pads simultaneously for 3 seconds.
To unlock the control: Repeat the procedure which was used to lock the control. (Press and hold the CLEAR/OFF pad for about 3 seconds or hold the 5 and 7 pad simultaneously for 3 seconds.)
unlock the control panel of ge microwave Google Search
Nov 05, 2017 | GE Microwave Ovens
Why are GE Profile JT930 touch pad numbers not working?
Seems problem with the touch pad. Try replacing the same.
Aug 16, 2014 | GE Appliances 30" Trivection Built-in...
Help! GE spacemaker 2.0
I had the same problem , it was finger touch control panel, when I cleaned with spray then it worked for some days . Finally to get ride of it , I changed control panel with a new one.
May 12, 2013 | Microwave Ovens
GE model JVM2070SK02 touch pad not working
Most people, and GE will tell you these are not repairable and you must replace the whole unit for $300 - 500. I can fix them. If you are interested, let me know. em.ka.ventures@gmail.com I can only fix the touchpad not working and it must not be physically damaged. You must be able to take out the control panel and send it to me. It is easy (3 screws and electrical connectors).
Jun 01, 2012 | GE Profile Spacemaker Over-the-Range...
Hello, I have a GE Spacemaker 2.0 (JVM2070SK) and with an electronic touch panel. The unit is 3 years old, the panel lights up with all the options however, when you touch the screen nothing happens. Then...
This is a common problem, and they're often intermittent.
You'll need a new touch screen.
You can get complete details on all these 2070-series microwaves on my page here:
http://www.microwavecontrol.com/jvm2070.htm
- William E. Miller, AS-EET
pupista@gmail.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 01, 2017 | GE Profile Spacemaker Over-the-Range...
Ge microwave works intermittent, when not working display reads F-3 and key pad does not respond
This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Sep 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE micowave, keypad will not work
GET THE OVEN NUMBER AND SEE HOW MUCH THE TOUCH PAD COST, SOME TIMES THE TOUCH PAD COSTS AS MUCH AS MICRWAVE OVENS NOW DAYS
Aug 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Touch control failed on GE Spacemaker Microwave HVM1540
If you want to order a touch pad, (it has the micro computer built in it!) and fix it that way, you'll still have a 2-3 year old machine.
I would say it would be quicker and cheaper to buy a new one.
Jun 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Too HOT to touch
how old is this, check the intake and extract vents for obstructions
Aug 30, 2008 | GE JVM1790 1000 Watts Convection /...
Microwave Ovens Logo
29 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
