Primus heavy duty washing machine fault finding
  • Daniel marabe Apr 29, 2017
    On primus washing machine What's mean by error rr13
SOURCE: admiral mega 22 plus heavy duty 2 speed washing machine
I think my set i just got today used is a 3 speed.Seems to be alright for now.There is a thing i was told called a harmonic balance it might be off or messed up.Tina.A(nc)
Posted on Apr 27, 2008
AlmostBob
  • 550 Answers
SOURCE: kenmore heavy duty washing machine 70 series
The most likely cause for water fill temperature problems is the solenoid has burned out, usually cold first, it gets used more. Not a repairable item , easy to replace
Posted on May 25, 2008
SOURCE: i have a kenmore 80 heavy duty it will not spin washing machine
does it agitate?check your coupler.
Posted on Nov 14, 2008
philbran
  • 242 Answers
SOURCE: washing machine does not spin
If the unit is making noise while set to spin but not spinning replace the motor coupling for the fix.
If the unit is silent when set to spin replace the lid switch for the fix.
Both are very common and not expensive plus easy to find online with the model number under the lid. Let me know if you have any other questions.
Phil
Posted on Apr 11, 2009
jsrock516
  • 5911 Answers
SOURCE: water leak, back of washing machine during rinse or drain cycle.
The back panel does not come off. You need to remove the outer casing in order to access the internal components. The following steps explain how:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
With the case removed, you should now have full access to all the internal components and be able to complete a thorough inspection. If the leak is coming from the rear of the washer, check your water inlet valve and associated hoses. Inspect the tub ring where the water dispenses into the wash basket and make sure it is not cracked, or has any loose hoses. If you need assistance in determining where the leak may be coming from, please let me know.
To reassemble the washer, perform the following steps:
1. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
If you have any questions along the way, please let me know. I hope you find this information helpful.
Posted on May 15, 2009
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
How do i find out whats wrong with my washing machine? The brand is whirlpool heavy duty
check for a clogged filter screen on the cold side of the water inlet valve,the cold water shut off, or the hose kinked
good luck
Feb 28, 2013 | Whirlpool Clothes Washer Heavy Duty...
Primus washing machine error 11? Is this a inlet water issue?
Error 11 is definitely a water issue. Usually it's because there is not enough pressure. Error 5 is an overload or mis-balance in the drum
Sep 15, 2010 | Washing Machines
Error code 11 on primus rs16
Error 11 is a water pressure or inlet problem. Check the 1st stage filters in the cold water hoses at the back of the machine.
Mar 03, 2010 | Washing Machines
Kenmore heavy duty series model 82672810 hearing a
i would guess you have something stuck in the pump.
you will need to remove the cabinet and then find the hoses going into the pump. when you remove the hoses, you will find something inside the pump causing the noise.
Feb 23, 2009 | Washing Machines
Squeaking/grinding/rattle noise during wash and spin
That sounds like a clutch problem - probably just worn and need replacement. Will definitely need to pull to find exact fault.
Regards
Nov 16, 2008 | Washing Machines
Ge washing machine, trying to find out if model is a heavy duty washer model #WJSR2070B2WW serial # HF193930G
My solution was, I didn't want to pay $14.99 just to find out if the machine was a heavy duty washing machine. That's why I quit.
Oct 08, 2008 | GE Washing Machines
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
