Question about Garden
I have a gt 1554 cub cadet. I noticed last year that the tractor would bog down real bad when I engaged the pto clutch, but it would recover and then I could mow.
But this spring it stalls the motor out completely when I engage the pto and if it does run it shakes real bad. I removed the deck and checked the spindles, they all move freely,dont seem bent, it has new bldes so they are balanced.I tested the pto, it had 12 volts and 2.9 ohm so that is correct. I figured the bearing in the pto was fried, so I purchased a new one, and thats not it. It stills stalls or bogs way down and shakes real bad. The pto engages with no attachment and doesnt shake. There is no debris on the deck top or bottom, nothing looks bent, it has newer blades that appear good. Could a spindle be bad and still move freely with no wobble or bearing movement. ??
SOURCE: My Cub Cadet 2135 PTO won't engage.
i had the same thing happen
found that the on/off switch had come unplugged from the wire harness just below the switch
had to attach the wires to something underneath so the weight did not pull the wires down and taped the two switches together to prevent it from pulling apart
it needs some kind of clip to hold them together
hope that this works for you
jo
Posted on May 24, 2009
panilling9
  • 284 Answers
SOURCE: engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
Posted on May 26, 2009
  • 257 Answers
SOURCE: Mower stalls when engaging blades
check the safety switch for engager could be bad,, hope this help,, good luck
Posted on Aug 15, 2009
  • 10865 Answers
SOURCE: cub cadet rzt 50, hit stump, blades wont engage but not bent
The blades on this cub cadet are activated with air pressure. Chances are that when you hit that stump, you either blew a fuse or the control module that allows the blades to spin. Begin by checking the fuses. J.
Posted on May 28, 2010
  • 146 Answers
SOURCE: cub cadet pto won,t stay engaged
Sounds more like a PTO clutch failure, rather than the switch. The clutch is mounted on the engine shaft, between the hydrostatic drive pulley (nearest the chassis) and the mower deck belt pulley (farther from the chassis).
Since it's an expensive part, make sure the problem isn't in the switch or wiring first. You could do that by probing the wires to the PTO clutch with an automotive test light - they are inexpensive and handy. Clip the ground wire of the test light to the chassis, and probe the hot wire to the clutch (it's the one that doesn't connect to ground) when the engine is running and the PTO switch is engaged. Obviously a helper has to be in the seat, and you should be careful doing this. If the light glows brightly, and the clutch doesn't engage, you definitely have a bad clutch. Good luck! Please rate my answer if helpful, thanks.
Posted on Jul 07, 2010
Cub cadet gt 1554
check for bad switch or bad relay behind dash or bad pto clutch jump it with battry were it connects with pto connetor
Jul 06, 2014 | Garden
Pto will not engage
i have had many that the wire breaks where it goes into the clutch and have luck in repairing the wire so see if you have power and ground at the connector have also seen a few safety switches go bad
Jun 19, 2012 | Cub Cadet Garden
I have a rzt 54 cub cadet, when i engage the pto it cuts breifly then the mower shuts down PLEASE HELP
A battery going bad may be your culprit. I found out just the other day that your mower can keep running but when the battery gets too weak, the pto clutch disengages and shuts down,
Apr 29, 2012 | Oregon Scientific Electric PTO Clutch for...
Cub cadet pto won,t stay engaged
Jul 06, 2010 | Cub Cadet Street Sign- tractor lawn riding...
CubCadet 1554 - won't start!
If you hear the PTO click when you turn the ignition on, sounds like the PTO button is pulled out like you were engaging the blades. The engine will not start if the PTO button is pulled out....
May 07, 2010 | Oregon Scientific Electric PTO Clutch for...
I have a cub cadet 3185 with a PTO problem
Check PTO switch and look for broken wires down around the clutch itself
Sep 24, 2009 | Cub Cadet Street Sign- tractor lawn riding...
PTO switch shuts down tractor
if the pto bearing is locked up it will stop a motor dead this is a common problem. You will have to get a new clutch assemble. The other thing that it could be is the deck has a locked up spindle.
Aug 19, 2009 | Oregon Scientific Electric PTO Clutch for...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
