Question about Amana Washing Machines
My Amana washer sensing light flashes off and on and the time it takes to fill the tub is way to long due to the water turning off and on with the sensing light what or how can I fix this
catriver
  • 878 Answers
SOURCE: AMANA WASHER WILL LEAKS WATER IN TUB AFTER SPIN CYCLE.
Cylon, sounds like you need to replace the water inlet valve. It's not seating and weeping water. For series 10 the part number would be 40097701. Not that hard of a job. Catriver..post back.
Posted on Feb 21, 2007
SOURCE: amana washer won't fill with water
1st I checked the power, compressor in garage had tripped the breaker to the washer circuit. This model has no bells or whistles to tell you if the power is on to the unit. Reset the breaker and unit works.
Thanks FixYa
Posted on Dec 24, 2008
barkencoa
  • 3463 Answers
SOURCE: Washer leaking when filling up tub
Unlikely to be pump, sounds more like hose leaking, or drum seal.
Depending upon severity of leak, place a sheet of newspaper under front of m/c, pushing it as far back as you can. switch m/c on for a few secs, then switch off, remove paper and you should be able to judge where leak is.
Tilt m/c back and have a look underneath.
At 12 years old, if it looks major, I think I would replace m/c.
Plz rate my solution.
Thanks.
Posted on Dec 31, 2008
  • 4088 Answers
SOURCE: When tub filling, it drains out at the same time.
The outlet of the drain hose must be higher than the water level inside the tub--normally the pump inside removes the water when needed. Get a plumber to install a proper height drain pipe for you.
Posted on Jul 16, 2009
  • 492 Answers
SOURCE: I have an auto sensing load whirlpool washer,
is it still under warranty but anyway there is a water fill level switch that controls the water level and when it reaches the setting u have it on then it shuts the water off and the wash cycle kicks in most likely bad or it may have a small hose on it that is crinkled off or stopped up
Posted on Feb 02, 2011
My washer wont leave sensing mode maytag bravos x model # mvwx500xw1
Shift mode sensor Orange thing at bottom of washer stuck on spin not shifting for agitation common in Whirlpool & Maytag and few others
Jul 04, 2016 | Maytag Washing Machines
Tip
The washing machine is under filling water?
This problem is due to fault in the Water-level switch in washing machine.
The Water-level switch is the part in the washing machine that senses the filling water in the tub. When the water reaches to its required quantity the Water-level switch sends the command to stop the water supply. But if the Water-level switch is faulty. It will sense the wrong quantity of water in the machine. And makes the water supply stop bit early then required. So washer does not fills with required water .The Water-level switch is located at the bottom of the outer tub in the washing machine. Many a times removing and reconnecting the switch makes it proper. in other cases it needs to be replaced.
These will help. Thanks
on Mar 18, 2010 | Washing Machines
Washer filled and will not drain if I reset the fill capacity knob it will fill but not drain.
This washer has a belt. The belt drives the pump on this washer. The motor turns in both directions. iIn one direction the washer tub is locked and the tranny agitates. The water pumps out and the tub spins in the other direction. If that pump is locked up or the hose from tub to pump is blocked then it wont pump the water out. Lay the drain hose down towards a bucket and see if any water comes out. If not you got blockage. Once you drain it out tip is back and remove the belt (no tools needed) turn the pump both directions and look for signs of a failed pump. Manual and more
Jun 30, 2011 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
The washer slowly becomes fills with water when not in use
Hello. I can assist you..
check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Aug 16, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Flooding and overfilling
Hi
If your washer is overfilling, check these:
Please accept the solution and revert for any further assistance.
Thanks
Rylee
Mar 24, 2009 | Amana ALW480DA Top Load Washer
Amana washer won't fill with water
Thanks FixYa
Dec 22, 2008 | Whirlpool AWM5125/1 Front Load Washer
Amana washer
take the front panel off, two screws at the bottom of the front panel, probably a 5/16 nut driver will work. You will need a flash light. partially fill the washer with water and then turn it to spin.
Look up underneath the tub and see where the water is leaking from. If its coming from above the bearing you need a seal job.
Bearing, seal kit, not cheap, how old is the machine, time to buy a new one?
T
May 12, 2008 | Washing Machines
Washing Machines Logo
29 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Terry Schneider
Mike
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
