Question about Sony Car Audio & Video
Does Sony CDX 270 CD/car radio require rear pin connections as plug and loom missing?
SOURCE: pioneer cdx-p24s wiring
**** - have you had an answer yet?
I've got one of those too - let me know if you still need the info.
Grtz,
Rick
Posted on May 09, 2008
HitWizard
  • 67 Answers
SOURCE: aux input for sony car stereo (cdx c 5000r)
For Sony Stereos, you will need to get what is called a Bus Converter. The RCA ports you are trying to use are for a CD changer or alternate device like satellite or HD radio, and those have to have some sort of frequency signal to even be selected. You can find a Bus Converter that will allow you to use this as an Auxiliary input. The device you are looking for is called a Sony XA 300, and it will allow you Two extra Aux Inputs, I believe.
Posted on Jan 29, 2009
  • 18 Answers
SOURCE: radio
http://www.scribd.com/share/upload/10754832/1nv50qxw7n28x10bdw30
Posted on Apr 09, 2009
  • 37 Answers
SOURCE: iPOD to Sony Xplod CDX-S2000 CD-R/RW EQ3
you car stereo doesnt have any aux inputs you can check up more on this site
http://www.crutchfield.com/p_158S2000/Sony-CDX-S2000.html?tp=5684&tab=features_and_specs
the rca inputs are for a pre amp or an amplifier
Posted on Jul 29, 2009
SOURCE: my sony cdx 4000r is not picking up radio signals
sony cdx4000r not working correctly plays cd s inconsistently radio not playing ariel in place
Posted on Dec 07, 2009
Does the sony cdx -gt25 work with the sony cdx t69
To connect T69 with head unit GT25,bus cable connecting port is required through which you can connect cd-changer with your head unit.As GT25 has no bus port,it does't work.
Nov 01, 2012 | Sony Car Audio & Video
Wont take the pin code i have
You must have the wrong PIN
To check
The radio SERIAL NUMBER is required for a code
First remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
This information can then be used to see if a code can be calculated
Jun 22, 2011 | Sony CDX-M800 CD Player
I have a sony cdx-ca720x player and want to hook up a mp-3 player where and what do i need to install
you need a RCA to 3.5 Stereo cable and plug it in the rear of the radio. Should be labeled AUX IN!
Feb 17, 2011 | Sony CDX-CA720X CD Player
I need to know where the wires comming out of the plug go to?? wiring diagram. thank you sony cdx-3100
This is the pinout shown on the Sony website for the CDX series players. Pin numbering is as follows:
1 2 3 4 5 6 7 8
9 10 11 12 13 14 15 16
This is looking at the connector with the wires towards you.
Pin Number Wire Color Description
1 White Left front +
2 Green Left rear +
3 Purple Right rear +
4 Gray Right front +
5 Blue/white AMP Remote
6 Blue ANT Remote
7 Red Accessory
8 Black Ground
9 White/black Left front -
10 Green/black Left rear -
11 Purple/black Right rear -
12 Bray/black Right front -
13 Sky blue ATT
14
15 Orange/white Illumination
16 Yellow Battery
Jan 05, 2010 | Sony CDX-3100 CD Changer
Installing a sony cd/radio (CDX-GT222)
Sounds like a possible ground issue. Check your ground (very important). Also try running the red wire to a keyed source i.e. from fuse block. Then run the yellow to a constant 12v source i.e.battery.
Jun 19, 2009 | Sony CDX-GT210 CD Player
Audio electrics
chances are if you got it from ebay there are going to be missin plugs for that unit.....and if i had to guess the two wires would be power (12v) n ground which should be red and black but differs on different cars.
Oct 01, 2008 | Car Audio & Video
Connecting To Auto Harness
Most Sony head units follow the ISO standards in its wiring and connector pinouts.
A Sony CDX-S2000 would be using the below listed wiring:
Yellow - +12V Constant Power (such as the + terminal of your battery)
Red - +12V Switched Power (such as the ACC of the IGN switch)
Blue - Power Antenna
Blue/White - External Power Amp Turn-on trigger
White - Left Front Positive Speaker Wire (LF+)
White/Black - (LF-)
Gray - Right Front Positive Speaker Wire (RF+)
Gray/Black - (RF-)
Green - Right Rear Positive Speaker Wire (RR+)
Green/Black - (RR-)
Purple - Left Rear Positive Speaker Wire (LR+)
Purple/Black - (LR-)
In some models, Sony would have several versions of the connectors depending on the region the unit was intended for use, 10. 16 and 18 pins. The connector (loom) would have to match what your version has. They are readily available from most auto stereo stores and on line. You can try here or here .
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 07, 2008 | Sony CDX-S2000 CD Player
Car Audio & Video Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
