Question about Garden
The grass box full alarm is sounding even though box empty.
Have cleaned off residue grass cuttings from sensors and alarms sounding even when mulching attachment used?
  • 225 Answers
SOURCE: water full alarm
Hi, There should be a little actuating rod poking down from the roof of the bucket chamber which contacts the bucket-float at one end and a microswitch at the other. The microswitch
must be activated to make the compressor and fan run.
Check this if you can to see whether this rod or lever is present, absent, lying on the floor or just plain stuck. If it is stuck in the "full" position then you'll probably have found the problem.
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills.
If they do not, please hold off on the rating and add a comment with more details so I can try to
help you further. Cheers, D
Posted on Jul 13, 2008
SOURCE: My Magicolor 2300dl printer displays
. Remove Waste Box, Empty box, wipe down w/ dry paper towel
. Turn machine off,. Unplug power cord
. there is a blue rectangular pull knob
.above Rectangular knob @an angle R 2 notches (contain ensors)
. Take an AIR can & hold 6-8 inches & spray N2 ea. sensor
. this should clear any particles that generate a false " Full " Signal
. credit to Nightangel for getting the ball rolling. Thx
Posted on Apr 14, 2009
SOURCE: alarm goes off on jeep grand cherokee lorado
under the ecu on the right hand side inner wing ,near the fuse box is the siren,un plug and remove the ecu then un plug the siren remove it by any means I had to pry mine off it has its own battery pack inside,I binned mine cos it doesn't affect the running of the Jeep hope you got sorted
Posted on Sep 10, 2009
perpetually
  • 360 Answers
SOURCE: uneven grass cutting
I have seen dull blades, blades not installed right and an un-level deck cause that.
Hope this helps.
Posted on Sep 21, 2009
SOURCE: Full water indicator lit continuously even though
Problem was a stuck float in the small water reservoir to the rear left of the unit.. Remove top and left hand side panel. Small reservoir can be seen at the bottom left. Remove small screw and slide off the cable assembly above. You should then see into the reservoir and the float. Clean float and reservoir and reassemble.
Posted on Feb 09, 2010
The bin full light is illuminated and it beeps. We have changed the bag so that it is empty and the sound and light are still on. Help please.
Paper shredders are messy. Fine paper dust covers everything, get a can of compressed air and clean under the shredding wheels. Looking up from the bottom check for any sensors that might be plugged.
Feb 26, 2016 | Dahle 41214 Shredder
Why does my flymo switch off when grass box is only half full?
sound like a bad pressure switch or sensor, try cleaning or washing the bag, inspect for broken wire.
May 17, 2014 | Garden
Trunk ajar alarm sounding constantly, even though trunk seems to be closed properly.
the sensor is part of the latch so that will have to be replaced to fix it. Although water has been known to seep into the latch through the key hole (bad gasket) and fixes itself when it drys out.
Dec 09, 2013 | Pontiac Solstice Cars & Trucks
Portable Air conditioner alarm won't stop
Sadly, if you still are not able to find an answer, it probably mean that the sensor is messed up and the best and cheapest option would be to get a new air conditioner unless you want to take it in to a repair shop and see what their quote for fixing it is.
Nov 29, 2012 | Heating & Cooling
I'm trying to remove my 02 lancer ls car alarm. I've removed the box and all the wires that was connected to the box but my car still will not start. I've even replaced the starter and it still won't...
The alarm had a wire to not let the car turnover/crank, is that what you mean, or the car turnsover/cranks, but wont run. If it wont turnover, usually its a larger wire that was cut and the alarm wired in, you will need to get this wire reconnected again. I dont have a diagram here to tell you the wire color, but usually its a 10-12 gauge wire. So if you have a 2 wires the same color, and its cut, connect them back again.
Sep 05, 2010 | Mitsubishi Lancer Cars & Trucks
Car alarm goes off whilst locked
Problem solved by ensuring there are no metallic objects around the cup holders. My wife had left a key and some coins there and these were interfering with the sensores situated beneath the cup holders. Bizarre but true.
Nov 15, 2009 | 2000 Toyota Celica
Husqvarna ct 135 mower,when attempting to engage cutters with lever beside steering wheel the alarm sounds and then the engine cuts out
Hi Janet,
its the warning button on the grass collector. If the button is not pressed in fully, the machine thinks that the grass collector is off, and therefore stops the engine. I had the same problem. If you take the grass collector off, you will see the button on the top left side of the back of the mower. It is covered by a strip of black plastic that slots over it.
To fix the problem my first solution was to tape a washer onto the plastic strip, thereby ensuring that the button is pressed fully in when the grass collector is on. When I got tired of the washer continually falling out, I used a screw to jam the button in. You should be aware though, that with the second method you will be able to engage the cutters with the grass box removed. Potentially a small child (with long arms) could put his/her arm down the shute and chop fingers off etc. I have no kids, and thereby feel safe.
Jul 16, 2009 | Husqvarna Garden
Just bought a 2.0 16v probe,problems with the alarm,just keeps going off.Is it possible to disconnect the alarm and still have the immobiliser working?
Yes this alarm didn't come with the car from the manufacture like this its an aftermarket piece so just go through all the wiring and cut off the ones that are connected to the alarm box under the dash on the drivers side.Be careful though you don't want to cut off a wire that is needed but if you fallow each wire from the box to where it connects and then cut it you should be fine.
Aug 02, 2008 | 1993 Ford Probe
1997 Civic elecrtical problem?
All alarm issues aside, the radio losing its settings would make me go and clean the battery cables.
Jul 15, 2008 | 1997 Honda Civic
My Magicolor 2300dl printer displays a 'Waste toner box full' message, even though I have just emptied the waste toner box.
Feb 28, 2008 | Konica Minolta magicolor 2300DL Laser...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
