Question about Amana Refrigerators
Amana AFD2535DEW7 Leaking during defrost from the bottom freezer. How to fix this???
  • 1122 Answers
SOURCE: water inside bottom of freezer after defrost cycle
your freezer drain is either frozen or clogged,remove stuff from bottom of freezer and you should be able to see the drainhole..if frozen use a hair dryer to melt,then to make sure it 's not clogged use a wire hanger to clear it out and you should be ok,let me know-mike
Posted on Oct 31, 2008
jumptrout51
  • 3361 Answers
SOURCE: how do you unstop the drain line
Remove the freezer back wall and lower panel. Remove the visible ice. Use a hair dryer to defrost the drain hole in the rear trough.
Posted on Mar 13, 2009
Maanita
  • 1142 Answers
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Mar 24, 2009
    • 72 Answers
    SOURCE: Viking freezer leaking
    you have a clogged drain, it is either clogged with ice or some kind of debris, thaw the freezer out and push a length of weed trimmer line down the drain. The drain is accessible by removing the back wall of the inside of the freezer. If there is no clog then the drain may be freezing up, if that is the case, take a piece of 14 gauge romex wire and loop it several times around the heating element at the bottom of the evaporator and push a few inches of it into the drain, this will get hot and transfer heat when it goes into a defrost cycle which is where the water is coming from in the first place
    Posted on Jun 17, 2009
    woodchuck789
    • 4070 Answers
    SOURCE: ice forming on bottom of
    Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
    Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
    Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
    Posted on Aug 18, 2009
    Where does Amana bottom freezer drain discharge to? I have manually defrosted the freezer. Water dropped into drain. Now water leaking out of the bottom at side of unit.
    The defrost water drains into a holding pan and is evaporated away. The video displays the most likely problem.
    https://youtu.be/_MyOFwRWRTY
    Oct 22, 2017 | Amana Refrigerators
    I have an Amana BRD18V1 or V2, bottom freezer. About every two weeks it leaks water on the floor on the right hand side and i have to defrost the bottom part to get about an inch of ice out. I trust...
    I assume you mean water leaking on floor of bottom freezer? There should be a small hole in floor in back to drain defrosted water down to pan under unit. This line might be clogged with food or frozen water. Carefully pour some hot/boiling water down tube to clear. You should see it empty into pan under unit where fan evaporates it.
    Jul 15, 2010 | Amana ABB1927DE Bottom Freezer...
    My amana side by side refrigerator is leaking on the freezer side ..puddle on floor or starts melting on its own
    Defrost drain is clogged with ice and overflows from defrost. Lower section of freezer at the bottom area of the freezer back wall.
    Jan 31, 2010 | Amana ARSE66MB Side by Side Refrigerator
    FREEZER AT BOTTOM OF REF. COLLECTS ABOUT ONE INCH OF ICE. THAN CANT OPEN BOTTOM DOOR SEEMS TO BE LEAKING DROPLETS OF WATER FROM REF. AT TOP WHAT COULD BE WRONG?
    Defrost condensate line behind the rear panel is clogged up. The watter is flooding over the condensate collection tray and and through the cabinet. Click below.
    HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
    There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
    Watch the short movie on how to get to the tray behind rear panel in freezer and if you have trouble or questions let e know, Thanks, Sea Breeze
    Nov 14, 2009 | Amana ABB1927DE Bottom Freezer...
    Amana bottom freezer: water leaking & ice build-up
    There should be some kind of drain at bottom of freezer compartment to collect and run off any condensate that collects during defrost cycle.. Clean out the drain and snake out the line that leads from it. Right now the liquid is collecting where it should not and it will leak out the gasket when you have enough of it.
    Sep 09, 2017 | Amana ABB1927DE Bottom Freezer...
    Samsung Fridge Freezer leaking water
    hi August.
    Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
    3 common refrigerator problems you can easily fix yourself
    The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
    How to Fix Water Leaking From the Bottom of Freezer
    Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
    SOLVED Water leak in refrigerator Refrigerator
    Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
    Amana abb222zde bottom freezer not defrosting
    unplug the freezer. let it defrost for a day then plug it back in. You will be fixed up then.
    Jan 29, 2009 | Amana ABB222ZDE Bottom Freezer...
    Refrigerators Logo
    44 people viewed this question
    Top Amana Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
