How do I re-light the pilot manually on Brivis Buffald gas heater
co7196
  • 3433 Answers
SOURCE: pilot light not working in gas heater
That probe that sits in the pilot flame is at fault. Remove and replace. Inexpensive fix. Make sure probe is in the tip of the pilot flame. If it does not stay hot enough, it will shut off the gas.
Posted on Jun 01, 2009
  • 15387 Answers
SOURCE: Burners on our Brivis Buffalo 52 Ducted heater aren't getting gas
test thermosat for proper operation ie-broken wire-power if good jump stat and check if unit goes on if it does than stat internal problem or wiring problem and needs replacement or repair --if stat good check fan safety/high limit sensor if good would need to check and test thermocouple thats the tube that the pilot flame burns on may be enough to keep pilot burning but not enough to open valve for heat demand
Posted on May 31, 2010
  • 10 Answers
SOURCE: My water heater pilot wont
Sounds like it is your thermal coupler. Check for a replacement part at your local hardware store. Good Luck.
Posted on Dec 03, 2010
reyjoshua07
  • 1157 Answers
SOURCE: brivis buffalo 85 EMS .
Hi redrosebulld,
If the EPRL light still flashes most likely the thermocouple has worn out. The thermocouple is a safety device which stops the gas from flowing. I will recommend to consult an authorized repairman to check the thermocouple and also the injector.
Hope it helps.
Thank you for using FixYa.
Posted on May 20, 2011
  • 185 Answers
SOURCE: my brivis has electronic ignitor
I would clean the Flame Sensor with a steel brush or steel wool.....
It is a steel rod with a white porcelain body attached to the pilot assembly with a wire hooked to in and it runs back to the control board .....
What it does is prove that there is a pilot flame before the control opens the main gas valve.....
It will try and do this about three times then lock out then when you cycle power it will try and start again.....
Posted on May 30, 2011
Brivis gas central heater pilot clicking all the time. Flame is on and still clicking.
You may need to clean igniter it is not sensing the flame check connections to it also clean pilot .
Oct 24, 2016 | Heating & Cooling
I have a brivis buffalo 85 ducted heating system, from last few days it doesn't come hot air only fan is running. pilot lamp also not with flame. ignation is working. I was turm blue color lid to pilot...
you need a new thermocouple. u can either get one from a plumbing store but the can be a bit fiddley to fit or u can get the proper Brivis one it just pulls out and u put the new one in. then u have to re light the pilot light. make sure u hold it down for at least 45 sec to make sure that it is getting hot enough when u release it it will stay alight then turn gas valve to the on position
May 26, 2014 | Heating & Cooling
I have a Brivis Buffalo 85, pilot light is on main burners will not ignite when turned on? It seems like gas isnt allowed to bar which turns on main burners
Usually a thermocouple or similar device is employed to allow fuel to flow once the unit sees that there is sufficient heat to ignite the fuel. Otherwise it can be a fuel valve that "sees" an unusual flow of gas which sets off the safety.
May 07, 2014 | Honeywell Programmable Thermostat Heater
Brivis buffalo 85 main burner not coming on pilot light is on fan comes on ???
If the pilot is on the thermo couple is ok. Could possibly be a faulty temperature limiting switch, it may be stuck and just needs a spray of WD40 or similar product. Then again I could be completely wrong.
Apr 04, 2014 | Jandy Lite2 LJ125 Ceramic Gas Heater
Pilot light is large and yellow on the brivis 92 wombat
blocked pilot , lack of air so it burns yellow needs blowing out with air line or can of air , or undo and clean pilot .
Jul 25, 2011 | Heating & Cooling
My brivis has electronic ignitor that lights the pilot but then goes out then does it again about three more times before shutting down almost like theres no gas. inside the heater theres a red light...
May 30, 2011 | Heating & Cooling
My brivis wombat 120 igniter won't work so I can't light the pilot
I have a brivis wombat 120. When room temperature is lower than required temperature, it starts to fire up and sends heating air. Now, it does start firing. If I increase the temperature testing, you can hear ant click sound from heater, but no firing. Can anyone help
Mar 26, 2011 | Heating & Cooling
May 31, 2010 | Heating & Cooling
Brivis Upflow/Downflow fan on continuously, no heat
depending on the year of the unit
if its between 1992-1999 it would be caused by the either the pilot not staying alight, or a faulty gas valve not opening,
These models start the fan on a time delay not tempreture so you will only get cold air circulating and when the thermostat is off the fan will stop.
(All models) if the fan is running regardless of the thermostat position an over heat sensor is faulty.
May 17, 2010 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
