Question about Microwave Ovens
KCMS135GSS just stopped working. We want to fix it. What can we do? No clock, no display, checked outlets and nothing.Do you still make parts for this?
2 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: kitchenAid microwave #kcms135gss just stopped
You probably have a blown internal fuse or thermostat (one is on the top of the cavity and one is on the magnetron).
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find links to helpful exploded view diagrams and part ordering help here. I'd recommend that your bookmark this link to your favorites.
Posted on Dec 05, 2009
Micrwave not working
see this causes and fix it. God bless you
If the microwave will not work at all, make sure power is on at the outlet and test the electrical cord. Test the fuse and replace it if it is faulty. Also check the door to make sure it closes properly. Test and, if needed, replace the fan.
If the oven doesn't cook or cooks only intermittently but the display is on, check the door interlock switch, the thermal cutout and the fan, replacing parts that don't pass the test.
Oct 16, 2012 | Microwave Ovens
GE Profile Spacemaker XL 1800
Yes the main fuse has blown for several different reasons. If you have no electrical know how, or experience using a multimeter you really should have a pro take a look at it. It could be anything from a bad capacitor, a bad High Voltage diode, a bad door switch or maybe even a bad magnetron or a control panel. Not really a job for a novice to attempt, as the main AC fuse will not blow for no reason. Good Luck
Sep 17, 2007 | GE JE1540 Microwave Oven
Microwave stops randomly on its own, dispaly flickers and I get prompted to enter clock settings, what should I do to fix it
When a microwave asks for the clock settings, it has lost power. Check the plug and the outlet for damage or if it is loose. When on, vibrations can cause the plug to reposition if loose enough. Even a very short loss of power will reset the microwave. If the plug/outlet is ok, then check to make sure that the fuse for the outlet is tightened fully (breaker switches do not have this problem). Last, try another outlet as the wiring to the outlet may be loose.
Feb 11, 2012 | Danby DMW773 Microwave Oven
Model # MH7149XFQ - 0. Nothing works. No light when you open the door. The control pad does not respond. The light under the microwave does not work. The clock display shows the digital clock but the clock...
1. Go check your breaker box. Find the one for this outlet, reset. Or just reset every one if U cannot figure that out. 2. if that does not do it..... The ck the Outlet w/ a proper tester (cheap @ builders supply, just a plug in tester w/ lite for volts.... too easy. 3. If neither of these work, find the fuse for the microwave & replace. If not qualified, hire or ask someone who is.... 4. none of these work..... time to buy a new one. gettocar
Aug 14, 2011 | Whirlpool MH7140XF Microwave Oven
Microwave JE 1860 has been making a loud noise for several months. Today it quit. Nothing works. No light. Turntable does not turn. Nothing on the display ... not even the clock. The unit was purchased...
Unless your personally attatched to this oven I would recomend you start shopping for a new one. Take the cover off and look for any fuses inside the front door area or on the control board, If they are bad replace them if none there then get a new one as they are more expensive to repair than replace. Most likely your magnatron shorted out and took the circuit with it, but check your house fuse as well on that circuit to be safe. A magnatron runs around 90bucks part only.
Jul 01, 2011 | GE JE1860 Microwave Oven
KitchenAid microwave #kcms135gss just stopped working no clock display , changed to diff outlet still nothing
Dec 05, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Have old tappan speedwave 1000. buttons work but when you press start nothing work except the countdown on display
Unplug the unit for 15 minutes...plug the unit in and try again. If that doesn't work - take the back cover off and look for any blown fuses...should be obvious.
Mike...
Nov 29, 2009 | Tappan Microwave Ovens
EVERY PART OF THE MICROWAVE STOPPED WORKING
There is an internal fuse inside. Need to find the cause for it blowing or it will just go again. Check the monitor switch and door switches. Eric
Aug 08, 2009 | Jenn-Air JMV8208AAS Microwave Oven
Kenmore over the range microwave 721.63684300 - nothing works
you must remove the MW take off the cover then look for a large metal can (capacitor) and a white (ceramic) fuse...look and, smell and, you should find the cause
Apr 02, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
Microwave Ovens Logo
29 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
