Question about Poineer Audio Players & Recorders
Poineer SX737 speakers cutting out - Poineer Audio Players & Recorders
  • Wayne Morris Apr 29, 2017
    Will play for 20-30 minutes, all 4 speakers cut out. Will start playing again Thanks
Poineer deck amplifier dc-z74 relays click but set deck does not come on no display lights dead unit
Part of your PowerSupply is Frito.
Probably the +/- 15 volt rails, could be other.
Check inside power voltages, probably some regulators are gone.
Preferably get a tech unless you have the know-how and test equipment...
PEACE---
Feb 09, 2016 | Audio Players & Recorders
Dvc wiring diagram
need the ohms of each coil and what the amp can handle in ohms
Dec 12, 2013 | Soundstream PCS-12 Car Subwoofer
Faint sound from the speaker have a poineer cx-7705 and m770
Check to be sure that your tape monitor button or lever is switched off.
Jul 07, 2012 | Pioneer Audio Players & Recorders
The left rear poineer speaker will not work, all other speakers will work and all are hooked up properly but no sound will come from the left rear. How do i fix this? any secrets
you may have a bad speaker. try connecting a different speaker output to the speaker and see what happens. if it still doesn't work, you have a bad speaker. if it does work, that output is probably bad and the output ic will probably need to be replaced. there is also a possibility there may be bad solder connections inside of the deck.
Jan 28, 2011 | Pioneer DEH-P2900MP CD Receiver...
CDJ-1000 CD Player: SIR I HAVE 100S POINEER WHN I RUN CD I FACE ERROR ...
hi there,
you need to clean compartment of your cdj. Pls make sure if you can do it yourself then do it yourself or take it to an expert.
djajay
May 05, 2010 | Pioneer CDJ-1000 CD Player
Loud thumping noise
ok u hava pero in solb u us mlifayr
vich wat ok and 2 chanl 4 chanl 8 chanl 16 chnal us platal mi
Mar 06, 2009 | AudioBahn AK402 Car Speaker
Only 3 out of 5 soround sound speakers are working on my surround
I had this problem with my surround. The way I solved mine was by hitting the "sound" button and it showed me a small symbol that looked kinda like speakers and I hit the button a few times untill all of the speakers were lit up. Your button may be different but you can use what I tried as a guideline on how to try and figure yours out.
Dec 29, 2008 | Logitech X-530 Computer Speakers
Poineer dvd rw for computer codecs
What program are you using for the payback, what operating system are you using? as this help with the fix.
May 11, 2008 | Pioneer DVR-110D DVD RW Dual Layer Burner
Surround sound
to connect audio from tv to receiver.Use the monitor out(audio) from tv to receiver .The tv will only put out left/right audio .Also when using the audio out from Sony tv sometimes you cannot use both the internal speakers from tv and audio out from tv to receiver at the same time..Make sure audio is set up on TV menu for audio out..
Nov 20, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
27 people viewed this question
Top Poineer Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Poineer Audio Player and Recorder Expert? Answer questions, earn points and help others
