Question about Gaggenau Ovens
How do I do the clock test prog reset for my gaggenau BMW 270/271 oven. To enable me clear error code E141 Please your reply is truly appreciated.
  • 3,828 Answers
Gaggenau Oven Instruction Manual - Dhs.Org
my-pdf.dhs.org/gaggenau-oven-instruction-manual.pdf
Posted on Apr 29, 2017
  • 12 Answers
SOURCE: Gaggenau EB 270/271 Electric Clock
To set the clock:
1. Press the clock key 3 items until the hr/min icon flash.
2. Press the + or - key until it come to your desired time.
3. Press the confirmation (check) key.
You have your time.
If not, call the service support.
Posted on Sep 01, 2008
ziraffa
  • 827 Answers
SOURCE: F14 error message
First change the fuse. Then if it still isn't functioning properly, you may have to replace the lamp, in which case you should contact a specialist. Details can be found in the Instructions Manual.
Go here:
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
and enter EB270 and click the Go button.
Then download the PDF file of the manual in English (EN)
Hope this helps :)
Chris (ziraffa)
ps Someone else on Fixya claims to have fixed the F14 problem by changing the PCB Board, whatever that is.. but there was no further rating or feedback given. That's all I have.. Good Luck!
Posted on Jan 11, 2009
  • 10 Answers
SOURCE: error code F 20 on Gaggenau EB 260/262 oven
Sometimes the error light will come on because of mixed signals sent. If everything works, then just ignore it. Unplug the oven or turn power off in fuse box. This may reset the light control. Be very careful around the power source. Wear rubber bottom shoes, have dry hands and floor. Don't touch exposed wires with anything. This is 240 volts that can hurt or kill you!!!!!!
Posted on Nov 03, 2009
Testimonial: "Appreciate the advise, but would still like to know the exact meaning of error code F 20. Thanks."
  • 30 Answers
SOURCE: kenmore electric built-in oven control panel beeping
Try this first!
The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem. If that does not work, repalce the defective parts yourself. You can do it for about 30% of what a repair company would charge. it's either got to be 1. Control panel 2. Relay panel. Good luck!!!
Posted on Nov 08, 2009
  • 8 Answers
SOURCE: My Gaggenau oven shows a
I have the same problem and the technician came out and took the oven out. He couldn't figure out was wrong and will need to contact the manufacturer technician to help him with the diagnosis of the problem. In the meantime, he says it looks like my modem is not working and may not be responding to the commands that would normally remove the key lock after a power outage.
Sorry, can't be reset - you'll need to pay the big bucks to have a technician out to assess, make sure you tell him your model number so that he can do his homework prior to coming out, that way you're not paying alot of money that I had to for this tech to figure things out. He took one hour and charged me $120 with no fix and will have to come back anyway.
Posted on Nov 25, 2009
How do I go about clearing the error code E141 displaying on my gaggenau oven with the clock test prog and reset method???
F23-relay electronics not selecting. There is either a fault with the pcb or a loss of continuity within the ribbon cable. Unfortunately, I think you are going to need an expert to look at this to confirm.
Sorry I cannot be of more assistance but some faults do require a physical check from a professional and cannot always be sorted out from a distance.
All the best.
Apr 29, 2017 | Gaggenau Ovens
How do I reset a Gaggenau EB385 F40 fault code
You cant reset this. The servicemanual describes this as a problem with the door lock.
F40 = Check the door locking
function and
parameters with the
customer service test
programme.
Check wiring.
Replace door interlock.
Jun 08, 2014 | Gaggenau EB984 Electric Single Oven
Gaggenau over eb 270 error code f10
hello i m french f10 is a problemn of the temperature sonde that give gou the temperature of your gaggenau
May 26, 2012 | Ovens
Gaggenau oven BO 270 error code E005
We have a Gaggenau BO250/251. It gave error code E005, and after a lot of frustration, we opened the left hand light (NOT the light at the top of the owen) and fiddled a little with the bulb. And voila, the owen worked again.
Stupid design to disable the owen when the light does not work. Bravo, Gaggenau....
May 19, 2012 | Gaggenau EB 270/271 Electric Single Oven
Error code F 20 on Gaggenau EB 260/262 oven
Nov 03, 2009 | Gaggenau ED 220/221 Electric Single Oven
Gaggenau EB290 built in oven - F10 code
If you really cannot find in manual, contact the manufacturer for guidance.
Aug 27, 2017 | Gaggenau EB290/291 Oven
DOUBLE OVEN,GAGGENAU
this oven could be in display mode this only allows non harmful functions to work eg lights etc but no heat this can be disabled through clock test prog reset but you will need an engineer to do it as complicated.
ring 08705 678910 for service and advise
good luck
Dec 16, 2007 | Gaggenau EB 270/271 Electric Single Oven
Gaggenau EB294/295 Electric Double Oven
I am a gaggenau engineer this is usually a fault with the door lock mechanism it can be manually reset eg remove oven and side panel pull back locking arm there is a also a built in test prog in oven clock that will switch door lock back to reset position but these will need to be done by an engineer as oven very heavy.
ring 08705 678910 for service and/or advise
good luck
Nov 20, 2007 | Gaggenau EB 270/271 Electric Single Oven
Ovens Logo
64 people viewed this question
Top Gaggenau Ovens Experts
Dennis Boxerman
Jaime Hernandez
ashburton
Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
