Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony tv video
My tv was working when I must have touched a button on the remote and the video went off. I tried to turn the power off and then on but all that happens is that the power light blinks. I just bought the tv used and I do not have the manual. I do know that it is very heavy but it is not a flat screen. I'm sorry that I do not have the serial # with me.
  • 116 Answers
High voltage power supply failure usually caused by bad solder connections in the horizontal drive circuitry-commonly aggrivated my a recent move of the tv.
Posted on Mar 01, 2008
Sony bravia 65 inch won't turn off
There is one main thing you need to do before any thing you need to unplug the Tv leave off for 24 hours not plugged in do not temp to plug it in then after 24 hours off you need to plug in do not try the remote or press any buttons ok at all just plug in and leave it for 24 hours plugged in then you can unplug the Tv for 30 mins then plug back in and try to use the remote or press the buttons if it still don't work then the power board might be the problem but get back to me afthe 2 days ok to see how you got on
Jul 10, 2017 | Sony Televison & Video
Sony bravia kdl-40w600b..turns off after switching on..and the red light indicates 8 time..whats the issue..and need to resolve
8 red flashes- main board sp prot, try power reset, update with usb, or replace main logic board
How to service fix phones tablets PCs TVs and tech reviews blog by Tampatec
Factory reset:,66/kw/factory%20reset/session/L3RpbWUvM...
First I unplugged my HDMI cable and powered OFF my router (using wireless).
As soon as HDMI 1 showed on screen, pressed the arrow up button on remote, touched the power button on left rear side (uppermost) button on my TV) and let go of arrow up. TV said RESET and after a min, TV went back to setup screen. Followed Setup onscreen instructions and working OK.
May 11, 2016 | Sony Televison & Video
I have a sony bravia kdl-37v5810. sound on loud no picture buttons dont work on set or remote have to unplug to switch off.
Two pieces of information:
First thing to try is unplug the set and a box or receiver if you use them for several minutes from power, then plug things back for power and see if that helps.
Second, Sony is one of the few companies who uses the same access code to reset all their sets for the last 20 years, if it comes on and responds to the Sony original remote you can try that,
set is off, Then with the remote Display, 5, volume up, and power.
If set comes on you should be in the service menu---do not by accident touch any buttons randomly : what you want to touch is 8 (reset or write should appear on the screen in red, then hit enter and the word should change to green and the set shut off.
turn back on with remote and see what happened or not.
Dec 19, 2012 | Televison & Video
I have an sony rm-ez2 and i want it to work with my orion Model #tv1934 whats the code or will it work
As far as I can tell, Sony doesn't have any codes for Orion TVs. You can try searching through all of the codes in the remote. Turn on the TV, press and hold the Set button and then press the Power button. Release the buttons. Then press TV button (component button). Press the CH+ button followed by the Power button. Repeat the CH+ and Power combination until the TV responds (powers off, changes channel). Then press ENT. Check if the TV responds to the remote on other functions. If it doesn't repeat the steps from press and hold the Set button.
This can take up to 70 tries.
Alternatively, try a replacement remote for the TV or a USB programmable universal remote. is a substitute remote that should handle all of the functions.
I hope this helps.
Sep 06, 2010 | Sony RM-EZ2 Remote Control
I have a sony trinitron XBR 32 inch... The pip was turned on by accident, but i don't have the original remote. How do i turn off the PIP? Thanks in advance.
pls. use remot menu key and open main menu use DW key and select system menu see the PIP option is "ON" set option is"OFF" .
See the PIP screen is clear.
Oct 20, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
KDL-32M4000 sony tv screen went black suddenly,
We are having the same problem! Whats the solution!!!?!?!?!?!!!?
Oct 18, 2009 | Sony KV-36FS100 36" TV
How to turn on Sony Trinitron without a remote control
Good day.
Please check with the channel buttons of your unit. They replace the power buttons functions.
Mar 21, 2008 | Sony KV-27V40 27" TV
TV will not turn off and TV buttons preform the wrong functions
check D1004 5v zener diode, if defective it can cause you this type of problem, also check D1003 and D1005.
part # 8-719-929-15 from sony.
these diodes are located in HS board, the one where all your front button are located in. by the way the HS board is no longer availableffrom sony
Dec 18, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
TV wont turn on
just throw it out and never buy a sony again. Sony really went down hill
May 01, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony 36' TV Volume Goes up on own/Stuck on Video 2
There's a setting in the menu. I think it's called "smart audio". It's supposed to adjust the volume automatically for commercials. But I don't think it works that well. Give that a try.
Jan 09, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
32 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
