My circupool rj45 is displaying pump run up. What is that and what do i do?
Connecting hp 513735 kvm to a datacentre. Monitor to vga on kvm. Vga on cable to srvers and rj45 to kvm 8 x rj45. cannt see any servers. Menu dont display any server after pressing prntscrn. What i'm doing...
this user manual may help you have to configure the switch first with a IP address and subnet mask that will let the switch see the server.
I am not totally up with hp but it looks similar to Cisco switches in that you have to configure the switch. I am studying Cisco at the moment and this seems similar.
http://h20565.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c01931438
Feb 16, 2015 | HP Computers & Internet
I'm getting salt lo msg.brand new unit, brand new water, 810 pounds of salt for ten days
Have you tested for salt content in the pool. Most salt generators require between 3000 and 5000 ppm of salt for it to operate correctly. How many gallon pool? 810 pounds of salt should make it around 30,000 gallons?
Jun 30, 2014 | CircuPool Salt Water Pool System
I have a E2000 wireless router. I had to disconnect it and do not have the instructions on how to reconnect it. Could you please help me
run your cable or your phone line into modem, then run your rj45 cable to ethernet from modem to eternet in router then run your other rj45 cable from router to computer! I hope this helps !
May 28, 2011 | Computers & Internet
I have a Bose Lifestyle 38. The cable that links the Lifestyle with acoustimas module has been been detached from the RJ45 plasticclip due to move of furniture. The cable is fixed in the walls and not...
i have life 38, looking at rj45, copper facing you (flat side of Rj45),
read left to right
white, brown, space, space, brown, space, white, red.
it looks first white brown runs down one side of flat cable, and the other 3 core brown white red down the other side of flat cable.
Hope this helps you out.
Aug 19, 2009 | Bose Acoustimass 6 III System
I'm currently having router trouble.
The first thing to know is, what kind of OS are you running?
Go to start and click on run, on the dialog box type 'cmd' or 'command', then type 'ipconfig /all'
Please look at your Default Gateway should display:
192.168.1.1 or 192.168.0.1
The modem rj45 cable should connect to the internet port on the router and another rj45 cable connect from the router(any port 1-4) to your pc
open your browser and go to http://192.168.X.X
The last resort will be to reset your router by pressing a reset button on the back of the router for 5-10 seconds.
Jul 13, 2009 | Linksys Wireless-G WRT54G Router
Flashing image on the Display
Icons from left to right:
The world: The Internet, if blinks there's not connection.
The modem: Your ADSL/Cable modem attached to the yellow RJ45 port
The router itself
The computer: All the attached computers to the grey RJ45 ports
The WL computer: All the computers connected via WiFi
The lock: Means that there's WiFi security enabled
Jan 02, 2009 | Belkin N1 Vision Router
Rj45 male to db9 male cable for ups
If you have a BackUPS CS, you are probably either using it with the USB cable that is supplied or with the 940-0128A supplied by APC, which permits running the UPS in dumb mode. By building your own cable, you can now run the BackUPS CS models (and perhaps also the ES models) using smart signalling and have all the same information that is available as running it in USB mode.
The jack in the UPS may be easily use a 8 pin RJ45 connector. It is easy to construct the cable by cutting off one end of a standard RJ45-8 ethernet cable and wiring the other end (three wires) into a standard DB9F female serial port connector.
PC Signal PC pin UPS Pin UPS signal RxD 2 2 TxD TxD 3 8 RxD GND 5 7 Ground FG Shield 4 Frame Ground Though these UPSes are USB UPSes, APC supplies a serial cable (typically with a green DB9 F connector) that has 940-0128A stamped into one side of the plastic serial port connector.
Here is suggested scheme of original 940-0128A cable
APC Part# - 940-0128A computer --------- Inside the Connector--------- UPS DB9-F | | RJ45 pin - signal | | Pin - Color | | 4 DSR ->|---+ | | | diode resistor | 6 DTR ->|---+---->|----///---o kill power | 8 Orange | | 1 DCD <-|----+ | | | | 2 RxD <-|----+----------------+--o low battery| 3 Brown | | | 7 RTS ->|----------+--///--+ | | | | | +--///--+ | | | | 8 RI <-|----+----------------+--o on battery | 2 Black | | | 9 CTS <-|----+ | | signal | 5 GND --|-----------------------o ground | 7 Red | | 3 TxD | | | chassis | Chassis/GND |-----------------------o ground | 4 Black | | | Not connected | 1, 5, 6, 9, 10 --------------------------------------
Sep 30, 2008 | Digi (76000200)
Computers & Internet Logo
David Payne
David Payne
