Question about Boss Music
How to connect boss dd3 with studiomaster 16 channel mixer?
  • 45 Answers
Use 1/4" plug cables or XLR-1/4" cables with the fx loop, depending on the type of connector of your mixer. Don't use batteries, they don't last. Use a type 2 (for noise reduction) 9V wall outlet adapter.
Posted on Jul 26, 2017
4 Suggested Answers
PolyrhythmFX
  • 109 Answers
SOURCE: BOSS DD3 STAYS ON AND WILL NOT TURN OFF
It's supposed to do that. An extra lug on the input jack is connected to the battery and/or power supply's ground.
So the only way to power off any pedal is to disconnect the input jack. If you use a power supply and power multiple pedals you can simply disconnect the power supply to cut power and avoid unplugging each one.
Posted on Oct 09, 2009
PolyrhythmFX
  • 109 Answers
SOURCE: Boss DD3 - LED switches ON but the signal remains dry.
Have you tried a new battery?
If you have experience with electronics then open it up and start testing all the components with a digital multimeter to find the failed component(s).
Unfortunately the newer DD3's are harder to fix then they once were. There is no place to point you other than just to start testing everything. Hard to say what has failed. The signal into the input of the circuit may simply be shorting to the output. Maybe the switch or switching circuit has a fault.
Here is the schematic as a reference: http://www.8bitsindgenug.net/boss_dd2.png
Posted on Dec 29, 2009
Testimonial: "Hi, thanks for your feedback. My DD3 is one of the earlier units (made in Japan). Thanks for the schematic this will be of great help. "
hmerchant110
  • 7191 Answers
SOURCE: I need an owner manualfor a Behringer pmp 3000 16 channel mixer
You can download the manual by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Posted on Jan 15, 2010
How do I set Connect my Boss ME 30 effects peddle .I have a berhinger xeney mixer .Do I need two amps
Try using the insert in/out for the channel you want or the main insert in/out for all channels
Dec 11, 2014 | Boss Music
Shud i get an external equaliser? i'm using MG166CX 16-Channel Mixer as the main mixer.
An external equalizer will not help this at all. The problem is likely within the amp (feeding the main speakers), the connections from the board to the amp, or the speakers themselves. In other words, the answer would be "NO." Best of luck!
Jan 14, 2013 | Music
How to hook power amp to mixer
The output of mixer connects to channel A or B of the separate amplifier and the output of the am connects to the speakers. Amp channels are listed as A and B or 1 and 2 instead of Left and Right because the manufacturer does not assume how you may wire your system. Please remember that compression, limiters and EQ device connect between the mixer and the amplifier with their prespective IN and OUT levels adjusted accordingly.
Apr 30, 2012 | Mackie 1604 Vlz3 16 Channel Mixer
Hi Folks, I have the Behringer PMP3000 Europower Desk. now also have a studiomaster VPX15 Sub (Active 600W). Does anyone know what the crossover arrangements are on the PMP for the Mono out, and what...
There is no crossover arrangement. On the PMP5000 they have a tunable filter INTENDED to do low pass for a subwoofer. When selecting this mode for a subwoofer The frequency of the low pass filter can be set between 30 and 200 Hz. This feature is NOT available on the PMP3000.
There is nothing related to a crossover in these amps other than what is mentioned above.
The MONO out is merely an analog summation of both the L and R channels.
Mar 06, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Low volume, high pith squill
The schematic is here:http://www.vintagesynth.com/roland/xp60.php Take note though that the design was changed for the newer DD3. Here is a link to a forum with links to later DD3 service notes:http://music-electronics-forum.com/t15879/. Start checking transistors at the input. Check voltage readings on pins on the I.C.s to see if they match the supply voltage at IC10 . If you get voltage readings on pins that aren't supposed to have readings there is a good chance that the I.C. you are testing is shorted. Also check the diodes as you proceed.
Jul 26, 2010 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
I have sound coming into the mixer but nothing coming out of the speakers or monitors.
Hello, The problem can be in diverse form but the hints to used is as follows . Check the XLR or JACK connecting cables used for connection , if they are okay , and if they are okay , check for the volume of the mixer and other audio appliances connected to it
May 16, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Jan 15, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Dec 29, 2009 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
Oct 08, 2009 | Boss Music
Problems with certain channels and there gain pots
I assume you are talking about an audio mixer, here's what i think:
I'm not sure about channels 12 and 16, but channels 6 and 9 seem like having some loose solder contacts, which usually occur with long term use - you need to remove the problematic channel strips and check the solder contacts on any of the pots / switches / connectors that protrude through the top panel - resolder any loose or bad solder contacts (i usually resolder ALL pins on ALL connectors, pots and switches just to be sure).
As for the lower gain on CH12 - see if the mixing slider is connected via wires, if so, compare it to the connections on other channels, see if there is a loose wire or if the wires are connected in a wrong way (i had a "lower gain" issue with a mixer once that turned out to be a wrongly connected mixing slider - i obviously wasn't the first person to repair that mixer...)
Channel 16: check input preamp IC, could be a bad electrolytic filter capacitor or other components, possibly a faulty IC.
Hope some of this helps...
regards
3rq8 (Triarcuate)
Sep 06, 2009 | Music
Music Logo
Top Boss Music Experts
Michial Gueffroy
Vito Vacirca Jr.
shaun taylor
Are you a Boss Music Expert? Answer questions, earn points and help others
