Question about The Office Equipment & Supplies
Error op-01619 and DM 00769
Our sp 75 plus printer is not retrieving the laminator values when using the diagnostics tool. It constantly report L1 lam com error op-01619. Another reported error is , DM 00769 The lower duplex unit did not reach the correct position. pls what can I do
4 Suggested Answers
SOURCE: heater error in Sp75
tenia el mismo problema, se soluciona verificando que el "ribbon" del laminador este colocado de la manera correcta y la cintilla blanca que tiene pegado uno de los extremos del "ribbon laminador" este pegada al mismo, ya que este funciona como un sensor, si este se despega, la impresora enviara una señal de error y no laminara
Posted on Aug 26, 2009
  • 36 Answers
SOURCE: error op-01619 lam comm error
In order of likeliness
1. Bad power supply in the printer, in the printer there are 2 power supply's if you have 1 lamination module 3 power supplys if you have 2. 1 power supply may have failed and need to be replaced. You will need to remove the outer covers check for the green light on the power supply. Then check the voltage with a volt meter.
2. Faulty system board. Try a firmware update.
3. If the printer was dropped or bumped hard it could be a loose cable inside.
If all that fails, I would take it in for service.
TulsaBiz.net
or MidWestIdSolutions.com
Posted on Aug 15, 2011
BaronVonNuke
  • 1915 Answers
SOURCE: Error 48:00 HP Designjet Z3100 44inch
Make sure that when you reinstalled the service station that it is seated properly or it will bind when the printer engages
Posted on Dec 01, 2014
How to solve e220 and e218
Both of those errors revolve around the laminator.
E220 is Lam2 Tag Error
E218 is Lam 2 Head Lift Error
I would recommend replacing the laminator.
Sep 19, 2013 | Office Equipment & Supplies
Card Jam Error 112 & 245
please calibrate the Lam Film sensor.error 245 is lam sync error please check Lam power/connections and restart the Printer.
Oct 02, 2012 | Fargo HDP5000-LC ID Card Printer...
Error op-01619 lam comm error
TulsaBiz.net
Jun 03, 2011 | Datacard Group SP75 Color Card Printer
The message center say to check lam power and reboot required. How do I reboot the lam
Power unit off. Take Power cord off the printer.
Remove Lamination unit at the connector.
Check it for obstructions.
re-install the Lam unit.
Power up the unit.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 25, 2011 | Fargo HDP5000 Thermal Printer
PVC HID 1000 cards were getting stuck/bent in the Lamination module of our DTC550 printer. Talked to the tech department where we bought the printer/lamination module. They suggest because we are using...
Turning down the lam temp and dwell on the lam unit should have no effect on image color - they affect the processes only AFTER the printing of the card is complete. Make sure you were making adjustments to the LAMINATION settings, not the printing settings.
As to the noise, squeeks and groans emanating from the lam unit usually means mis-loaded lam film. Check the loading of the lam film in the printer and make sure it is not binding on the spools, and that the spools turn smoothly. Other than that, it could just be your printer showing signs of age. They have been out of production for more than 5 years, and do break down with age and usage.
Apr 28, 2017 | Fargo DTC550 Thermal Card Printer
Heater error in Sp75
Sounds like either the thermocouple or the heater went out. Was this the error code?
OP-01604 Thermocouple problem in L1 laminator
The comments in the service manual states:
- Check the thermocouple wire for damage.
- If the thermocouple was recently replaced, verify that it is not installed backwards
- Verify that the thermocouple connector is not unplugged or plugged in backwards
I would probably order a replacement part, call in your local DataCard service representitive or send it to DataCard for repair.
Oct 01, 2008 | Datacard Group SP75 Color Card Printer
Lam Error/Out
I contacted fargosupport.com and a technician walked through the solution, free of charge.
Jul 16, 2008 | Fargo Pro L ID Thermal Printer
Top The Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
old marine
old marine
Mitch Vass
Mitch Vass
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
