Question about Refrigerators
D voltmeter of my 3.5KVA generator stays @ 230v while it is running on bulbs, tv & fan but drops to zero (and everything goes off) once I put 'on' my refrigerator. It returns to 230v if I put it 'off'
  • Thywill Apr 29, 2017
    I forgot to add: the generator rpm seems ok because the engine doesn't stop at all; it continue to fire. But the voltmeter drops to zero and the power will go 'off'. Put off the refrigerator, it returns to 230v and power is immediately restored.
  • 3,828 Answers
Adjust the governor on the motor
or the generator cant take the max load anymore
do your
sums again must be close to the 3.5 kva with that lot on
Posted on Apr 29, 2017
  • 1 more comment
    will the governor be responsible?
  • magna buff Apr 29, 2017
    a fridge is not constant voltage draw like bulbs and TVs the fridge compressor kicks in and out .via thermostat i dont know the motor size or draw that fridge is when it kicks in each time
    ..what is supposed to happen ..
    ......when more load is applied to the generator ... the Governor responds and increases the revs on the engine to get the generator to generate more electricity ...if the generator cant make more volts the lot needs a service
    Hello Sir... The governor is not responsible. I tried adjusting it; got 260v on voltmeter. But once I power bigger appliance like refrigerator, the meter drops to 10v.
    Anyways I checked the AVR; it was very hottttt!!! The capacitor looks swollen. Without wasting further time, I got another AVR, adjusted the potentiometer and wow! The refrigerator, cooker & all appliances powered 'on' effortlessly.
    Thanks magna buff for finding time to help. I am grateful.
SOURCE: GE Side by Side Refrigerator
if you checked with a volt meter and there is no power then youhave a bad relay in the frirge
Posted on Jan 25, 2009
CarlGehrke
  • 169 Answers
SOURCE: My porter cable generator 3000 wt will not stay running once star
If this generator has been stored for any length of time with fuel in the carb you probably have a plugged main jet in the carb. As joboo1 says there are a few other things that could cause this behavior, but most often I see dirty carbs, water in the fuel, and plugged/dirty air filters. Get a flashlight and look into the fuel tank thru the filler hole, if you see anything floating in there you've got water in the fuel. Look at the ari cleaner, oil and fuel on the element indicate a dirty carb. Of course check the oil level. Lastly, take the bowl off the bottom of the carb (shut off the fuel valve first), if you see debris in there the carb needs a good cleaning.
Regards,
Carl
Posted on Mar 01, 2009
dennymulford
  • 1055 Answers
SOURCE: Alternator won't charge consistently on 1988 GMC suburban
fake it off and have it checked for free at auto zone, it sounds like your voltage regulator is shorting out
Posted on Mar 09, 2009
  • 16 Answers
SOURCE: Piaggio Skipper 125 - fuel needle goes to full, voltmeter drops.
Maybe it is picking up and reflecting the light from the green light that stays on continuously while the scooter is in operation.
Posted on Dec 31, 2009
gordanddar
  • 477 Answers
SOURCE: norcold refrigerator igniter not generating a
Sounds like your ignition board is not working.
Aftermarket ones have a common automotive fuse.
Have a look at the following on line so you know what you are looking at in your unit.
Dinosaur electronice makes a UIB ( universal ignition board ) that will fit just about any fridge.
about $100 online. $250 where I tried to buy one at a rv place.
Posted on May 27, 2010
My Duromax XP10000E just started to drop volts to zero intermittently while running.
MMmmm... MANUAL here:
DuroMax XP10000E Generator Owners Manual
(NOTE! SCROLL DOWN at the site above)
A few TROUBLESHOOTING tips here:
http://duromaxgenerators.org/frequently-asked-questions
THIS YOUTUBE may help you too?
DuroMax XP10000E Generator Wiring and Diagram
And finally try this ~ looking at any YOUTUBE that may help you!
Duromax XP10000E YouTube
I hope SOMETHING in the above links helps you, Dan!
Anthony
Apr 16, 2018 | Cars & Trucks
Power Automatic low then balnce
Do you have other loads pulling the voltage down, compressors in airconditioning, motors, etc. Perhaps when you measure voltage at 230V which should not cause a issue it's within 10%. But maybe a motor pulls in and drops it further than you measured? Re-check with meter and record. Check generator for overloading and also wiring size feeding
Aug 28, 2013 | Honda Electrical Supplies
Freezer dropped to -12 won't stay at -1
freezer light does't work, I put in new bulbs and it doesn't stay cold.
Dec 06, 2011 | Sub-Zero 632 / S
I have a Philips rear projection TV model # 50PL9126D/37. I started having problems when the red indicators on the power swich for the overheat and the bulb failure starting coming on and the picture...
