Question about Omega Vehicle Parts & Accessories
Can I use an Excalibur rs 230 dpb remote start system without using the omega bypass module
reynosaelect
  • 165 Answers
SOURCE: Is there a installation guide on an omega
find on this adrees www.caralarm.com
Posted on Mar 17, 2009
alicantecoli
  • 22326 Answers
SOURCE: will my 97 eclipse gst need a universal bypass
forget the boy racer alarm ,it will cause no end of problems in the future ,just use a padlock and chain from the seat fixing and then around the steering wheel ,check this site out for people with problems big time from these alarms being fitted.
Posted on Sep 19, 2009
RonBurgundy7
  • 13 Answers
SOURCE: suburban battery keeps dying
locate the brain under the drivers side under-dash area. this may require you to undo a couple of bolts. you will need a 7MM and a 10MM depending on the year of the truck. from there you can unplug the the 6 pin main ignition harness from the brain. it may just be that the battery is no good. a trip to one of the major chain auto part stores can have them check your battery for free. Good luck.
Posted on Oct 21, 2009
iadame
  • 676 Answers
SOURCE: Need instructions to program and operate my Omega
Your best bet for this would be to go to the Omega website. Be sure you ahve your make and model number of the alarm. Good luck and please rate. Use the link below to retrieve your manual.
www.caralarm.com/manuals.asp
Posted on Mar 15, 2010
MECP Guy
  • 344 Answers
SOURCE: I am installing a bulldog rs 700 for my corolla
You do not require a bypass module, double check your wires to make sure they are going to the right ones, but again you do not require a bypass module for this car
Posted on Apr 11, 2010
Where is a local dist/sales/install/repair in vancouver b.c. canada?
You can contact Omega Research and Development, the makers of Excalibur and K-9, for a local dealer. Omega R&D website
Nov 17, 2011 | Excalibur. K9-ECLIPSE 2-Way Keyless Entry...
When we press the start button the truck will try to start three times starting an stopping all three times
1,- Check the tag wire make sure is connect it or program the remote start to voltage check and you don't have to connect the tag wire.
2.- If the vehicle have an immobilizer was the bypass module installed?
3.- Check immobilizer connections
4.- if you have the tag wire connected make sure the tachometer is learned.
Jan 11, 2011 | Omega MARS-22 Remote Vehicle Starter with...
Remote starter stops working every few months, I was bringing it in to have it reset every time but shop is no longer open. I would like to know how to reset the unit myself.
Use this procedure to reprogram the remote transmitters
1. Turn "on" the ignition.
2. Press the Valet Switch 5 times and wait for horn confirmation of entry into programming mode.
3. Press and release the "Lock" transmitter button on each remote to be coded (one at a time).
4. The system will respond to each with an audible confirmation.
5. Turn "off" the ignition to exit program mode.
The unit should retain the transmitter codes almost indefinitely and should not require reprogramming periodically. I suggest that you call Omega Research and Development, the makers of Excalibur, to see if your unit can be replaced. Their number is 800-554-4053 and their is www.caralarm.com
Nov 10, 2010 | Excalibur RS-310-EDP Remote Start Keyless...
I am installing a bulldog rs 700 for my corolla 1998. I cannot start by the remote starter , and the bypass control module makes noise clicks constantly. So how will I do ? Please help me ! Thank a lots.
Apr 11, 2010 | Remote Starter with Keyless Entry
Need instructions to program and operate my Omega Excalibur K9 car 3-button remote entry.
Mar 15, 2010 | Vehicle Parts & Accessories
My boyfriend has an Omega car starter in his Chevy 1500. Recently he had to replace the battery and now he doesn't know how to reset the car starter. And of course we can't find the manual!! Help!!
There will be a few step you will need to do. First we will need the model number of the Omega car starter Also the year of the truck. I would need to see if there is a bypass module and if so what kind of module. The module might need to be reprogrammed.
Nov 06, 2009 | OEM Systems Vehicle Parts & Accessories
How do you reprogram (reset) the remote starter after power has been disconnected? I dont know what model
Most remote starters do not lose their "memory" when power is lost. However, if an older version bypass module was used for your vehicle it may need to be reset but you must know the model. If you are not able to look under the dash panels yourself, you should take it to your nearest dealer/installer. Some also reset or relearn after the first key start. The FCC number off of one remote may help narrow down model of the remote start also. Vehicle info will also be helpful. DC
Nov 04, 2009 | Omega MARS-22 Remote Vehicle Starter with...
Car turns over but won't actually start.
put key in the ignition and try to remote start it while sitting in it. if it starts, use the brake to shut it down then take the key out and try it again. if it will not start the second try they need to install the bypass module, or install it correctly. not recommended to be done by your self. you can take it to a shop that works on them but they will likely charge you for their time.
Oct 19, 2009 | Excalibur RS-310-EDP Remote Start Keyless...
Vehicle Parts & Accessories Logo
65 people viewed this question
Top Omega Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an Omega Vehicle Part and Accessory Expert? Answer questions, earn points and help others
