Question about Radio Communications
Have a Barrett 980 SSB marine radio, can't get the tuner to work. The user manual is not very comprehensive
Gavin93
  • 66 Answers
SOURCE: SSB radio
If you are using the radio on a boat, then no, the grounding does not matter that much. However, an SSB transceiver would be hassle to install on a boat because of the amount of power they use to transmit. If the transmission is bad, try using the radio's internal tuner instead of the separate tuner. This may help improve the quality of transmit, however, some radios have a tough time clarifying incoming and outgoing signals and create a garbled sound when it receives a signal or when it transmits. If that doesn't work, then you can try grounding. But if you want a radio that doesn't require all this nonsense tning, you might want to think about investing in a Yaesu. They are pricey, but are one of the best HAM radios.
Posted on Sep 07, 2008
Mechanic688
  • 204 Answers
SOURCE: Users manual for Magnum S-980 10 meter radio
Hello rickstaats, here is what your looking for,,,
http://www.cbtricks.com/radios/rflimited/magnum_s9/graphics/magnum_s9_om.pdf
and
http://www.cbtricks.com/radios/rflimited/magmun_980/graphics/s980_om_addendum.pdf
Compliments of CB Tricks,,, take care,,, Mechanic
Posted on Nov 01, 2008
geordie rob
  • 7 Answers
SOURCE: Wharfedale user manual
i have copied manual to pdf, happy to email it to you
Posted on Dec 29, 2008
drifterK
  • 4924 Answers
SOURCE: I would like to obtain a user hand guide manual,
tel me the model and manufacturer..i-ll see what can be done...
Posted on Aug 03, 2009
MarineTech1
  • 76 Answers
SOURCE: I am trying to find
You will find the maual you need by using the following link :
http://www.prospecelectronics.com/JBL%20MR6%20manual.pdf
Posted on Sep 13, 2009
Yaesu 857D very poor audio out on SSB.
Dbl check your swr in am mode.. Ch your ssb power and mic gain default is 50 on both on hf .. If you use the mh-59 you will need to reduce the mic gain to 35 and it needs to be set for remote mic in the menu. Also the ssb needs to be set 2.5k wide with the ssb carrier zeroed both tx and rx
Apr 29, 2016 | Yaesu FT-857D transceiver
How do i set dead key
some amps like the 6 watt output others don't .Since its a new model radio it may like the 6 watts too.I would question the people you intend on getting this amp from as to whether or not your radio will like those high watts or not and what would he recommend. I have checked around and some techs are looking for a manual for this radio as I am .
Apr 16, 2016 | Uniden CB Radio with SSB Bearcat 980 SSB
Furuno fs 2570 ssb having a problem of tuner NG but antenna tuner is good what culd be the problem
most likely bad contacts, remove all contacts, clean them, and rejoin them, see what happens.
Apr 05, 2015 | Furuno Boating
How to change frequency of ssb fs-1503
For direct frequency input: i.e 2061.4khz transmit - (TX), (2), (0), (6), (1), (4), (ENT) - use (RX) for receive frequency.
For ITU channels - (CH), (4), (1), (2), (ENT)
Direct frequency inputs are restricted to authorized marine band frequencies.
Jun 09, 2014 | Furuno FS1503 HF SSB Radiotelphone EMail...
I cannot hear other people
check that the rf gain is set at maximum, also, I would check antenna and coax for damage/misinstallation. if these seem fine, you may have a receiver failure and need to service the rig
Mar 12, 2014 | Uniden CB Radio with SSB Bearcat 980 SSB
Does my tv have a built in tuner? its a 2003 model#D52W20 AND CAN I ORDER THE MANUAL FOR IT?
Yes ,this set has built in tuner,located on the SSB board next to the Deflection board.
Bottom 2 chassis onthe right is the deflection and on the left is the ssb board and right behind ssb board is the AC power supply board.
You can ship these boards for repair if you are unable to Fix it yourself.
PTS 1-800-844-7871
UED 1-800-648-6657
Retrevo.com For Manual
Encompass Parts might have service manual 1-800-638-3328
Jul 21, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an older uniden marine radio that i just bought and i am wondering how i get on the weather channels
Turn the radio on, set the radio to USA then use the up-down channel selector and scroll down to channel 1 that's it. Good luck.
Jan 30, 2011 | Uniden Solara DSC VHF Marine Radio
Boss marine am fm cd reciever wont get fm radio
it could be either the fm antenna connection or the fm tuner inside the radio.
Mar 29, 2009 | Car Audio & Video
SSB radio
Sep 04, 2008 | Ranger TR-696F SSB CB Radio
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
