Question about Honeywell Humidifiers
Water is not flowing out of my Honeywell HCM350W humidifier the tank is staying full which means its not working
SOURCE: No water running through the pad
I has same problem and was able to fix ti by taking off the selonoid (cylinder) and then removing both fittings (where the water line enters and then exits the selonoid. The fitting where the water enters has a small pinhole that I found clogged and just cleaned it with a toothpick. After cleaning and reattaching everything, it works fine.
If that doesn't work, you might need a new selonoid which are around $70-$80.
Posted on Dec 08, 2007
SOURCE: Continous ware flow on Honeywell HE220A Humidifier
I am having the same problem. I have had my humidifier for about 5 years now and I just started having the problem where the water continuously flows through the solenoid. I took apart the solenoid by removing the fittings from both sides. When I did that, I noticed that there was a hole in the metal that allowed me to see through to the other side. Apparently, it had corroded and and broken through, allowing the water to pass through the solenoid without really going through the valve within the solenoid. There are several sites that sell replacements for about $70, which is not cheap, but cheaper than buing a new humidifier for $120. Here is one site I found: http://www.iaqsource.com/product.php/honeywell/32001639-002/?product=112783&category=1142
Posted on Nov 20, 2008
  • 189 Answers
SOURCE: No Water flow thru Humidifier
Loosen the brass fitting where it connects to the soleniod valve. If water comes out your saddle valve is ok. Carefully retighten this fitting. With the humidifier turned on loosen the first fitting down stream from the valve see if water comes out. if it does turn the humidifier off and see if it stops, it should. That will tell you the the valve is ok then, just clean the filter and the oriface. if it does not turn on and off check the wiring. if ok replace the valve.
Good luck
Posted on Mar 29, 2009
SOURCE: Honeywell Natural Warm Moisture Humidifier Is On But No Steam?
I have the same problem and I have 2 of them fairly new. I can't seem to find out what the problem is either.
Stumped?????????
Posted on Dec 16, 2010
lkjbhertg
SOURCE: Water tank broken
Hi, I think you can purchase from amazon. take a look here: Maintain Your Home Environment From Anywhere. I hope this helped you. Have a nice day
Posted on Dec 07, 2014
Humidifier is producing water but it is leaking and not going into bucket. Suggestions?
The only thing I can suggest is getting a new one. In theory, it should be possible to just fix whatever the problem is. In theory. However, should the problem repeat itself, it might come to the point where the total cost of ownership will outweigh the cost of getting a new humidifier. I would suggest something like the Honeywell HCM350W. It's a little bit bulky and you'd need to change the filters regularly, but it's a good and not very expensive humidifier.
Jan 30, 2017 | Humidifiers
Need two tank caps with gaskets
Fixya does not sell replacement tank caps.
Sep 03, 2017 | Bionaire W6 Whole House Humidifier / Air...
I have a Honeywell humidfier HE 220A with a KIP U147112 pump. A lot of water bypasses the humidifer and I use 5 gal. in 24 hours. is there an adjustment on the pump to reduce the flow, or some other...
I have a Honeywell humidfier HE 220A with a KIP U147112 valve. Will turning the large screw head on the valve decrease the volume of water flow through the humidifier. Too much water is being wasted.
Dec 20, 2010 | Honeywell HE220A1019 Whole House...
No Water Flow to Honeywell Enviracaire HE225A1006 Humidifier
I have same problem with no water flow on identical humidifier but was able to fix it. Removed the inlet to the solenoid valve and found (1) a small taper mesh filter inside (2) a small diameter orifice that was clogged. Cleaned the miniature filter and used a sewing needle to open the orifice and now works perfectly.
Jan 09, 2010 | Honeywell Humidifiers
I just finished hooking up my new he 220a HUMIDIFIER
I have a HE220, HE 260 humidifier..by pass, flow thru. There is no water flow between the hot water tank and the humidifer. The water valve is on. Is there an inexpensive part I can replace myself first before calling a plumbing contractor?
Dec 30, 2009 | Honeywell HE220A1019 Whole House...
Stumped?????????
Apr 10, 2009 | Honeywell Humidifiers
Honeywell HE220A water not reaching humidifier
Replace the Valve on the unit. Check the small filter inside of it where the waterline attaches first. If its clear and you have lots of flow from the 1/4" line the replace the valve.
Jan 19, 2009 | Honeywell HE220A1019 Whole House...
Good luck
Nov 22, 2008 | Honeywell HE365 Humidifier
Oct 18, 2008 | Honeywell HE220A1019 Whole House...
Nov 30, 2007 | Honeywell HE360A1027 Whole House...
Humidifiers Logo
185 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
