I have a one year old ks electric blanket and when i turn it on it flashes timer off?wont heat at all
brainyass
  • 242 Answers
SOURCE: morphy richards electric blanket - how to use timer setting
Go here and pick your model for instructions:
http://www.morphyrichards.co.uk/DownloadSearchResults.aspx?G1=G19
Posted on Oct 24, 2008
TheMobilian
  • 8220 Answers
SOURCE: Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
Posted on Jan 20, 2009
SOURCE: Dreamland electric blanket not heating
Yes we had an electric duvet from this company and it stopped working. Was replaced very kindly and no fuss by John Lewis and the same thing happened. (They had said they wouldn't replace again) . Spoke to the company but the woman was very rude. Said that if we lived in a rural area that was our tough luck basically. (A power surge or something). I don't think that's acceptable but we have given up on it now. I think there are 'known' issues with these products that are beingswept under the carpet.
Posted on Oct 24, 2009
SOURCE: electric blanket error code
My new blanket works great. Then I changed my sheets and would get the F2 problem. Very consistent after 5 tries with F2 blinking by unplugging at wall outlet and comes on with F2 blinking. Let it rest a night and still the same.
Then I unplug it at the blanket. Hmm, notice a pin was lower than the others. PUSH BACK IN FIRM and tried again. Perfect.
Posted on Feb 23, 2010
  • 652 Answers
SOURCE: my sunbeam electric blanket - the heat controller ...
do away with the blanket, as it is an electrical issue, hazard!
Posted on May 22, 2010
What does the light flashing on a sunbeam electric blamket controller mean and why wont the blanket heat up
The flashing red light is designed to notify you in the event that
a problem has been discovered by flashing the light on the base unit.
Before resetting the unit. First, check the blanket/mattress
pad for visual damage.
If no visual damage is found, unplug the system from wall outlet.
Check that the base unit is well connected to the module. Plug the power cord into the wall outlet. Set the base unit to "On." If the system still does not operate after two or three times trying to reset, disconnect the power cord and get it checked out by a specialist!
Nov 02, 2014 | Home
Tip
I have an electric whirlpool dryer about 4 years old..here are my issues and any...
This advice is for all ELECTRIC Dryers that have a "No Heat" problem.
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) – remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
I hope this information is helpful to you. If you need further assistance, please go to my profile at: http://www.fixya.com/users/jsrock516 and use the "Ask Me" feature for a quicker repsonse to your questions/comments.
on Nov 30, 2009 | Kenmore 62602 Electric Dryer
Winter's tale electric heating blanket flashing "F"
I\'m having the same problem as Jenn. Tried unplugging it and left it for a day. Both sides are now not working. How can I get it to work again? Husband is having a hissy. Please just tell me what to do. or tell me how to download the manual. Haven\'t had this for very long 2 months. if any help.Mary Ellen I did love this when it did work.
Nov 19, 2013 | Winter's Tale Microplush Electric Blanket...
Heaters wont turn on
I don't know how old those are but if they are over 1 year old flexing can cause the heat wires to fail. If it is in the controller it could be a thermal cutoff that needs replacing. My sister got a burn on her hand during the early 80's from an electric blanket so you have to watch if it is not working the way it should there could be a chance of injury.
Oct 02, 2013 | Sunbeam Home
Sunbeam electric blanket repair waynesboro ms
wash the blanket then throw it in the bin
water and electrical components do not mix
electrical blankets are just a resistor element in ceramic covering and if you put that in a washing machine that is the end of the insulation
Mar 18, 2017 | Sunbeam California King Arlington Heated...
I bought a queen dual control warming blanket . I barely used it the first time I bought it a year ago. I put it into my closet for storage after the first winter. I put it on the bed today getting ready...
The flashing lights usually means theres a problem and the blanket has shut itself off so it wont cause a problem...Like burn down your house.
I love electric blankets but I have had little luck with them. Its only a matter of time before they get like this. I have never gotten one to work again after it has started to blink.
If you still have the box maybe there is a warranty.
Sep 21, 2011 | Health & Beauty
Lg dryer stop heating after i stuffed it witha blanket front load gas dryer Tromm 3 years old. I completely cleaned it, but still won't heat I can fix it with your help
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 23, 2010 | LG DLE2514 Electric Dryer
Dec 17, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
