Question about Vacuums
Where is the fuse located on a dirt buster vacuum cleaner?
  • 3,828 Answers
Black & Decker Dirtbuster Vacuum Cleaner
no fuses in these ....double insulated
the motor has a thermal protection shut off when overheating
will start again when cooled down
empty bag often
if unit keeps shutting down replace vacuum
where is the fuse located on a dirt buster vacuum  - 2477301-black-and-decker-dirtbuster-vacuum-cleaner-0-bwbjq1d2inqbxh534mfqkm1n-3-0.jpg
Posted on Apr 29, 2017
Are bags needed for a dirt devil hand held dust buster?
Dirt Devil Parts
dirtdevil.com/parts/
Dirt DevilNo promo code required. ... most popular: Bags: Belts: Filters: Cleaning Solutions: Filters, F1-F85: Filters, Adapters: Filters, ... vacuum cleaner: Attachments & Tools: Brushrolls, Hand Vacs: Brushrolls, Uprights ... Handheld Steam Cleaners.
Type G (10 Pack) - 3010348001 - Dirt Devil
dirtdevil.com/parts/details/3010348001/type-g-10-pack/
Dirt DevilGenuine Type G bags. Fits all hand vac models equipped with the paper bag adapter. Includes ... The Handheld Vacuum That Picks Up Where Others Leave Off ...
Ultra Corded Bagged Handheld Vacuum - Dirt Devil
Jan 01, 2016 | Dirt Devil Vacuums
Why wont the reset button depress on riccar 8955 or turn on after trying
The reset button does not have a significant amount of movement in response to pressing to with a paper clip or ball point pen. If the vacuum does not start upon pressing the button, then either the thermal protection circuit is not why the vacuum stopped in the first place or the reason the thermal protection circuit tripped has not been cleared. Quoting from the manual
"Your Riccar vacuum cleaner comes equipped with a Manual Reset Thermal Fuse Protector. This thermal protector is designed to protect your vacuum cleaner from overheating due to a restriction in airflow (i.e. clogged hose, operating the vacuum without a bag). Should this situation occur, the thermal fuse protector will safely shut off the vacuum cleaner to avoid any potential damage. NOTE: To determine it was the thermal fuse protector that turned off your vacuum
cleaner, please refer to the vacuum cleaner's headlight. If the headlight is on while the motor is off, then the thermal fuse protector did safely shut down the motor. If both the headlight and motor are off, then there is some reason other than the thermal protector (i.e. pulled plug) your vacuum is off.
To reset the thermal fuse:
. Unplug the vacuum cleaner
  1. Check for problem - over-filled bag, clog in hose, clogged filters, etc.
  2. Correct problem
  3. Locate "tripped" fuse - the small white button located on the bottom of the back side of the main body (roughly one inch to the right of the left wheel)
  4. Using a pencil, paper clip or other pointed object, push the reset button in
  5. Plug vacuum cleaner in and resume use"
Mar 08, 2015 | Riccar 8955 Upright Vacuum
How to fix dirt ***** easy steamer deep cleaner, it is leaking water?
Hi there! Check the clean water tank valve to see if that is where the leak is coming from. If so, your clean water tank will need to be replaced. If the leak is coming from somewhere else we recommend taking the cleaner in to a Dirt Devil authorized service center for repair. I have included a link where you may locate the nearest service center to you. Hope this is helpful. If you still need assistance feel free to reach out to us here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil.
Service Center Locator
Aug 22, 2014 | Dirt Devil Featherlite Easy Steamer Extr...
My eureka multicyclonic vaccuum isn't spinning or picking up any dirt, what do I do?
Try open the bottom cover where the motor is located. It seems the the power belt is broken. Guides and Manuals Eureka
Apr 13, 2014 | Eureka Vacuum Cleaners; AIRSPEED One...
Dead Dirt Devil Featherlite
1. Power cord not firmly plugged into
outlet.
1. Plug unit in firmly.
2. Blown fuse or tripped breaker. 2. Check fuse or breaker in home. Replace fuse/
reset breaker.
3. Needs service. 3. Take to service center or call 1-800-321-1134.
4. Thermal Protector activated.
4. Unplug cleaner. Allow to cool for 30 minutes
Nov 03, 2012 | Dirt Devil Featherlite Bagless Vacuum...
The Dirt Devil Featherlite vacuum cleaner throws up the dirt back out. Sometimes the vacuum cleaner doesn't pick up any dirt
You have a blocked vacuum hose take hose off and out side. Push the garden hose from one end to the other, this will push out the blockage
May 01, 2010 | Dirt Devil Featherlite Bagless Vacuum...
I have a 7.2V Dust Buster Black and Decker cordless vaccuum and we have lost the little filter inside it. Where can I buy it?
I have a 7.2V Dust Buster Black and Decker cordless vacuum and we have lost the little filter inside it.
Where can I buy it?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Please include the brand name and model #
A lot of your local vacuum cleaner dealers carry the Black and Decker filters depending on the model #’s and I will post a few phone #’s listed below so you can order a filter. But 1st always check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://blackanddecker.com/
Contact Us -- Customer Service and Produce Support
1-800-544-6986 (M-F from 8am until 5pm, Eastern Time)
Black & Decker
101 Schilling Road
Hunt Valley, MD 21031 USA
www.A-1Vacuum.com 1-800-657-1874 If you cannot find a local dealer near you they can ship you the parts UPS.
Don – The Vac Man
Go Ahead. Use Us.
Apr 30, 2008 | Vacuums
Vacuums Logo
46 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
