Question about The Office Equipment & Supplies
The green light flashes 7 times on my Quingo plus
  • Anonymous May 02, 2017
    Fault code 7 is a speed pot issue & requires an Engineer, please contact our Customer Services on 01582 430900 and we will try to get you sorted out. Quingo
SOURCE: the dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Posted on Apr 14, 2009
localwonder
  • 6784 Answers
SOURCE: Green light flashes 7 times - why?
Ok, the reason for the shutdown is because of a serious control fault within the control panel. it could be because of a simple lose wire or, it could be as serious as a damaged control circuit board.
The best way to find out is to use a multimeter and test all pins on the back of the control panel for their respective operational values. Make sure the wires are not worn and damaged as well. check the entire wiring harness for lose fit on all correlating parts in the unit.
If you are not an experienced electrician, i would recommend calling in a tech for a look. Your tech will run a smilier inspection to make sure its the control and not a motor malfunction.
In most cases, this will most defiantly be a control board failure and replacing the board will usually fix this type of issue.
PLease rate and god bless:)
Posted on May 09, 2009
  • 39 Answers
SOURCE: power light flashes green once then amber 7 times
change/clean manually the main roller because it observe ink.
Posted on Jun 23, 2010
SOURCE: when i turn the printer on the light flashes amber
when i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked normally after being off for a couple of days, but now it is doing that again.
Amber light flashes 7 times, then green for a couple of seconds, then amber 7 times etc.
Posted on Jan 03, 2011
Daniel S
  • 4323 Answers
SOURCE: Clean light "green" flashes 7
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or high temp wash-heated dry-high temp wash-heated dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Posted on Aug 29, 2011
Quingo air wont go. New batteries showing charged but green light still flashing. Have checked not in free wheel
How many times does the light flash. This will tell you the fault. Then check in the trouble shooting guide in your manual.
Apr 18, 2015 | Health & Beauty
I have a quingo plus mobility scooter when I've switched it on the green led flashing always 5 times. What fault that mean? Just fitted new batteries.
hi, that is related to your brake, either a wiring issue, connection etc, the micro-switch located on the brake or the brake resistance changing ..
Regards
Rob
www.gewizrepairs.co.uk
Mar 26, 2015 | Health & Beauty
Where can I buy batteries for my Quingo Plus Scooter I need 2x50Ah Batteries?
Look online for source. Country of origin doesnt matter, just battery information.
Sep 29, 2014 | Health & Beauty
Maintainence manual for quingo plus mobility scooter
Sadly i cannot find a manual however I can help you with the repair because I know these scooters very well. regards GeWiz
Dec 06, 2012 | Health & Beauty
Need handbook or manual for Quingo plus
Hi Catherine, Quingo customer services can replace the manual at a small charge. Please give them a call on 01582 430 889 if you'd like to order one.
Mar 03, 2012 | Health & Beauty
When i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked...
Jun 02, 2010 | Canon BJ I6500 InkJet Printer
Canon i320 amber light flashing will not print
I believe that 7 amber flashes refer to a cartridge error. Check that the cartridge is seated correctly.
Nov 05, 2008 | Canon i80 InkJet Printer
Top The Office Equipment & Supplies Experts
Gareth Cockram
Gareth Cockram
Tygh Duval
Tygh Duval
Jerry Greenberg
Jerry Greenberg
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
