Question about Saws
Brian has already eaten a 30 degrees slice of his cake and has just cut a slice of 45 degrees what angle of the cake is left over
    Top Expert:
  • Saws Master
  • 45,373 Answers
360 degrees in the cake
30 + 45 =75 degrees
360 - 75 =285 degrees of cake
Posted on Apr 29, 2017
How do I miter with my radial arm saw (RA-2500). I can't tell from the manual.
the slide can be angled by the degree plate where the timber sits
the blade can be angled by the degree plate on the arm that mounts the saw
so you can get a 45 degree to the timber length and a 45 degree angle cut to that angle to give you a corner mitre cut
Jul 03, 2017 | Saws
Diagonal lines at 45 degree angle from left top to right bottom of screen
db:: 4.31::Diagonal lines on tm2 screen? fz - Hivmr
www.hivmr.com/db/fzap9jk8dp87mcjk3cc9jsp7fzxk7pz1
There are faint 45 degree diagonal lines covering my brand new tm2 LCD ... with some static looking diagonal lines going from bottom left to top right. .... DB:3.01:Dv6113 Us - Computer Freezes Showing Diagonal Lines On Screen aj ... Also there arediagonal lines that run across the screen at about a 30 degree angle.
3M Privacy Filter for Laptop diagonal-14.1" viewing screen ...
www.amazon.com/3M...diagonal-14.../B00006B8A9
Amazon.com, Inc.
Rating: 3.8 - ‎1,617 reviews
Amazon.com: 3M Privacy Filter for Laptop diagonal-14.1" viewing screen ... Premium 14.0 Inch Privacy Screen for Widescreen Laptop or Computer Monitor .... 3M™ Privacy Filters create a 30-degree cone of vision so on-screen data is .... You'll also notice a large "3M PF14.1W" printed in the top right hand corner of the filter.
FZ190: Faint Diagonal lines on screen? ' NotebookReview
forum.notebookreview.com > ... > VAIO / Sony
Jan 27, 2016 | Computers & Internet
How do I cut an angle of 135
You would cut a 45 from the backside if the face side is to have a 135 degree cut. You will need trim up to the final cut.
Maybe this image will help explain it.
Mar 19, 2015 | Garden
I did a 45 degree bevel cut with my Dewalt portable table saw and now I can not get the blade back to a 90 degree position, any thoughts?
Did you check to see if the saw has a locking nut on the front of the bevel gauge handle? Its possible you just locked it into position and forgot to unlock.
Oct 05, 2014 | Dewalt Saws
How to cut wood trim corner angles ?
It's generally easiest not to figure them at all - prop them in their intended position (although usually upside-down) to make the cut. Doing that eliminates any need for a compound miter saw. That assumes you're talking about crown molding. If you just want the angles for flat moldings, then remember that a square corner equals 90 degrees. Split that corner in half to make a miter joint, and you'll want 45 degrees. If you're making a half-round corner with three pieces, split the 90 degrees by three (the number of pieces) and you get 30 degrees each.
It does get a little more complicated if you're meeting one thickness molding with a completely different thickness molding - then sometimes the easiest thing to do is not miter at all, but make a "coped joint".
Jul 12, 2014 | Office Equipment & Supplies
Wen miter saw will not keep 45 degree angle
I found a wood working forum and I think that there is a discussion that may assist you with this issue: http://www.woodworking.com/forum/archive/index.php?t-4424.html
Feb 23, 2013 | Wen compound miter saw
A pizza is divided into 8 equal parts. what is the area of one slice if its radius is 6 inches?
Hello and Welcome to FixYa!
Area of pizza (Combined Bread + Crust) = Area=pie * (radius)^2. If divided in 8 equal parts, Area of 1 piece=Area/8.
Area= 3.1415* (0.1524)^2 Area of 1 slice= Area/8 Concerned.
Jun 28, 2011 | Computers & Internet
Cutting 45's on my Dewalt 744
Narrow throat plate should work. Sure you have the blade installed correctly with arbor washers?
Feb 28, 2010 | Dewalt DW744S 10" Portable Table Saw with...
I cannot get a perfect 45 degree angle with my Makita circular saw. Is it me or the saw??
When using the gauge on your saw it is off on the 45 degree cut? If so you might have to use a tri Square every time you want to cut a 45. Sometimes the lock gauge for the 45 angle may be off some. When you put a tri square on the board you cut it is not a true 45 even though the saw says it is?
Jul 29, 2009 | Makita Saws
I want to cut 2 7/8 inch pipe to make a 90 degree elbow, not a corner but a sweeping corner. I know how to cut 2 45's to make a corner but I want the corner rounded.
They make pipe benders for you application. They are quite inexpensive. If you want to do it your self you can. Remember the total number of degrees you want is 90. Each cut is half the angle. Example 45+45=90. 30+30+30=90. and so forth.
I don't know your application but they sell larger radias 90 degree rigid conduit elbows at Home Depot or Lowes.
Apr 24, 2009 | Plumbing
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
