Have unpacked a new G24TDC12V15 and ran the first time automatic set-up without connecting the ariel. The TV says DTV database empty. How do I reprogram new set?
5 Suggested Answers
CRTN
  • 716 Answers
SOURCE: DTV Box
Dtv Ready Only Means That It Has A Cable Outlet On The Back They Are Gonna Need The Digital Box If They Wanna Continue Getting Antenna Stations.
Posted on Jan 07, 2009
  • 8909 Answers
SOURCE: Problem, unable to access any digital channels. TV
If the database is empty you need to re load the system.
With your remote controller, go to menu and from that you need to select install or setup.
This will scan for all available channels and store them for use.
Hope that helps.
Posted on Nov 19, 2010
  • 202 Answers
SOURCE: can't tune DTV
Get an amplified antenna, for about 30$ from radioshack and try that, you get no guarantee that you will get stations at all, you can get channels in one spot and two inches away get nothing so a lot of thing affect your reception, with dtv it's gonna work or its not, no more fuzz or semi pictures like analog. Your home may have crappy reception period- but the amplified antenna should get you something- if you get a picture be sure to leave the antenna where it is, moving furniture and other conductive materials can affect your reception also....too much to even write here this is a big subject---try what i have suggested and let me know if it works... good luck
Posted on Mar 30, 2013
  • 1114 Answers
SOURCE: the tv is fine without the freeview box have tried new scart lead also new tv ariel leadand retunned several times
Are you getting any reception at all? Could it be that the antenna is not receiving the signals??
Posted on Jun 12, 2014
THIS PROBLEM IS NOT LOGICAL-SIGNAL STRENGHTS HAVE BEEN CHECKED AND WAS OK BUT THE PICTUE KEEPS BREAKING DIFFERENT ON 3 DIFERENT TVS IN THE HOUSE BUT WHEN I REMOVE ANY ONE OF THEM AND CONNECR IT INTO O
In fringe areas; where signal strength is too weak, this should happen. It sounds that, you're using an Ariel booster along with a splitter. Just connect one TV at a time, without using the splitter. If picture break occurs even this time, adjust the the signal strength of the booster [either low or high], and check whether it can help you. Keep in mind, iv the signal strength is too low, or set to too high, this fault will happen, as AGC [automatic Gain Control] circuit inside the set won't function properly. Gopakumar Gopalan Google
Dec 15, 2014 | Toshiba Televison & Video
How do I access DTV channels? It always indicates 'Database Empty'
When you set up the tuner select analog + DTV and then do a channel search.
Jul 10, 2014 | Sharp LC32D44EBK 32 in. LCD TV
No or bad signal
Check in the Installation Menu that Antenna Power is set to OFF.
There is a chance that the water that came down the aerial lead has damaged the tuner module in the Humax.
Dec 28, 2013 | Humax PVR9300T HD DVR
Problem, unable to access any digital channels. TV displays error message Database Empty, any way of removing this message and accessing DTV again. Thanks
Hope that helps.
Nov 19, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Connect lg m1962d for freeview
Hi, you should be able to receive it. There should be a button, either labelled TV or DTV, that will flick between normal ariel viewing mode or DTV.
Have you tuned everything in?
You should be able to get all channels.My Father in-law uses a seperate box with an indoor arial and gets everything crystal clear.
I fyou need more help - then please ask.
Tony
Jun 06, 2010 | LG Televison & Video
Recieving no digital channels in my LCD TV
hi there alot of the updates for the system should automaticly download via ariel to the tv to keep you up to date some times if the strenght of the signal isnt srong enough then you might not get the update they send out , one thing i have found is that if you use an ariel booster then this makes the signal stronger this helps particularly if you have more than one tv set up with the same ariel, you could try unpluging all ariels to other tvs making sure the ariel lead you are using has no conections in it as this also gives you loss of signal if there are multiple conections in the lead runing from the ariel to your tv set hope this helps some
Cheers ;)
Feb 05, 2009 | Toshiba Regza 42C3030DB 42 in. LCD TV
Bush btv180t- connections
Hi ,
Thanx for the reply.
managed to sort it second time around.
Just ran the coax from the rf socket downstairs to the back of the tv link ,which is attatched into the ariel socket in the back of upstairs tv.
the tv link comes with good instructions,but need reading carefully first.
Jan 14, 2009 | Televison & Video
Freeview channels (DTV) on a Sharp Aquos TV
On my Aquos it's saying no carrier and database empty what do I do, I have trying to reset TV but free view isn't coming on and it's saying carrier 0.
can anyone help
Nov 22, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Hang on refresh database
I had the "Refresh Database" problem with my C250, it just sat there after turning it on! However, the GOOD NEWS is, I corrected it! First I connected it to my PC, then FORMATTED the unit. This gave me an empty player that at least would turn on. Then I downloaded the Sansa "Updater" from the SanDisk website. After setting up the updater software, I connected the C250. It automatically checked for any new firmware, and loaded it into the player. After that I restarted the C250 and it again came up OK without any music loaded. The last thing I did was to load only 1.8 GB worth of music files. My take on the problem is that if you overload the memory, or interupt a file while loading, then the "datbase" function never gets done. I've had mine running for about a week now without problems! Hope it works for you too! <Good Luck> David
Jan 19, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Refresh database
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
