Question about Tablets & eReaders
I need a charger for zte tablet, not micro usb, the charging port is about 3/4 in long
    Sergeant:
  • 111 Answers
My tablet won't charge
First try to charge it with a different charger, and test the factory charger on another device (you tablet may have the common micro USB connector). This will test if the charger or cable are bad. But if the tablet will not charge with a different charger and cable, and it is still covered under the factory warranty, return it for a refund or a replacement.
I have repaired many tablets with a bad charger port, and it seems to be either a poorly designed connector, or an open wire inside due to pushing in too ******* the cable into the port.
if you cannot replace the tablet, maybe you can find help from someone who can open the tablet and fix the charger port.
Nov 27, 2017 | Tablets & eReaders
My Samsung tablet won't charge when plugged in
Does it have a micro USB charger/charging port? This was the universal charging adapter most manufacturers other than Apple moved to around 5 years ago. In my experience, the charging port to charger connection can become loose and prevent charging....especially if you use the tablet or phone during charging. The best method I have found to troubleshoot the issue is to try a charger that successfully charges another device and plug it into the tablet or phone. If your device still does not charge, and especially if the connection is loose, it is most likely that your charging port is damaged. Another possible issue would be the battery itself but the charger or charging port is the most likely culprit for your issue.
Sep 08, 2017 | Samsung Tablets & eReaders
My Charger Port is no longer there is there any other way to charge it
Jillian, Check warranty, I beleive should be one year, call manufacturer right away if under warranty. Option 2 Have charger port replaced at a computer/cell phone repair shop. Check links below and see how they fixed this issue.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Android tablet charging port fix
How to Fix the Charging Port on Tablet
Is there any way to charge my tablet without the micro USB port
http://forums.androidcentral.com/amazon-kindle-fire/283806-anything-i-can-do-if-my-charging-port-broke.html
Apr 26, 2016 | Tablets & eReaders
The charger wont go in to the port to charge it and the tablet needs to be charged it was working just fine last night dont know if my son did something or not
Robin, the charge ports can be changed at a computer or cell phone repair facility. Check the attached links,instruction and guides, Good luck
How to replace the fixed charging port
How to Fix Tablet Charger Port
Amazon com 2 pcs Replacement Micro USB Charging Port Connector for Vizio...
Apr 24, 2016 | Tablets & eReaders
HiSense Sero 7 tablet. Why no charge, no power?
About 1,620 results (0.80 seconds) Search Results
    HQRP USB to micro USB Cable / USB Charging Cable for ...
    www.amazon.com > ... > USB Cables
    Amazon.com, Inc.
    Rating: 2.9 - ‎22 reviews
    1A AC Wall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA .... If you try to use the tablet while it is being charged, no charging will take place.
    HQRP AC Adapter / Battery Charger / micro USB Charging ...
    Amazon.com, Inc.
    Rating: 3.7 - ‎6 reviews
    HQRP USB to micro USB Cable / USB Charging Cable for Hisense Sero 7 LT E270BSA / Hisense... ... HQRP Micro-USB AC Adapter rapidly charges your Cell Phone / Tablet PC ... This one does not. ... Yes No Sending feedback. ... $3.91. 1A ACWall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA Tablet.
    HQRP AC Adapter Dual microUSB Charging Cable for ...
    www.amazon.com/HQRP-Adapter-microUSB-Chargin...
    Amazon.com, Inc.HQRP AC Adapter Dual microUSB Charging Cable for Hisense Sero 7 LT E270BSA... Do not wait until charging one of your devices to charge the second.
Feb 09, 2016 | Tablets & eReaders
I have the Trio 7" Dual core tablet. The battery is not charging completely, can this battery be replaced and if so where do I find the battery in the unit?
Battery replacement is possible. The battery is a flat component encased in a shiny silvery sheath behind the speaker area inside the back cover. It's mounted with double-sided (very) sticky-tape. A replacemnent battery should be sourced, having the same power specifications as well as physical dimensions. (see detailed close-up photo attached.) Replacement involves desoldering the 2 terminal wires (1 red and 1 black) which attach it to the main board, and replacing the battery with a new(er) unit.
The above having been said,I'd only replace the tablet battery if I was sure that it's the battery at fault. Here's what I'd suggest.
First, check that you're using a charger with the proper 5 Volt / 2Amp (2000milliamp) output. Also I'd suggest you use a charger designed to be plugged intothe G2 7" Dual-Core tablet's dedicated charging port. (See sample tablet charger in attached photo) The G2 tablets WILL typically accept charging output via the micro USB port, for example, from a typical cell phone charger. However typical phone chargers which will happily attach to the Trio or other similar tablets, via the micro-USB port do NOT often have the same output power specifications. This I think may cause difficulty with the tablet battery not reaching the fully-charged status. Also, the use of the USB port for charging may cause access problems if the battery power is low during some operations (eg data transfer in slave mode), as the charging port can not multitask as the USB port can. If power to the main boad is lost during such operations the tablet may become "bricked". Bottom line for me would be to use the dedicated appropriately rated charger whenever possible: it's the reccommended charging method.
25239131-kxzyo1nfvoux0zgzt1u5dqab-5-3.jpg 25239131-kxzyo1nfvoux0zgzt1u5dqab-5-5.jpg
Oct 18, 2014 | Trio Mach Speed Stealth G2 Tablet - Teal...
Repair 2012 nexus 7 charger port
The micro usb charging port on the nexus 7 is notorious for becoming useless b/c cords fit loosely in the port right out of the box. Micro usb cords get wiggled and jiggled because of the size of the opening and then the port will no longer charge b/c solder breaks from the board, or the tongue inside the port partially breaks apart.
You can buy the replacement micro usb / headphone jack assembly for about $50 and do the repair yourself (hopefully) ...or you can send it to us and we\'ll replace just the jack and ship it back to you all for $54.95
More info and our repair form is on this page:
http://www.rockhoptec.com/services.php#t...
Mar 04, 2014 | Tablets & eReaders
Playbook totally drained power cannot charge
The problem may be with your charger, Micro usb cable or your micro usb port. The blackberry playbook rapid charger uses the little brass buttons to charge and will help you diagnose if the problem is with the playbook battery or if the problem is with the micro usb connection.
Feb 17, 2014 | Tablets & eReaders
We need a plug
The charging on the tablet depends on the model.
Most including the Kocaso 776 charge via the micro USB port, and this is a standard USB port.
So all you do is purchase a micro USB to standard USB cable and plug it into the standard USB port on the charger or a PC.
Feb 07, 2014 | Kocaso 7" Capacitive Touchscreen Tablet...
Kindle fire hd tablet won't charge up
1) Plug it into a different USB port on your pc;
2) Use a different USB charger - look to see if the one supplied with your 'phone has the common Micro USB jack;
Fire's take about 14-16 hours to charge from a pc and 3-5 from the wall,
Jan 27, 2014 | Amazon Kindle Fire HD
Tablets & eReaders Logo
70 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
