Question about Emerson Televison & Video
I have a Emerson LF461EM4 flat screen won't turn on just the red light is on ?
freetek
  • 5568 Answers
SOURCE: Emerson flat screen tv with red stripe
The pixels on your screen are controlled by a matrix composed of switches that turn off and on to produce light.
They are located vertically and horizontally, row-wise and must function together to produce everything from black (everything turned on so no light, or very little, can escape) to layers that represent the three colors that are used alone or in combination to produce the millions of possible shades of each.
One of the switches that controls one of the vertical columns has failed and has turned on the entire column that allows red to display.
The problem switch (a semiconductor combined with many) is permanently turned on, probably part of the screen assembly itself, and was placed with others by robots.
The pin spacing on these 'chips' is very small and often makes the assembly unrepairable.
While LCD panels have fallen hugely in price, you may be looking at a parts cost (labor is probably not too bad) that may make you decide to replace the set.
Unfortunately, the once-proud Emerson name has sadly been degraded and there is a lot of their electronics available from companies that specialize in 'refurbished' products, an indication that they have a large failure rate.
Posted on Jul 07, 2008
SOURCE: Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Posted on Oct 29, 2008
dsacco86
  • 1077 Answers
SOURCE: I have an emerson flat screen that will not turn on ? The red stand by light comes on, but when you hit the power button the green light comes on then shuts off quickly and the TV will not come on?? A
Try leaving the TV unplugged for 30 mins so the TV can reset itself.
If that doesn't work, most cases with the Emerson TV, the Inverter Transformer goes bad on the backlight Inverter Board. It's what powers the screen for your TV. If it can't power up the screen, it automatically shuts off. Basically, they call this "Protection Mode" with this happens.
You can get a replacement backlight inverter board at this web site link:
http://www.shopjimmy.com/catalogsearch/result/index/?q=ewl3706+inverter&p=1&stock=all
Just make sure the board number matches your board.
If it fixes the problem and you decide to throw your old board in the trash, I would like to keep the damaged board if possible. I want to do some research on the board to find out what really causes the transformers to go bad. Here's my e-mail dsacco86@hotmail.com
Posted on Jun 03, 2009
SOURCE: Emerson 19 inch flat screen
change your cc from text to off
Posted on Dec 14, 2010
SD Tech
  • 14553 Answers
SOURCE: I have a jvc lt-32a220 flat screen and won't power
Power supply or microprocessor in the set---have you tried to unplug set and or box if used from power for a while and then power back?
Do I understand it is a new set?
Posted on Dec 10, 2012
Hi I have a Emerson lf461em4 when I turn it in Emerson comes across the screen and then the screen goes black
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Feb 04, 2017 | Emerson Televison & Video
Our emerson tv stopped turning on its model LF461EM4
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 05, 2016 | Emerson Televison & Video
Emerson lf461em4 wont power on solid red light
Could be an open internal fuse or power supply failure
Sep 24, 2016 | Emerson Televison & Video
I need to replace the main board in my Emerson LF461EM4 will a board from a magnavox 46ME313 be compatible they appear to be the same board with different firmware
Magnavox Philips and Emerson uses same types of board in some of their models. if its looks similar then you can try replacing.
If you wish to get some details; check the site linked here. Pull up older posts.
Sep 13, 2016 | Emerson Televison & Video
Emerson tv modle #lf461em4 comes on and shuts off after a few seconds
Hi Nancy,
This problem generally happens due to backlight failure. Either the backlights have failed or the required voltage to drive them is missing. You will need the help of a TV tech to handle it.
Good luck
Apr 16, 2016 | Emerson Televison & Video
I have a 27inch Philips flat TV that when its pluged in the light is solid red and TV won 't turn on
Common TV Repair for Emerson, Sylvania, Philips, Magnavox
? 5:35
www.youtube.com/watch?v=nQHWrJJg4Mc
Oct 11, 2013 - Uploaded by Tampatec
Top most common LCD TV repairs for Emerson, Sylvania,Philips, ... my tv wont turn on neither the led ...
Nov 01, 2015 | Philips Televison & Video
Model LF461EM4. Why won't it turn on?
Fault to the main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 05, 2015 | Emerson Televison & Video
Emerson flat screen won't power off and screen flashes blue ,green, red and black?
Sounds like the main board causing that type of symptom. You can get replacement main boards from www.tvrepairworld.com
Jan 10, 2013 | Televison & Video
It won't turn on, the red light flashes
That means that its no good and needs to be replaced
Aug 02, 2012 | Emerson LC320EM8 32 in. LCD TV
Televison & Video Logo
37 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
