Info screen on kobellco 210 tracho isnt workn. An wont change modes..
How do I get out of safe mode
Restart your computer and press f5 button and choose start normally mode .
Jan 18, 2015 | Irulu 7" Touch Screen 2gb Android 2.3...
Why does my cooling fan work only when the ac is on?
cause its programed too----probly workn otherwise but u wont notice it till motor is hot--if wasnt workn car wud ovrheat
Sep 01, 2014 | Cars & Trucks
Scaleo p fitted new graphics card asus geforce 210 wont start up
Hi , i suggest try running the driver setup in "custom mode" checking option : clean install , to remove previous possibly corrupt installed settings
Also access BIOS setup and change "first seek peg" or some such, so BIOS communicates to Windows to first seek video device expansion card rather than onboard
(ps , if changed from onboard to expansion card ensure the onboard control applet for onboard video has been uninstalled via add/remove)
Jan 26, 2013 | ASUS GeForce 210 Silent - 512 MB GDDR3 -...
2003 dodge durango 5.9l need help on burping just changed out the water pump .
let it run n chec gauge for ovrheat--if shows then pump isnt workn rite--or thers air in system-----gut enuf fluid in there
Jan 24, 2013 | 2003 Dodge Durango
How to change screen saver on hp mini
Hi Iosherrera,
I see that you are tying to change your screen saver on you HP mini 210-2160NR.
* Your HP mini 210-2160NR has Windows7 Starter Edition installed,
* click on start you will see a search bar type in screensaver,
* then choose Change screen saver,
* the Screen Saver Settings windows will appear on your screen, select the screen saver you desire then click on Apply then OK, this is where you can change your screen saver settings instead of going to personalize.
Windows7 starter edition does not have functions like the other window7 version but the above instructions are a work around to personalize your Windows7 starter.
I hope that this will answer your query regarding how to change your Screen Saver on your HP mini 210-2160NR, have a nice day.
Apr 11, 2011 | HEWLETT-PACKARD HP Mini Lavender Rose...
My car Truck wont start up. The dont hear the pump
first check all fuses and relay to fuel pump. have someone turn the key to on, and listen for a humming noise at tank.I do not believe there is a reset for pump. call any auto parts store and they should be able to tell you. or call a dealer and ask to speak to service,
Apr 16, 2010 | 1999 GMC Yukon Denali
Screen Blank- can't even reset
thats what happened to my ipod there really isnt anything you can do. i really know how you feel sorry!
Dec 30, 2008 | SanDisk Sansa e260 MP3 Player
One of my pictures wont delete, and the screen says protected how do I change that so I can delete it?
If your pic is in the locked mode (Green Key Icon). Bring up picture. Press menu. Press (Playback Menu) and hit OK. Press OK again and it should bring up the pic with option of off or on. Hit off to unlock and you should be able to delete the pic.
Nov 01, 2008 | Olympus FE-210 Digital Camera
My screen is blank on all modes except playback and setup
If you can playback captured images ok but in capture mode your screen goes blank and taken shots are black then the CCD sensor in your camera is faulty and has to be replaced. Nikon agent -if you can find one- will do this for you but it may be uneconomical repair on this entry level model.
Apr 30, 2007 | Nikon COOLPIX P4 Digital Camera
Open Questions:
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
