Question about Kenmore Refrigerators
How do we level our kenmore side by side refridgerator that has wheels.
    Top Expert:
  • Kenmore Master
  • 42,994 Answers
If the wheel are not adjustable in height, you will have to shim underneath.
Posted on Apr 29, 2017
Where do I find a manual for the kenmore coldspot # 59099990 refridgerator
Model number is not valid check plate inside refrigerator. Usually Sears Kenmore start with 3 digit model number like 590.xxxxxxxx, and usually have characters that tell u what characteristics the model has and what color scheme.
May 10, 2014 | Kenmore Side by Side Refrigerator
CAN NOT LOCK THE WHEELS TO KEEP REFRIGERATOR FROM ROLLING
A refridgerator will roll forward and back you cant lock the wheels. If the floor slants that much you can take little peices of wood or carboard to place in front of the wheels so they dont roll.If you have anymore questions please comment me back so I can further assist.
Jul 28, 2011 | Kenmore Side by Side Refrigerator
The Refridgerator is not level. How do you level the refridgerator - how do you get at the levellers in the back?
before you push the frig back to the wall set the "left right" level making sure that the feet are not down all the way, you want the adjusted feet to be about half way up.
when you slide the frig back to the wall you can now level the front to rear using only the front levelers. if that doesnt give you enough movement to get it level thaen redo the process but make all the levers higher before you push back the frig.
Jan 16, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
How do i level a refridgerator
Most will have screws on the front two legs. Remove the lower grill and check in the area of the front legs for these screws. If you have a bubble level set it on top side to side and screw the screws until it is level that way and then set the level front to back and check and do the same. If you do not have a bubble level, you can use a clear glass, measure the glass at a point and mark around the glass. Fill to that mark with water and level the fridge with that.
Oct 17, 2010 | Kenmore 57029 Side by Side Refrigerator
Kenmore Refridgerator/Freezer does not work.
check your damper vent door located between the fridge and freezer and make sure its opening up to let cold air into the fridge,also check the evaporator fan motor and make sure its operating to blow the air around the inside of the unit
May 23, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
How to level a maytag plus side by side refridgerator I got the front wheels level, but the back right wheel is not coming down and the whole unit can tilt to the back right. How do I get the back right...
There is a bolt in the middle of the bracket that holds the wheel that you turn. When you tighten the bolt it pushes on the the wheel bracket and it goes down, bringing the fridge up. Loosen, it goes up bringing the fridge down.
Nov 27, 2009 | Maytag MSD2756G Side by Side Refrigerator
Door not closing properly
Hi: The Kitchenaid refs. us a gravity close along with the magnets in the door seals. Magnets getting weak seals getting old and what you told me you checked can cause this. The easy fix is to raise the front of the fridge by lowering the front wheels. Pull the grill off the front and find the leveling screws (usually labeled.) Raise the front of the fridge until the doors swing shut with a gentle push. Before you replace the grill make sure the fridge dosn't rock side to side as you want it even. This is what they call leveling a fridge. Not cabinet level. Just sturdy. Hope I helped, Jeff
May 31, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Hot high side assembly and at the front door section
Replaced the GE fan motor which seems to have solved the problem.
Dec 28, 2008 | Kenmore Refrigerators
Refrigerators Logo
29 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
