Question about The Office Equipment & Supplies
The green light on my quingo plus flashes 7 times what does it mean
SOURCE: the dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Posted on Apr 14, 2009
localwonder
  • 6784 Answers
SOURCE: Green light flashes 7 times - why?
Ok, the reason for the shutdown is because of a serious control fault within the control panel. it could be because of a simple lose wire or, it could be as serious as a damaged control circuit board.
The best way to find out is to use a multimeter and test all pins on the back of the control panel for their respective operational values. Make sure the wires are not worn and damaged as well. check the entire wiring harness for lose fit on all correlating parts in the unit.
If you are not an experienced electrician, i would recommend calling in a tech for a look. Your tech will run a smilier inspection to make sure its the control and not a motor malfunction.
In most cases, this will most defiantly be a control board failure and replacing the board will usually fix this type of issue.
PLease rate and god bless:)
Posted on May 09, 2009
  • 11 Answers
SOURCE: Lexus RX330 - "Maintence Required Light" flashes 7 times?
reset: turn ignition on...push odometer button till it displays mileage on car...not trip milage but actual mileage. Turn car off. Open driver's door, press and hold odometer button....turn ignition to on....hold odometer button for 10 seconds....odometer display will show -----,----,---,--,-,0000000....maintenance lights are reset...lights will come on every 7500 miles to remind you to change oil and check fluids etec....
Posted on Jun 06, 2009
SOURCE: Philips 42PF7220A/37 42'' TV (LED flashes red 7 times)
Five buck solution; If you have any tek skills at all and are feeling adventurous; UNPLUG THE POWER, remove the back panel; You will be faced with the mainboard. In the lower right quadrant you will see two small capacitors, like tiny yellowish coke cans. If these are bulging, there lies your problem. These must be replaced. If you have no soldering skills, take only the mainboard to a fixit shop and have them solder in the two capacitors easily found on line. No guarantee's but worth a try
Posted on Dec 14, 2009
SOURCE: when i turn the printer on the light flashes amber
when i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked normally after being off for a couple of days, but now it is doing that again.
Amber light flashes 7 times, then green for a couple of seconds, then amber 7 times etc.
Posted on Jan 03, 2011
Quingo air wont go. New batteries showing charged but green light still flashing. Have checked not in free wheel
How many times does the light flash. This will tell you the fault. Then check in the trouble shooting guide in your manual.
Apr 18, 2015 | Health & Beauty
I have a quingo plus mobility scooter when I've switched it on the green led flashing always 5 times. What fault that mean? Just fitted new batteries.
hi, that is related to your brake, either a wiring issue, connection etc, the micro-switch located on the brake or the brake resistance changing ..
Regards
Rob
www.gewizrepairs.co.uk
Mar 26, 2015 | Health & Beauty
Where can I buy batteries for my Quingo Plus Scooter I need 2x50Ah Batteries?
Look online for source. Country of origin doesnt matter, just battery information.
Sep 29, 2014 | Health & Beauty
Maintainence manual for quingo plus mobility scooter
Sadly i cannot find a manual however I can help you with the repair because I know these scooters very well. regards GeWiz
Dec 06, 2012 | Health & Beauty
Need handbook or manual for Quingo plus
Hi Catherine, Quingo customer services can replace the manual at a small charge. Please give them a call on 01582 430 889 if you'd like to order one.
Mar 03, 2012 | Health & Beauty
The ready light is flashing green then amber. What does this mean
This lights pattern means the waste tank needs the blotter replaced.
Then once replaced, the tank reset needs to be performed.
Waste Ink Tank Reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and release the Resume button
4. Press Resume button 2 times then release BOTH buttons.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
Jun 15, 2010 | Canon i950 InkJet Photo Printer
When i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked...
Jun 02, 2010 | Canon BJ I6500 InkJet Printer
The middle light keeps flashing 7 times then stops then repeats. the other button to change the paper type. i dont think its a ink issue possibly a paper one.
This mean multiple ink tanks of the same color installed or Ink tank in a wrong position.Check your ink tanks.This ink tanks has a memory chip.Sometimes this chip fails.
If the green light blinks with a orange 7 times this mean the waste ink tank is full.Follow this:
1. Turn off printer
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
8. Your printer should respond as normal.
Nov 04, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
29 people viewed this question
Top The Office Equipment & Supplies Experts
Gareth Cockram
Gareth Cockram
Tygh Duval
Tygh Duval
Jerry Greenberg
Jerry Greenberg
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
