Question about The Computers & Internet
Last time I pressed the button underneath to change from lbs oz to grams it reads unSt on the screen. What does this mean please? I have changed the battery but this makes no difference.
  • The Master
  • 2,184 Answers
It means unstable surface level the base
Posted on Apr 30, 2017
SOURCE: Frozen Screen
I had this very same problem. To fix this problem you have to re-flash your RCA MP3 player with the following file: http://download.rca.com/download/RD1022_28_72_76FWUpgrade_v1002.exe My RCA Model RD 1072a as worked fine since flashing the player with this file.
Posted on Apr 06, 2007
  • 14 Answers
SOURCE: My canon a75 continually says low battery after changing them
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Posted on Aug 21, 2009
SOURCE: My remote does not work with my bush a632 tv. i
Hi there we had same problem so phoned 08456040105 and they told me to press menu button on tv for 10 secs and take batteries out of remote and press power button on remote for 10 secs while batteries are out. it worked for us doing both at same time....good luck
Asker's Testimonial " Oh my goodness thank you so much for this advice. I was a bit sceptical but it worked wonderfully!! " - aurora393
Posted on Feb 07, 2010
  • 8 Answers
SOURCE: screen shows ERR. I changed batteries and tried
You're right..This happens often when one changes the battery.Here's what to do :
The ERR message can only be corrected by holding in the DISP/MENU and STOP buttons for two seconds, which results in ALL the material on the recorder being erased. It will say (FOR) for a few minutes while it is erasing everything, then will work again.
Solution found at http://www.amazon.co.uk/Olympus-VN-2100-Digital-Recorder-microphone/dp/B000V3NTEU
Posted on Feb 10, 2010
SOURCE: i have a set of hanson kitchen scales and i cannot
To switch your Hanson kitchen scales from ounces to grams, press the on/off button until you see the display change to the measuring scale that you require. This change option is ONLY available as you are switching on the scales, so if it already on - switch it off first and start again from scratch. Once you have set it to grams, it will remember your choice for next time, so you don't need to worry that you have to do this every time you switch on.
I hope this helps. Good luck.
Posted on Mar 13, 2010
12 oz of pasta in cups or grams measure
That depends on what you mean by "oz" (ounce).
If you mean volume, then 12 oz is 1.5 (one and a half) cups.
If you mean weight, then 12 oz is about 340 grams.
Oct 22, 2016 | Kitchen Appliances - Others
How do I switch from grams to ounces on the Polder kitchen scale?
There is a button on the back of the scale with "g/oz" below it. This changes your scale from grams to ounces or vice versa.
Feb 24, 2015 | Polder Slimmer Digital Scale
Scale stopped giving oz, grams, and kilograms.
Get back to the menu by holding 'unit' when powering up.
Set default values to below by hitting unit to increase digits, and z/t to save.
1 - 00 (press 'unit' until 00 is displayed, then press z/t)
2 - 15 (press 'unit' until 15 is displayed, then press z/t)
3 - 00 (press 'unit' until 00 is displayed, then press z/t)
4 - 05 (press 'unit' until 05 is displayed, then press z/t)
It will only save if you see an 'f' display before turning off.
There is a limit to the amount of times the unit can 'flash' to the memory. If you cannot see the 'f' display, the memory is full and you cannot change.
Hope this helps!
Mar 10, 2014 | Kitchen Appliances - Others
I have the Salter Scales model 2040, it is currently sent to oz, do you know how to change to grams as there is only 1 button. thanks
I just had a play with mine as I wanted to change the weight mode too.
The solution is this:
While the machine is OFF, press and hold the button for about 5-10 seconds.
The display will go from 8888 to show the weight measurement (lb oz) at the top of the display.
Press the button to select the weight you want.
You should be able to continue with your baking :o)
Hope this helps
Oct 09, 2010 | Salter 2001 electronic kitchen scale
How many grams of r134a will it take as it has no plate with the info
Usually it will take 2 or 3 cans of 134a to charge a typical American car's or light truck's a/c system.
There are about 454 grams per lb. of matter and each can is about 12 oz. (not 16 oz. = 1 lb.).
3 cans would be 3 cans x 12 oz. = 36 oz. or about 2 lbs. 4 oz.
If you round down to 2 lbs., then the grams is about 454+454 which is about 900 grams rounded down.
You could find the grams per ounce and multiply by 36.
454 /16 = 28.375
and 28.375*36=1021 grams for 3 12 oz. cans of refrigerant.
Jul 04, 2010 | 2000 Ford Ranger SuperCab
Have a Chefmate digital stainless steel scale. It weighs in grams and ounces. It was changed accidently to grams but I want it in ounces. Not sure how to do it and misplaced owner's manual.
Easy! On my Chefmate scale what I have to do is toggle so that "weight" is blinking. Then hit "0" - that is zero. Now you can change back and forth from grams to oz!
Jun 25, 2010 | Microwave Ovens
I have a set of hanson kitchen scales and i cannot change it from fl oz to grams etc
Feb 08, 2010 | Health & Beauty
I have a chefmate nutritional scale that was working fine,then all of a sudden the screen started saying out2. replaced batteries but nothing so far.
It is not OUT2, but rather OUE2, which means your chefmate needs to re calibrate. To do that you will need the following:
a 2000 grams weight or 4.4 lbs, I used a 3lbs protein jug unopenened and a 600 grams glutamine bottle unopened.
Ok so turn your scale off then:
1) press the ON button and leave it press while simultaneously pressing once the TARE button (though it may need more than one or maybe leaving it press for a few secs thought try just hitting it once first), release the TARE and you should see a CAL on the screen (top left), release the ON and it will read:
2) the number 00000 on the first line will appear, click TARE
-this calibrates no weight first-
3) then it will read you another weight mine read 2000 grams, put that weight on top of the scale (NOTE every scale uses a different weight to calibrate i am giving you mine) once you put it there hit tare and it should read PASS
4) Remove the weight and it should read "0", mine read first 1 grm so i had to re do it again until i got 0.
5) You can try weighting different unopened things that you know the weight of, but if not just turn it OFF then back ON and it should read "0"
Congratulations your scale is now calibrated and ready to use again!!!!
NOTES: i have the electric scale if the on tare button does not works for you it may need a different combination to calibrate.
Sep 08, 2009 | Health & Beauty
ONE TROY OUNCE EQUALS HOW MANY CUBIC INCHES? Another way - how large is a troy ounce of gold?
1 troy ounce =31.1035 grams
454 grams = 1 lb
gold weighs .3091 lbs/cubic in
therefore 1 troy oz = 0.2216 cu in
Apr 04, 2009 | Office Equipment & Supplies
Computers & Internet Logo
Top The Computers & Internet Experts
d3yavu3
kimblebear
Level 1 Expert
Dennis Boxerman
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
