Question about Hotpoint Refrigerators
How do I replace the heater element on a hotpoint quadrio FFU4DK fridge/freezer?
The Machine
  • 788 Answers
SOURCE: FRIDGE/FREEZER KEEPS FREZING UP
I would consider the thermostat sounds like the freezer thinks it's warmer than it actually is and keeps running.
Posted on Apr 10, 2008
  • 1462 Answers
SOURCE: wd 860 hotpoint washer dryer heater
take rear bottom rear panel off. you will see heater slightly towards the rhs held by 1 10mm nut in centre. loosen nut and prise out. why do you want to replace it as obviously you haven't tested it?
Posted on Aug 09, 2008
barkencoa
  • 3463 Answers
SOURCE: have a hotpoint tdc30p dryer that will not heat
Check to see if the new parts fitted are o/k,
If they are, then your problem is probably a faulty control unit or possibly bad connection in the wiring.
If the new parts are faulty, then something else is causing them to fail.
Make sure all filters are clean and that all air vents are clear
Posted on Dec 12, 2008
  • 53 Answers
SOURCE: hotpoint fridge freezer icing up freezer and fridge does not work
Does your model have independent thermostats for the fridge & freezer???
If not, could be that you will need to change the Thermostat.
These are not expensive - around £10 if you buy on the Internet.
Easy to fit yourself...just turn off the power, remove the power plug from the wall, then unscrew the 'stat unit from inside near the top of the fridge (some are attached to the interior light) and remove the screw holding the thermostat tube to the rear wall.
Often the thermostat gets a small hole somewhere in the long tube, which then lets all the gas escape, making the stat useless.
You can see these small holes in the pipe if you use a magnifying eyeglass, like the kind Jewellers use.
Posted on Nov 17, 2009
SOURCE: fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
Fan not working, fridge not cooling anymore, freezer seems ok
Hotpoint Fridge Freezer RFA52 BUT I DONT KNOW WHERE IS THE FAN CAN SOMEONE HELP ME TO TELL ME WHERE IS THE FAN IN MY FRIDGE SO I CAN DEFROSE IT.
PLESAE EMAIL ME ON: RAFIK02UK@YAHOO.CO.UK
MANY THANKS
Posted on Mar 01, 2010
Where is the fuse on hotpoint quadrio fridge freezer
Hello Donna;
My name is Peter. I am a retired field service refrigeration technician.
Refrigerators do not have fuses. They have independent component (Part) failures that act like a fuse.
If you can provide me with a model number and some detail of what the issue is, I would be more than happy to help you.
Nov 21, 2014 | Refrigerators
Hotpoint quadrio fridgefreezer keeps tripping the electrics when I open the fridge door.
I believe that a short circuit creates a defective light bulb inside the refrigerator or some other element in its circuit (door switch, lamp socket, wiring).
Dado
Apr 26, 2014 | Zanussi Freezers
Hotpoint quadrio fridge isnt cooling but freezer is can i start its defrost cycle manually?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 10, 2011 | Hotpoint Refrigerators
My hotpoint quadrio amber lights at the top of the fridge door are flashing is this anything to worry about - they are indicated with the words ''super cool'' and ''super freeze'' (sorry but cant find...
my hotpoint quadrio is causing problems the fidge part is no longer cooling the light is coming on but thast is all what can cause this. can anyone help
Feb 20, 2010 | Refrigerators
Freezer cold, fridge warm
Hi, You have a self defrosting problem.
Remove the rear inside freezer panel and check continuity on the defrost element and bi-metal switch.The bi-metal has to be tested cold. If there is continuity on both parts, you will need to change the defrost timer.
The most common part that goes bad is the element. I hope this helps you. Please leet me know if I can assist you further.
Vic
May 28, 2009 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
81 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
