Question about Dishwashers
How do I start the cycle on my Lamont dishwasher please
Flap on tablet dispenser on Lamont dishwasher won't open
Totally stuck or can you open manually?
I suspect you can open by hand, but sometimes overloading can result in jamming.
Should be spring actuated after a solenoid release.
If all is well mutually, sounds like a service call to take the door panel apart and troubleshoot.
if so inclined, you can find an exploded view of your unit on a parts supplier site and, exercising usual cautions, explore yourself.
Oct 23, 2016 | Dishwashers
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Dr. Bill Lamont, how would you handle this
If you were Dr. Bill Lamont, how would you handle this difficult situation
Oct 03, 2013 | Cars & Trucks
Flotec Float switch did not automatically shut off,enginburn out
Hi Lamont .. I would first check test the float switch and make sure that it is faulty, set it up in a tub of water and manually move the float switch. see if it cycles on and off. sometimes the float will get hung up on its support or on the edges of the sump pit. If the float switch is faulty then YES it can be replaced,. try a building supply store like home depot or the pl;ace where you got the switch originally.
Please Vote !!
Jun 01, 2010 | Flotec 13 Hp Automatic Submersible Sump...
Cleaning Cycle not Starting
Please provide the model number and the approximate age of the dishwasher.
If this diswasher uses a turning dial to select the cycle, which turns as the dishwasher progresses, I strongly suspect that this timer has failed and needs replacement. Especially since the soap door never opens. Does the dishwasher drain during and at the end of the full cycle?
Mar 29, 2009 | GE Dishwashers
My webcam PHILIPS SPC 220NC can't connect to video capture device.
steven lamont moore "the reason could be is that it is busy loading on another program
steven lamont moore
Mar 01, 2009 | Philips SPC 200NC Webcam
GU2500XTPS3 QUIET PARTNER - NO START.
23310532.jpg The dishwasher will not start. The following things have occurred;
1. The Cycle option light is flashing.
The model is GU2500XTPS3
Can anyone please assist if they have seen this problem before?
Oct 22, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool quiet partner III
Hello bckp,
Welcome to Fixya
If your dishwasher does not run or stops during a cycle
Is the Start/Resume indicator flashing? Opening the door or
interrupting the power stopped the cycle. Close the door and
press START/RESUME.
Does the Start/Resume indicator flash 3 times when you
press START/RESUME? The dishwasher is waiting for you to
open the door after the last cycle. Open and close the door,
then press START/RESUME.
Is the door closed tightly and latched?
(NOTE: On models with a dual-digit display, the control
displays “- -” during a cycle if it believes the door is not
latched.)
Is the right cycle selected? Refer to the “Cycle Selection
Charts.”
Is there power to the dishwasher? Has a household fuse
blown, or has a circuit breaker tripped?
Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
Is the water shutoff valve (if installed) turned on?
It is normal for certain cycles to repeatedly pause for several
seconds during the main wash.
If the dishwasher will not fill
Check the overfill protection float that is able to move up and down
freely? Press down to release.
Let me know if any of these procedures helped you?
Huuum
Please remember to leave a rating.
Oct 04, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Can't get a connection back on my ISP (embarq).
If you have dial-up, go to tools>internet options>click "always dial my default connection" or if you have broadband click on "Never dial a connection" These settings are found in Microsoft Internet Explorer 5 or higher.
Apr 11, 2008 | Dell Microsoft Windows XP Home Edition
Whirlpool Dishwasher Fills and then Stops
  Check your connection where you connected dishwasher to power cord.
Oct 25, 2007 | Whirlpool 24 in. GU2500 XTP Built-in...
Dishwashers Logo
35 people viewed this question
Top Dishwashers Experts