Yes, the fan issue. I have seen this set malfunction before, the fans they put in it were junk. You can replace with similar computer fans, just make sure you trace the wires back because some of them are color coded wrong on the internal wires. The black wire should be ground - same as tuner ground, the red wire is power +12v I believe, it may fluctuate depending on temperature, and the yellow wire is the feedback. The higher the voltage goes on the yellow wire, the slower the fan is turning (the tv uses this to tell if a fan isn't spinning and shuts it down = your problem) hopefully just replacing the fans will solve the issues. Make sure you put them in so they blow the direction you want, the one on the side blows out, and the one under the lamp you'll have to check. I ran into one of these where the fans were failing, but I replaced them and still couldn't get it solved. The power and feedback signals go into the "MAIN board" and I suspect there was a problem there. You should be able to hardwire the yellow wire to ground to "trick" the tv into thinking the fans are running full speed (Zero volts) but it didn't work for be as it had on other brands before (ie - do that at your own risk). Let me know how I can help, but suspect bad fans in this TV for sure.
Jul 24, 2010 | Televison & Video
Television only stays on for a minute and then goes out
Its the bulb that is failing and the cooling fans are dusty. Those bulbs dont fail all the time all at once.
Apr 18, 2010 | Televison & Video
Lights stay on in fridge
HI. The door switch will be the culprit here.
The interior light in most refrigerators, and the fan in some, are controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Dec 10, 2009 | LG LFX25960ST Stainless Steel French Door...
KDF E60A20 screen goes blank loses sound for 10 60 seconds
I've had this same problem ongoing for a couple weeks. Finally, tonight it would shut off every 20-30 seconds, stay off for another 20-30 seconds then come back on. It turned out to be my bulb. I blew the TV out with compressed air, removed the bulb and disassembled it. Taking the bulb out of the plastic cage I then remove one of the metal screens at the top of the bulb, it just has little clips holding it in. I took a bottle of rubbing alcohol, some Q-tips and proceeded to clean the inside of the bulb through the screen hole. After cleaning the inside I put the screen back in, cleaned the outside of the bulb with a rag and alcohol, then reassembled everything. The TV is much brighter, I had to turn down the brightness setting and has been running the last few hours without an issue. You can avoid all this by buying a new bulb but I don't have the money right now to replace it and I'm cheap so I'll milk this bulb for everything it has. Heat kills bulbs so if you clean the screens and blow out the TV once every couple months you'll get a lot of life out of it..... I'm almost to 4 years on my original bulb and my TV is on constantly!! Good luck to all!!
Mar 15, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
TV goes off intermittently
sounds like an intermittent shut down which is heat related. some part , maybe one stuck on a heatsink is warming up and running too much current triggering shutdown.
to find it you can tell what is shutting down with a voltmeter, or you can heat suspected parts with a blow dryer to speed the shutdown .. or freeze spray to see if it goes beyond your shutdown time.
Nov 10, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
2002 hyundai sonata headlights
GENERATOR OUTPUT LINE VOLTAGE DROP TEST
This test determines the condition of the wiring from the generator "B" terminal to the battery (+) terminal (including the fusible link). 1. Be sure to check the following before testing: a. Generator installation and wiring connections b. Generator drive belt tension c. Fusible link d. Abnormal noises from the generator while the engine is running. 2. Turn the ignition switch to the OFF position. 3. Disconnect the negative battery cable. 4. Disconnect the generator output wire from the generator "B" terminal. Connect a DC test ammeter with a range of 0-100A in series between the "B" terminal and the disconnected output wire. (Connect the (+) lead of the ammeter to the "B" terminal. Connect the (-) lead of the ammeter to the disconnected output wire.) An inductive-type ammeter which enables measurements to be taken without disconnecting the generator output wire is recommended. Using this equipment will lessen the possibility of a voltage drop caused by a loose "B" terminal connection. 5. Connect a digital-type voltmeter between the generator "B" terminal and the battery (+) terminal. (Connect the (+) lead of the voltmeter to the "B" terminal. Connect the (-) lead of the voltmeter to the battery (+) cable.) 6. Reconnect the negative battery cable. 7. Connect a tachometer or the scan tool. 8. Start the engine. 9. With the engine running at approx. 2500 rpm, turn the headlights and other lights on and off to adjust the generator load on the ammeter slightly above 30A. Limit: max. 0.3V When the generator output is high and the value displayed on the ammeter does not decrease to 30A, set the value to 40A. Read the value displayed on the voltmeter. In this case the limit becomes max. 0.4V. 10. If the value displayed on the voltmeter is still above the limit, a fault in the generator output wire may exist. Check the wiring between the generator "B" terminal and the battery (+) terminal (including fusible link). If a terminal is not sufficiently tight or if the harness has become discolored due to overheating, repair, then test again. 11. After the test, run the engine at idle. 12. Turn off all lights and turn the ignition switch to the OFF position. 13. Disconnect the tachometer or the scan tool. 14. Disconnect the negative battery cable. 15. Disconnect the ammeter and voltmeter. 16. Connect the generator output wire to the generator "B" terminal. 17. Connect the negative battery cable.
Jun 05, 2008 | Hyundai Motor 2002 Sonata
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
