Question about Gaggenau Ovens
How do I do the clock test prog reset for my gaggenau double oven
    Top Expert:
  • Gaggenau Master
  • 52,130 Answers
SOURCE: DOUBLE OVEN,GAGGENAU
this oven could be in display mode this only allows non harmful functions to work eg lights etc but no heat this can be disabled through clock test prog reset but you will need an engineer to do it as complicated.
ring 08705 678910 for service and advise
good luck
Posted on Dec 19, 2007
Benimur
  • 6966 Answers
SOURCE: We clean are double wall
Hi williamk77,
Your post "reset the clock" may refer to three (3) clocks in your Dacor ECS230. The first is the "Setting the Time of Day" which could be performed by pressing on the "CLOCK" touchpad. The time of day will falsh. "AM" or "PM" will be displayed and "TIME" will flash in the display. Thereafter, press the touchpad "+" or "-" until the correct time of the day is displayed and release touchpad.
The second is the "Using the Minute Timer" which is better explained at the user's manual page 6. Below is a snapshot of that part of that page.09d8cbe.jpg
and the third is "Timed/Delayed Timed Cooking" likewise better explained at the user's manual (p.9). Should the manual be not readily available, it may be downloaded from here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 27, 2008
dutchman05
  • 487 Answers
SOURCE: timer clock on bosch double oven
Please follow this link and download the instructions.
Manual
Please rate me as FIXYA
Posted on Apr 29, 2008
  • 12 Answers
SOURCE: Gaggenau EB 270/271 Electric Clock
To set the clock:
1. Press the clock key 3 items until the hr/min icon flash.
2. Press the + or - key until it come to your desired time.
3. Press the confirmation (check) key.
You have your time.
If not, call the service support.
Posted on Sep 01, 2008
SOURCE: clock on cooker flashing
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
Posted on May 01, 2009
How do I go about clearing the error code E141 displaying on my gaggenau oven with the clock test prog and reset method???
F23-relay electronics not selecting. There is either a fault with the pcb or a loss of continuity within the ribbon cable. Unfortunately, I think you are going to need an expert to look at this to confirm.
Sorry I cannot be of more assistance but some faults do require a physical check from a professional and cannot always be sorted out from a distance.
All the best.
Apr 29, 2017 | Gaggenau Ovens
Gaggenau oven display clock unreadable.
The display may have to be replaced
Sep 01, 2016 | Gaggenau Ovens
Gaggenau EB290 built in oven - F10 code
If you really cannot find in manual, contact the manufacturer for guidance.
Aug 27, 2017 | Gaggenau EB290/291 Oven
I have a gaggenau 194/195-610 Double oven that takes 25 minutes to preheat to 350%. Is there a quick diagnosis for this problem or do I need a repair service. These ovens have never really worked properly.
It could be a faulty stat or element, an engineer will be able to test them for you
Also he will make sure the cooker is wired properly at the cooker point (correct flex et.)
Sep 21, 2009 | Gaggenau EB294/295 Electric Double Oven
Older Gaggenau double oven unit...heating elements stop working
Shut off te breaker for the oven for an hour then turn on again and it should come back on, just so you know Gaggenau appliances are super high end, if it needs service it will cost you
Jul 10, 2009 | Gaggenau Ovens
good luck
Dec 16, 2007 | Gaggenau EB 270/271 Electric Single Oven
I am a gaggenau engineer this is usually a fault with the door lock mechanism it can be manually reset eg remove oven and side panel pull back locking arm there is a also a built in test prog in oven clock that will switch door lock back to reset position but these will need to be done by an engineer as oven very heavy.
ring 08705 678910 for service and/or advise
good luck
Nov 20, 2007 | Gaggenau EB 270/271 Electric Single Oven
Ovens Logo
Top Gaggenau Ovens Experts
Dennis Boxerman
Jaime Hernandez
Oloyede Monsuru
Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
