Question about Coffee Makers & Espresso Machines
Water is not flowing out of my Honeywell HCM350W the tank is staying full which means its not working
SOURCE: FILL WATER TANK warning
I've had this problem. Looks like its the float in the back corner of the water tank, which contains something magnetic that must trigger a sensor. I put a piece of plastic in the float chamber to push the float closer to the side of the tank. Be careful, if you jam the float (in the up position) then you may run out of water without any warning. Very annoying when you can't get your morning coffee.
Posted on Apr 24, 2008
co7196
  • 3433 Answers
SOURCE: Intermitent heat from Atwood 10 gal marine water heater
Water level safety shutting down heat source
Posted on May 24, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Have no hot water flowing at all from my Atwood
Hi and welcome to Fixya.
Here are 2 manuals that should help you in troubleshooting your RV hot water problem.
Multiple times there is a ref. to resetting the reset switch for 30 seconds on the unit (cover removal required)
For the ignition:
http://www.atwoodmobile.com/manuals/waterheaters/MPD%2093757%20PS%2011.19.07.pdf
For the water heater:
http://www.atwoodmobile.com/manuals/waterheaters/MPD%2093050%20PS%204.9.09.pdf
The manuals as written are full of warnings mixed in with meaningful text. (Not user friendly)
Posted on Feb 02, 2010
  • 5421 Answers
SOURCE: The flush valve does stay open long enough after flushing
Which style of flush valve do you have? If it is the dual-flush option (solids/liquids) I do not know how to adjust those. If you have a traditional style, then the flapper or ball is closing too soon. You need to adjust the guide arm (flush ball) higher or shorten the chain between the flapper and the handle. Adjust this carefully or you will have it fail to seat and the toilet will constantly run.
I hope this helps.
(who needed to replace the fill valve and the flapper at her home earlier this week)
Posted on Feb 19, 2010
ExHandyman
  • 86 Answers
SOURCE: tank over flow with water after now kit put in
Actually you are never supposed to bend the rod. Every unit is designed with adjustment screws to regulate height. The plastic replaces the metal, because they are cheaper to manufacture and ship, and no rust.
Posted on Mar 14, 2010
Humidifier is producing water but it is leaking and not going into bucket. Suggestions?
The only thing I can suggest is getting a new one. In theory, it should be possible to just fix whatever the problem is. In theory. However, should the problem repeat itself, it might come to the point where the total cost of ownership will outweigh the cost of getting a new humidifier. I would suggest something like the Honeywell HCM350W. It's a little bit bulky and you'd need to change the filters regularly, but it's a good and not very expensive humidifier.
Jan 30, 2017 | Humidifiers
My 96 jeep grand cherokee laredo over flow tank won't hold any water. The radiator was staying pretty full until now. It's leaking water can't find where it be?
Pull the dip stick for the oil , its probably over full ! The reason is that you have a bad head gasket ! So water / coolant are mixed with the oil !
Nov 16, 2016 | 1996 Jeep Grand Cherokee
Honeywell he240 no longer working. It is less than 2 months old. I noticed water had stopped flowing out of drain tube. The filter tray is not filling up with water. Humidistat clicks when turned up and...
Maybe the hose is blocked. Take the hose off the supply side, and blow into just enough to add pressure to it and see if that works.
Try this site for more details or a similar issue:
Honeywell HE240 new install not working
Feb 12, 2015 | Honeywell Humidifiers
How do you drain holding tanks 1 and 2 on a trail runner 39qbbh
Are you asking because monitor panel says full still? Not uncommon for paper or other debris to hang on probes inside tank and cause panel to read improperly. Close valve, add some water and then pull valve and listen for flow. If that water flows through ok, your likely empty.
Jan 05, 2015 | Heartland 2013 Trail Runner TR 39 QBBH
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
My honeywell water heater SV9570A 2062 lites up for about 5 sec and then goes out
The flame rod could use cleaning with some steel wool. The other thing is the pressure switch on the inducer might not register the air flow.
Jan 02, 2014 | Water Heaters
Low water pressure
Hi Bob,
You can determine if the tank is the problem by connecting a garden hose to the drain that is provided on most water heaters. Before doing this, be sure to shut of the electrical supply to the heater - otherwise you can damage heating elements if an electric type or waste fuel by heating an empty tank if a gas / propane fired type.
If you get a slow flow out of this drain, it means that somewhere in the cold water supply side to / in the tank - there is a problem. Inside the tank, the cold water is delivered by a "dip tube" that distributes the cold water to the bottom in the tank. Dip tubes are used in both electric and gas / propane fueled heaters. Here's a cut away view of a typical tank:
If the tube is clogged, or there is build up, scale or debris in the supply (cold water) side of the heater, flow rates will suffer. Likewise, if there is a problem with the output of the tank, it will directly affect flow as well.
If you get a good flow rate from the drain, then the issue is going to be on the hot water output side of the heater. Again, the same build up, scale, debris issues on the hot water out put pipe will cause problems with flow. Typcial tanks do not have dip tubes for the hot water side of the tank - as taking hot water from the top of the tank is most desireable and is furthest away from the cold water that rushes in to make up the hot hot water going out.
There's nothing really in the tank itself that can cause issues with flow outside of the dip tube, and piping to and from the tank.
Jun 29, 2012 | Water Heaters
Low water light stays on
If water light and heating lights go on and off, Try this: Fill water, turn water nozzle on, let water flow out. Water light should go off. Shut off water.
If coffee lights are solid, turn off the machine, let it cool off and try the above again.
Jul 07, 2009 | Gaggia Syncrony Compact Coffee...
How to regulate water level in Rheem Fury-series LP water heater?
Yes, no problem as long as it is not completely empty.. Even 1/2" of water is significant
Jul 02, 2009 | Honeywell Programmable Thermostat Heater
Control Rheem water heater temperature based on schedule
This is probably not what you really want to do. It will use more energy to reheat the tank than maintain a full tank of water.
Jun 25, 2009 | Honeywell Programmable Thermostat Heater
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
