Question about Cannon Office Equipment & Supplies
My cannon multi functional printer /scanner scans with full red background. The scanner head bulb scans showing full red colour. I tried even to adjust white balance to default,
Is there any connection loose between logic board and scanner head? Or any settings on logic board need to be verified? Any switch settings on Scanner head need to be changed. Please provide possible solutions
    Master:
  • Cannon Master
  • 641 Answers
Hi. I think that scanner reading sensor is defective. Light has to be white color only.
Posted on May 16, 2017
SOURCE: problem scanning with samsung scx 4521f
My connection is via a parallel to parallel cable, and I am also having a similar problem. I'm reading that usb to usb cable is the only way it will properly function. good luck with it!
Posted on Oct 20, 2008
SOURCE: My scanner doesn't scan negative
" I can only select platen as the sourc. the film setting has vanished" - I had the same problem. Unplugged the USB cable from a shared usb 2.0 hub and plugged into an old USB 1.1 dedicated port and it started working. No ideas why (perhaps in the hub it couldn't detect the scanner model correctly)
Posted on Dec 29, 2008
Just4help
  • 145 Answers
SOURCE: I need for Mustek 1248UB scanner Driver
Hope this link works for you.
http://www.mustek.com.tw/html/prod_scan/1248ub/specification.html
Posted on May 31, 2009
SOURCE: Sanning problems for multi function printer PIXMA MP 160
Just hold the stop and reset button until the warning goes away. Works like a charm
Posted on Feb 11, 2010
Xeea
  • 70 Answers
SOURCE: I have a Canon iR1600 network printer. Need scanning facility.
download the driver i will send u the link http://driverscollection.com/?H=iR1600&By=Canon
Posted on Mar 11, 2010
My Canon e510 printer scanner scans with full red background
hi . if the light is not white the image sensor unit is defective and has to be replacex
Apr 29, 2017 | Canon Office Equipment & Supplies
Sir, i want to scan a colour matter , i have 2570 cannon printer copier, please tell me or send software
it does not require any software just on the printer and keep the document on platen and click the colour button a green colour button.
Oct 17, 2010 | Office Equipment & Supplies
My mfc240c says to replace the yellow ink cartridge but I don't want to spend money on that if the 'light bulb' is ruined. When I turn on the machine, I don't see any light for scanning or copying. ...
By the "light bulb," do you mean the scanner lamp? That lamp should only turn on when you are actually scanning, faxing, or copying a document. You should be able to still use the machine to scan and fax, even with the yellow ink empty. Try scanning a document to see if the scanner lamp comes on.
As far as printing or copying goes, you won't be able to print or copy anything until you replace the yellow ink, even if you try printing in black and white only.
Apr 19, 2010 | Brother Multi-Function Center MFC-240C...
Brother MFC 215C :yellow and red refuse to print
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Nov 12, 2008 | Brother Multi-Function Center® MFC-215C...
Print Cartridge Problems
i have an mp170 all in one and when you fill the cartriges they dont show up as full cannon put a chip in the cartridge to con people into buying new ones try siting the cartridges in warm water for a few hours then blot the cartridge with tisue paper if it dont blot out the ink the cartride is finnished and you need a new one .To align the cartridge you flick through the menu on the printer not pc screen look for alignment page print this off then you have to pick the dark boxes on the sheet shade the bit next to it and put on your scan bed and click ok it should scan the sheet and reset the alignment
Jul 19, 2008 | Canon PIXMA MP180 All-In-One InkJet...
Colour Problem
Sorry, that won't help. I've tried doing all that you state. And this is on a brand-new Microtek 9800 scanner. Wish I could help
Feb 16, 2008 | Microtek ScanMaker 6100 Pro Flatbed...
Feb 13, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Sanning problems for printer PIXMA MP 160
some printers can detect that the cartridges are refilled based ona barcode or scanning of the cartridges. Does this Cannon have ink tanks or ink cartridges. If it has intakes then the print head needs to be cleaned wth rubbing alcohol and a q-tip. If they are cartridges then it would be good just to buy the original cartidges. As far as the scanning goes this can be a direct connection to the printer going through maintenance. If it continues to not scan then you may need to uninstall the scanner. see if the scanner shows up in your scanners area. if not then it will need to be re-installed.
Feb 13, 2008 | Computers & Internet
29 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Iqbal Husain
Iqbal Husain
Victorman
Victorman
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
