Question about Cannon Office Equipment & Supplies
My cannon multi functional printer /scanner scans with full red background. The scanner head bulb scans showing full red colour instead of usual white colour. What is the solution please.
jonniewalker
  • 1031 Answers
SOURCE: Canon MP600 all in one inkjet printer
error code u052 is a print head error that means the print head is faulty If unit is still under warranty should cover the printhead. Go ahead and call canon support number for your region or go online to canon website for closest Authorized Service Facility and they will take care of it for you.
Good luck
Posted on Sep 19, 2008
  • 3 Answers
SOURCE: Dell 1815 dn printer scanner issue: single line appears in scans
Do you get the same line when you use the adf for other purposes?
If so, check the scanner glass just before the platen for something like white-out on it. Clean both the scanner glass and platen glass with Windex.
That is a common problem on all ADF scanners.
Good Luck
Posted on Nov 20, 2008
rulds2008
  • 3866 Answers
SOURCE: troubleshooting in scanning and printing
You have to reset that cart. before you fill it there should be instructions on how to do this on the refill kit you bought, you cannot just fill the cart and put it in the printer you will dmage the print head if you have not already done so. I cannot see what was done so I could not give you a solution but only tell you that the ink needs to be charged before you put it into the printer!!!
Posted on Apr 30, 2009
SOURCE: Sanning problems for multi function printer PIXMA MP 160
Just hold the stop and reset button until the warning goes away. Works like a charm
Posted on Feb 11, 2010
SOURCE: Multi-function Samsung CLX-3175 doesn't scan to PC
I had the same issue with Windows 7 64 bit.I managed to solve it by doing the following
1. Locate the scan2pc.exe program in C:\Windows\twain_32\Samsung\CLX3170 2. Right-click/properties - Compatibility tab. 3.Set compatibility to win xp. Set "Run as Administrator"
I also added the scan2pc.exe to the firewall allowed programs (did that for scanmgr.exe as well, but I don't think I needed to).
Works great now!
Good luck!!
Posted on Apr 30, 2010
My Canon e510 printer scanner scans with full red background
hi . if the light is not white the image sensor unit is defective and has to be replacex
Apr 29, 2017 | Canon Office Equipment & Supplies
Scan/copy issue: horizontal lines and bulb red
It's the scanner fluorescent lamp faulty, replace the scanner will solve the problem
Jul 15, 2017 | Samsung CLX-3175FN Color Laser All-in-One...
Sir, i want to scan a colour matter , i have 2570 cannon printer copier, please tell me or send software
it does not require any software just on the printer and keep the document on platen and click the colour button a green colour button.
Oct 17, 2010 | Office Equipment & Supplies
When I scan a document to my computer it comes with blue background
This is usually caused by the white balance being on manual instead of automatic. You can correct it on the scanning applet control panel (varies depending on your driver OS and version), or after acquisition in whatever program you use to manipulate the image.
Also (rarer) it could be caused by a yellowing of the automatic white balance calibration strip which is under the glass, near the scanning head homing position.
Apr 27, 2010 | HP Scanjet 4200c Flatbed Scanner
Colour Problem
Sorry, that won't help. I've tried doing all that you state. And this is on a brand-new Microtek 9800 scanner. Wish I could help
Feb 16, 2008 | Microtek ScanMaker 6100 Pro Flatbed...
Sanning problems for printer PIXMA MP 160
some printers can detect that the cartridges are refilled based ona barcode or scanning of the cartridges. Does this Cannon have ink tanks or ink cartridges. If it has intakes then the print head needs to be cleaned wth rubbing alcohol and a q-tip. If they are cartridges then it would be good just to buy the original cartidges. As far as the scanning goes this can be a direct connection to the printer going through maintenance. If it continues to not scan then you may need to uninstall the scanner. see if the scanner shows up in your scanners area. if not then it will need to be re-installed.
Feb 13, 2008 | Computers & Internet
Scan head/carriage not parking in one spot -- keeps moving.
The scanner is having trouble getting its "white reference" usually due to dusty mirrors, but can also be the bulb losing brightness. These are not a easy machine to pull apart if your not used to it.
Good colour laser MFP, depends on volume of prints and remember colour dont come cheap, but dont use refill cartridges, Kyocera and Oki both have good Models
Dec 01, 2007 | HP LaserJet 3320mfp All-In-One Printer
26 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Iqbal Husain
Iqbal Husain
Victorman
Victorman
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
