Question about PRINTER Office Equipment & Supplies
Error code b0605
Printer 2055dn
5 Suggested Answers
tballone
  • 126 Answers
SOURCE: I have HP Laserjet P2055dn
This is a problem with the RAM module you will need to replace it.
Posted on Oct 21, 2010
SOURCE: I have hp printer laserjet
It is posible to have problems with your usb cable. Othert possibilities is that the printer usb port is broken
Posted on Mar 24, 2011
  • 132 Answers
SOURCE: The printer is displaying error:
HI............
Issue Description: Print cannot boot up into ready state with an error message shown on printer control panel. The error messages include ERROR: B0601/ B0602/ B0603/ B0604/ B0605. Root Cause: Firmware crashes. Note: Inappropriate behavior may cause firmware crash. For example, a printer is turned off when critical firmware update is undergoing. Solution: Firmware Update Utility.
There are two use cases when encountering the issue: Instructions for Use case 1: driver is previously installed on PC
  1. Place printer in bootcode mode.
    1. Hold down the Cancel and OK buttons.
    2. Power on printer.
    3. Continue to hold down buttons until control panel dislpays Hewlett- Packard on the first line and Bootcode on the second line.
  2. c01688132.jpg Please observe the printer control panel and verify Downloading Update Data is displayed on control panel followed by Programming App Flash; please wait for upgrade utility to finish. Printer would be restarted automatically and the control panel display would show Ready .
Then the firmware is now successfully recovered. Instructions for use case 2: driver is NOT previously installed
    1. Insert printer installation CD.
    2. In Windows OS, please go to Start , Settings , Printers and Faxes .
    3. Click Add a printer to start Add Printer Wizard as shown blow and click on Next button. c01688133.jpg
    4. Check Local printer attached to this computer box; uncheck Automatically detect and Install my Plug and Play printer box and click on Next button. c01688134.jpg
    5. Select FILE:(Print to File) in the Use the following port: dropdown list and click on Next button. c01688135.jpg
    7. Browse to the CD drive in which the printer installation CD is inserted previously and click OK button. c01688137.jpg c01688138.jpg
    8. Highlight the HP LaserJet P2050 Series PCL 6 found in the printer installation CD and click on Next button. c01688138.jpg
    9. Specify the Printer name and click on Next button.
    10. Select No for Do you want to print a test page? and click on Next . c01688139.jpg
    11. Click the Finish button and allow driver to install as shown below. c01688140.jpg
    12. Verify printer is listed in Printer and Faxes window as shown below: c01688141.jpg
  1. Place P2055 in boot code mode:
    3. Continue to hold down buttons until control panel dislpays Hewlett-Packard on the first line and Bootcode on the second line Printer is now in bootcode mode.
  2. In the Printer and Faxes window, right click on the HP LaserJet P2050 Series PCL6 icon and select Properties .
  3. Click the Ports tab and view the USB ports as shown below.
    NOTE: If more than one (USB001) please take note of all listed ports, as other installed printers may have USB ports (USB002, USB003, etc). c01688142.jpg
  4. Close Properties window.
  5. Plug in USB cable from to PC
  6. The Found New Hardware Wizard will pop up, and tje printer USB enumeration will happen.
  7. Open printer properties and select Ports tab again.
  8. In ports tab, tick the correct port that the HP LaserJet P2050 series printer is enumerated on and click OK . c01688143.jpg
  9. Click Cancel on Found New Hardware wizard window.
    NOTE: Not the driver is installed and it is pointed to correct USB port.
  10. Run HP LJ P2055 Firmware Update Utility.
Posted on Sep 21, 2011
SOURCE: error b0605
HP laserjet p2055dn error message B0605
Posted on Aug 16, 2012
Code Error B0605
B0605 message. Follow HP's directions at http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01687323&lang=en&cc=us&conte...
and put the printer in BootCode mode then ran the firmware updater.
The directions indicated that the printer would restart on it's own, but if does not, so let the printer sit for about a minute after the Firmware Updater says it was done, then power down the printer and pull out it's power cord. Let it sit for about 15 seconds, then plug it back in and start it up. When the printer starts up, the printer's display may go through a bunch of messages (Erasing...) for a few seconds. When it finishes with all of the messages, you should be able to print to the printer again.
I hope this helps. Regards, Mike
Jan 16, 2016 | HP LaserJet M1005 Printer
Packard erroe :b0605 Hp 2055dn show message when booting.how to solve
The printer's firmware (controlling software) has mulfunctioned.
A common error message on the HP LaserJet P2055dn series is the B0605 Firmware Error. If you are handy with a computer, the first step is to follow HP's trouble-shooting steps and re-flash the firmware in BootCode mode, then reboot the printer. Re-flashing the firmware doesn't always help, but it's a good first step. See HP's trouble-shooting document here: Error
B0601, B0602, B0603, B0604, or B0605 displayed during printer initialization
Check this link:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01687323&lang=en&cc=us&contentType=SupportFAQ&prodSeriesId=3662052&prodTypeId=18972&printver=true
If this process does NOT fix your B0605 firmware error, you will probably need to replace the formatter assembly, which is the main logic board in the printer.
Dec 27, 2015 | HP Office Equipment & Supplies
Smearing on HP laser jet 2055dn
That sounds like a drum issue. Try replacing the toner or have you done that already? Give me a call if you ever need to replace the toner. I can beat out Staples and Office Depot. Damien @ iPrint Technologies - 818.700.7419 Dir.
Aug 28, 2014 | Office Equipment & Supplies
Error code b0605
Hi Ekera
Code bo605 Firmware error B0605 on HP LaserJet P2055dn (Printer Troubleshooting)Firmware error B0605 on HP LaserJet P2055dn A common error message on the HP LaserJet P2055dn series is the B0605 Firmware Error. This error basically means the printer's firmware (controlling software) ...Download firmware from HP site & reload basic or updated firmware.
Cheers
Trevor
Jul 13, 2014 | HP Laserjet P2055dn Printer
Error b0605
Jul 05, 2012 | HP P2055DN LaserJet Monochrome Printer
I have hp printer laserjet p 2055dn I got this error on printer screen b0605 then I tried the solution from hp website ...
Mar 24, 2011 | HP P2055DN LaserJet Monochrome Printer
I have HP Laserjet P2055dn printer, it show the error: B0605.
Oct 21, 2010 | HP P2055DN LaserJet Monochrome Printer
Error:B0605 در پرÙ?Ù?تر HP2055 Ú?Ù?ستØ? Ú?راغ...
b0605 on hp laserjet p2055 connected to the network ...how do i sort this out ...khathu
Sep 04, 2010 | HP P2055DN LaserJet Monochrome Printer
29 people viewed this question
Top PRINTER Office Equipment & Supplies Experts
Gene
Hardeepak Bhambh
Hardeepak Bhambh
Are you a PRINTER Office Equipment and Supply Expert? Answer questions, earn points and help others
