Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
What is an E04 code?
My washing machine stopped in the middle of the cycle and it comes up with this code, and wont unlock. what do i do?
  • 38 Answers
On the front of the machine is a round access port. Insert a paper clip into the tiny hole and push in, rotate this cover clockwise. Access cover should come right off, now unscrew the plug covering the drain assembly, have lots of towels nearby, or a wet dry vac ready, a lot of water will come gushing out, after you have cleaned up the water find the source of the obstruction within the pump and remove the obstruction. Assembly is the reverse of removal. E04 means that it's taking to long for the pump to pump the water out, it's usually caused by foreign matter within the pump housing, whole infant socks have been know to get lodged in these pumps. Hope this helps.
Posted on Jul 27, 2009
Hoover code eo4
Call the service for this product.
Feb 01, 2014 | Washing Machines
E04 Error
E04 is a time out on the heating phase, to confirm this run a cold cycle, if the machine completes the cycle but sticks on any program above 40 degrees, best bet it's a faulty heating element.
Nov 27, 2011 | Bosch Washing Machines
Door wont unlock once a wash cycle has begun
that is correct ,. pump water out then the door will open.
May 20, 2011 | Kenmore Elite 45986 Front Load Washer
Machine just died in middle of cycle. will not
first of all take the waste pipe out from the back of the washer which goes to the outside drainage,make sure you have a bucket to catch all the water that comes out,the lower the pipe the faster it will come out,then you will be able to open the door,and the problem that you have with it stopping in middle of cycle is that the bushes are worn on the motor,these are easy to replace and cost about £10.00
Jun 07, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Frigidaire washer machine stop in the middle of the cycle
Replace your lid switch.
The machine must have a goodd lid switch to continue timer functions after wash and rinse.
Feb 28, 2009 | Frigidaire FWS833A Top Load Washer
Bosch washing machne error E04
This happened to me this morning and I did this. I found my daughters sock in the trap. After fixing I drained the load and started again. Works great. Bosch E04 Solution:
  1. Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, I can't say! I'd guess you could get wet.
  2. Locate the round door on the front of the machine (about 6" in diameter, lower right corner)
  3. Find a drill bit or small screwdriver that fits in the hole in the round door.
  4. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole to 6'oclock and it should come free.
  5. Once the door out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hands. There is a small collector lip at the bottom of the cap, that is where I held my wet/dry vac to catch the water. Unscrew slowly so you don't get flooded. Take your time and keep unscrewing it until it is free.
  6. Pull out the trap that you just unscrewed and you'll most likely see the item that caused the E04 error code. There is an side of the trap that is marked that it needs to be installed facing downward, so watch for that when you put it back in.
  7. Read these directiosn upside down and backwards to put it all back together.
  8. Run a load and watch for leaks. You could leave the door off until you are sure you screwed the cap in tight enough.
Oct 29, 2008 | Washing Machines
Bosch 300 series washer// led code E04
Remove the access panel at the front botton right corner. There is a manual release button you can pull.
Oct 27, 2008 | Bosch Nexxt 300 Series WFMC2201UC
Error code e04 on hoover washing machine
called hoover and they replaced the washing machine
Jul 27, 2008 | Washing Machines
Water not entirerly draining, e04 code continues on...
http://applianceguru.com/forum2/14805.html
Wow - I can't believe it. I had the SAME problem and searched the internet. This was the first site I found and was initially discouraged since there was NO solution, but upon further searching, I found the answer. I'll post the site here http://applianceguru.com/forum2/14805.html and you can just hop on and find out the answer in a much more helpfully worded way than I could ever do it!
I found a girls bobby pin and a rubber band stopping my drain from functioning! I thought it would FOR SURE be legos, but those boys are off the hook!
May 31, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
766 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
