Question about Garmin GPS
I have Garmin 128.It is hanging after switching on. What were problems ?
128 garmin ; takes long time to pick up signal and most the time it dos nt and keeps turning off .should i buy a sledge hammer
I wouldnt do that just yet (hit it with a sledge hammer I mean...lol) First make sure its fully charged up that could cause a delay and also cause it to keep turning off on you. After a full charge if it continues to do this then go to www.garmin.com At the top right of the page click on My Garmin and either set up an account or put your user name and password in if you know it. Then go to technical support and ask them about repairing your unit. Explain to them what it is doing and what would the cost be to have it repaired.
I hope this helps you out if it does please leave me a Yes that I did help you with your problem. Thank you.
Apr 06, 2011 | Garmin GPS 128 Receiver
When mitel 5234 is switched on it hangs at option 128 missing
I hope this has been resolved by now by your IT department or Phone vendor. Option 128 is a DHCP option and should be set up by them.
good luck,
Mark
Jan 27, 2011 | Mitel 5215 IP Phone
DHCP DISCOVERY - USING OPTION 128 ERROR ON PHONE
The network switch isn't set up properly.Contact your vendor or network admin for setting this up properly.
May 26, 2010 | Mitel 5215 IP Phone
I need some garmin serivce manual
Hello.
You can find the garmin manual here.
Just type in your unit details.
Nov 07, 2009 | Garmin GPS 128 Receiver
Long beep when turning off
I had the same problem with the etrex Vista. The problem was that my Mac stored hidden files on the Micro SD card and those cause the beep. If you delete the hidden files e.g. with Tinker Tool then you Garmin will work fine again.
Jun 11, 2009 | Garmin GPSMAP 60CS GPS Receiver
GPSMap 172c Can not read Garmin Data Card
I have the Sounder 178C. It will only work with 128 Mb Cards (or smaller). It does not work with the 256Mb Cards - says "Reading Card" forever.
Per Gramin, I had to buy the 128 Mb card and DVD map update. Then program the card with a USB data programmer to make it work.
May 01, 2009 | Garmin GPSMAP 172C GPS Receiver
System in hanging
try to replace your RAM
Jan 13, 2009 | Intel Motherboard
Hanging problem
D845GBV no display in skrin.bib tone continuously for 03 times nonstop, after which nothing happens except for cpu fan running.
Sep 03, 2008 | Intel D845GVSR Motherboard
GPS Logo
27 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
