Question about The Audio Players & Recorders
What is the perth frequency for Smooth FM digital radio
KaeZoo
  • 156 Answers
SOURCE: Problems with FM with
That is very typical of tuners designed for the US market; US FM radio stations use only the odd numbers. In most cases, tuners made for the US cannot be adjusted for use in other countries. However, a few have an "area" control that can be switched; usually it's part of the setup menu. Check out your owner's manual, if it's available.
Posted on Jul 09, 2007
wyoed1
  • 211 Answers
SOURCE: 75-822 midland radio
You have a bad detector in the radio. Needs serviced. Change the bad detector diode and it should work. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
  • 14 Answers
SOURCE: Opel Astra G 2002 Radio Set from Japan to Middle east
simply your scanner range is from 77 to 90 mhz. you can not listen to any higher frequencies than that.
Posted on Nov 15, 2008
SOURCE: How to test r/c transmitter for 27 & 49mhz using am or fm radio s
I went to wisegeek.com & they took care of problem & did not cost a penny. What happened to your site where it says Let our Expert solve your problem for FREE. Who wants to get advice from someone that does not know how to tell the truth & doesn't know right from wrong-Bye charlie lockhart
Posted on Jan 28, 2009
David-n-TN
  • 69 Answers
SOURCE: How can I adjust my
You will have to replace the radio with a European radio to pick up Euripean frequencies. You have a USA radio in your car and it will have to be replaced.
Posted on Jan 08, 2011
How do i change the AM radio to FM?
Hello
Press RADIO BAND.AUTO PRESET until the band you want appears in the display (direct power on). Each time you press this button, the indication changes as "FM" --> "AM". Hold down TUNE + or --, until the frequency digit begins to change in the display. The player automatically scans the radio frequencies and stops when it finds a clear station. If you can't tuned in a station, press the button repeatedly to change the frequency step by step. If FM broadcast is noisy, press "MODE" until "Mono" appears on the display and the radio will play in monatural without any noise. Only strong FM signals can be decoded to stereo. OK.
Oct 22, 2011 | Sony CFD-S300 Radio/Cassette/CD Boombox
How do you auto preset radio stations?
Hello
[1] Press RADIO BAND.AUTO PRESET until the band you want appears on the display [direct power ON]. Each time you press the button the indication changes as follows. "FM" => "AM"
[2] Hold down TUNE+ or --ve until the frequency digits begin to change in the display.
The player automatically scans the radio frequencies and stops when it finda a clear station. If you can't tune in a station, press the button repeatedly to change the frequency step by step.
If FM band is noisy, press the MODE repeteadly until "MONO" appears in the display and the radio will play it monatural. If FM radio signal at your area is very weak, this type of noise may occur. OK.
Sep 28, 2011 | Sony CFD-S350 Radio/Cassette/CD Boombox
The static level is so high I am unable to hear the radio.
Under menu, select FM frequency. Try using different frequency. A nearby FM station could be bleeding its signal onto the FM frequency your unit is using by default.
Jan 09, 2011 | Delphi Roady XT XM Radio Receiver
Trying to figure out what FM frequencies are avail for my portable XM in my car? 50595 is my zipcode.
KQWC 95.7 is the only FM station that is out of webster city which is the 50595 zip code.
Jan 27, 2010 | Delphi Roady XT XM Radio Receiver
How do i find the FM frequency for a Connex CX-4300-300 CB radio?
FM is just a form of modulation, not an actual frequency. The frequency doesn't change between any of the modes (LSB, USB, AM, FM, CW).
For example, if you are on channel 19 (27.185MHz) on AM (Amplitude Modulation,) switching to FM (Frequency Modulation) mode you would still be at 27.185MHz, but using a different form of modulation.
Nov 10, 2009 | Connex CX-4300HP CB Radio
Got a new mp3 fm modulator, no frequency is detected
u should set the fm frequency on your modulator as same as ur car radio. example, if ur radio states 100.00, set ur modulator 100.00 also.
Oct 10, 2009 | Virtual Reality Sound Labs VRFM7 MP3 FM...
Sirius S-50 Portable
Go to device settings - FM Frequencies - select the FM 1 or FM 2 or FM 3, turn the dial to move the FM frequency to that which you want. Press the Sirius Dog to enter this frequency. That's it.
Oct 20, 2008 | Sirius Satellite Radio S50-TK1 Satellite...
Radio set up on samsung j700
FM radio works the same way that AM radio works. The difference is in how the carrier wave is modulated, or altered. With AM radio, the amplitude, or overall strength, of the signal is varied to incorporate the sound information. With FM, the frequency (the number of times each second that the current changes direction) of the carrier signal is varied. FM signals have a great advantage over AM signals. Both signals are susceptible to slight changes in amplitude. With an AM broadcast, these changes result in static. With an FM broadcast, slight changes in amplitude don't matter -- since the audio signal is conveyed through changes in frequency, the FM receiver can just ignore changes in amplitude. The result: no static at all.
For sellecting frenquencies, go to radio, options, set frequency and search...
Jun 13, 2008 | Samsung Cell Phones
No radio in menu. only music. voice .settings .
The service may not be available in your area. Make sure the headphones are connected to the player when searching for radio stations: Here's pg 15 of the user manual:
FM Radio (if applicable)
The Sansa
player includes an integrated FM radio for listening to live broadcast FM
stations. Please note that the FM Radio function may not be available in your region.
Listening to FM Radio
To listen to live broadcast FM station, follow these steps:
1. Select FM Radio from the Main Menu.
2. A radio frequency menu will appear.
3. Press |<< or >>| to adjust and search for the desired frequency, or select
preset by pressing Select.
4. For fast search, press and hold the |<< or >>| buttons.
Feb 20, 2008 | SanDisk Sansa Clip MP3 Player
27 people viewed this question
Top The Audio Players & Recorders Experts
bihug
bihug
Level 1 Expert
D. E. Hev
AliennoisE
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
